tpi motor pics
Old Oct 3, 2015 | 02:01 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Re: tpi motor pics
Originally Posted by robertfrank
Here's mine
Nice ride man. Let me ask, what did you need to do in order to delete your MAF sensor ?
Old Oct 4, 2015 | 02:44 AM
Twin_Turbo's Avatar
Factory speed density setup...see upper plenum pass side eear. Map sensor right there.
Old Oct 9, 2015 | 08:08 PM
zero13's Avatar
Car: 91 Z28
Engine: Enhanced 5.0L
Axle/Gears: 3:42 Posi
Re: tpi motor pics
SLP headers/Ramair boxes/Accel 8.8's/Strut brace(Hotchkis)...Super clean.
Old Oct 9, 2015 | 08:10 PM
zero13's Avatar
Car: 91 Z28
Re: tpi motor pics
<a href="http://s967.photobucket.com/user/ramzero13/media/2015-07-21%2017.00.56.jpg.html" target="_blank"><img src="http://i967.photobucket.com/albums/ae154/ramzero13/2015-07-21%2017.00.56.jpg" border="0" alt=" photo 2015-07-21 17.00.56.jpg"/></a>
Old Oct 16, 2015 | 09:19 AM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Re: tpi motor pics
Helluva job detailing every nook and cranny zero13. Magnificent.
Old Oct 17, 2015 | 12:44 PM
zero13's Avatar
Car: 91 Z28
Re: tpi motor pics
thanks for the words.
Old Oct 28, 2015 | 11:49 AM
NiG's Avatar
NiG
Car: 1989 Gray ttop GTA
Engine: 5700cc
Transmission: auto 700R4
Re: tpi motor pics
mine is a bit sloppy, but it works just fine, a nice TPI with valve seals to be replaced. Don't have much money nor time, here in Italy, to bring it new
Does it look nice or bad?
Old Nov 1, 2015 | 05:02 AM
KCG's Avatar
KCG
Car: 89 IROC
Re: tpi motor pics
Can someone tell me what color the engine would've been from the factory?
'89 in my case.
Old Nov 1, 2015 | 05:36 AM
paulo57509's Avatar
Car: '87 IROC
Transmission: TH700R4
Re: tpi motor pics
'89 in my case.
Low gloss black.
Old Nov 5, 2015 | 08:08 PM
TPIVette's Avatar
Car: 1991 Corvette
Engine: 383 TPI
Axle/Gears: D44 3.33 gears
Re: tpi motor pics
Old Dec 7, 2015 | 05:45 PM
8996chevy's Avatar
Car: 89 IROC
Engine: 355
Transmission: 5 sp., Alum Driveshaft
Axle/Gears: 3.73 Posi
Re: tpi motor pics
here's my 89 tpi. 355 cu in, 4bolt mains, lt4 hot cam, vortec intake, edelbrock e tec heads, hooker headers, 52 mm TB, Large tube runners, 5 sp, 3.73 posi
Attached Thumbnails tpi motor pics-100_4563.jpg   tpi motor pics-100_4565.jpg   tpi motor pics-100_4568a.jpg
Old Dec 11, 2015 | 10:30 AM
RED85TPI's Avatar
Car: 1985 Trans Am
Axle/Gears: 9 bolt Borg Warner Posi 3.27
Re: tpi motor pics
Thought I'd join the fun!
Old Dec 14, 2015 | 11:26 AM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Re: tpi motor pics
Pardon my rats nest of spark plug wires, something I did back in 1992. She's just now coming out of storage after a long, long rest..... its 99% factory baby! Amazingly, the original hood struts still work!
Old Dec 30, 2015 | 04:39 PM
zero13's Avatar
Car: 91 Z28
Re: tpi motor pics
well, I like that!...8996Chevy... ...
Old Jan 20, 2016 | 09:50 AM
seth1989irocz's Avatar
Re: tpi motor pics
Hooker Shorty headers, k&n, 8mm spark plug wires, throttle body bypass
Old Jan 20, 2016 | 12:54 PM
2012sergen11's Avatar
Car: 1987 Trans Am
Re: tpi motor pics
Lot of nice Tpi setups, I noticed a lot of rubber boots with the stainless piping and was wondering what size adapter you used that fits the throttle body when crushed down (to oval shape). PO put a lt1 elbow on mine but the clamps hit the alternator
Old Jan 20, 2016 | 04:10 PM
Twin_Turbo's Avatar
Re: tpi motor pics
4"
Old Feb 9, 2016 | 09:32 PM
Gray Ghost 8991's Avatar
Engine: 355 TPI
Transmission: 700R4 or 4L60
Re: tpi motor pics
Originally Posted by FireDemonSiC
Here is my TPI, which I am very proud of. Currently it has SLP runners with a port matched plenum, Holley AFPR and that's about it for now (Intake-wise anyways). In a month or two when it warms up I am going to be installing my ported base manifold with 22/lb injectors, top-end stainless steel bolt kit, braided fuel lines, aluminum underdrive pullies and open up the siamese more in the runners.
All I can say is wow! I did a very similar paint scheme on my engine but I haven't gotten my block back from the machine shop yet so its not currently assembled but ill be a son of a gun if that don't look awesome !!!
Old Feb 12, 2016 | 10:16 PM
alpine247's Avatar
Car: 1988 IROC-Z
Axle/Gears: 2.77 posi stock
Re: tpi motor pics
Old Feb 17, 2016 | 01:04 PM
87gtaredonred's Avatar
Re: tpi motor pics
here is mine
Old Feb 17, 2016 | 02:07 PM
danclemts's Avatar
Car: 1985 Volvo turbodiesel
Engine: 1989 305 TPI in the Volvo
Transmission: 1990 700r4
Axle/Gears: 3.73 Dana 30
Re: tpi motor pics
TPI in my 85 Volvo
Old Feb 17, 2016 | 02:49 PM
mrestrictrplate's Avatar
Re: tpi motor pics
88 fast how does the car run with the first intake? Looks great
Old Feb 19, 2016 | 05:08 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: tpi motor pics
Originally Posted by danclemts
TPI in my 85 Volvo
Now that is unique. I like it.
Old Feb 19, 2016 | 05:58 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Re: tpi motor pics
How about a fully built, balanced and blueprinted 334 TPI stroker!?
Attached Thumbnails tpi motor pics-img_20150913_185100.jpg   tpi motor pics-img_20150913_185108.jpg   tpi motor pics-img_20150728_104105.jpg   tpi motor pics-img_20150607_052109.jpg   tpi motor pics-img_20150710_004115.jpg
tpi motor pics-img_20150718_164236.jpg   tpi motor pics-img_20150805_010653.jpg   tpi motor pics-img_20150604_041029.jpg   tpi motor pics-img_20150612_021727.jpg   tpi motor pics-img_20150709_230755.jpg
tpi motor pics-img_20150627_175907.jpg   tpi motor pics-img_20150627_181417.jpg   tpi motor pics-img_20150606_161507.jpg
Old Feb 19, 2016 | 10:40 PM
no new tires's Avatar
Car: 88 IROC-Z
Re: tpi motor pics
Whats you car run? ^^^
Old Feb 20, 2016 | 12:28 AM
Car: 1985 Z28
Re: tpi motor pics
Not sure yet. Haven't tracked it. Only about 1200 miles on the engine since I built it. Just got the tune finished up.
Old Apr 28, 2016 | 11:50 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Re: tpi motor pics
Here's my mostly stock 91 TPI. Cleaned up the engine bay and did so added color touches. The red plenum and dist. cover is a vinyl wrap.
Old Jul 19, 2017 | 03:32 PM
ScarabChris's Avatar
Re: tpi motor pics
May I ask where you got that intake plumbing?
Old Jul 23, 2017 | 09:01 AM
Re: tpi motor pics
Getting mine cleaned up. I got the car on 7/12 and moving right along. New exhaust system too.
This engine bay was pretty messy. I'm about 80% done with the clean up.
Old Jul 23, 2017 | 05:37 PM
Re: tpi motor pics
Improving daily....
Old Jul 23, 2017 | 07:42 PM
zya5point0's Avatar
Car: 87 IROC
Transmission: auto
Re: tpi motor pics
Old Jul 23, 2017 | 07:44 PM
ViperSpec's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Axle/Gears: 3.27 (Stock)
Re: tpi motor pics
This is how it sits now. FIRST TPI, Hooker 2055's into a full 3 inch exhaust minus the cat (previous owner removed it,) Flowmaster 80. CAI with a SU145 MAF. Runs nice, but you can tell the factory heads and cam don't work well with this intake and exhaust.
This is the pile I have been building up in preparation for my next upgrades. Jegs/Profiler 195 heads, Scorpion narrow body 1.6 RRs, Comp 268 XFI, 2400 stall FTI converter, Dynomax 3" in / dual 3" out muffler to replace the restrictive Flowmaster currently on the car and some nice new tips. All the stuff to finish my "LS1" front brake swap, including Earls SS lines for the whole car. Solid Motor mounts. Accel 300+, Racetronix fuel pump harness and an Aeromotive 340 Stealth to replace my ailing Walbro 255. I also have a set of UMI Sfc's ready to be installed when I get the chance. I am excited to get this stuff installed.
And yeah, My engine bay is well past due for a good cleaning. Been on a few gravel roads lately and it really shows lol.
Old Jul 24, 2017 | 07:33 AM
kaos420's Avatar
Car: 88 gta
Engine: 5.8
Axle/Gears: 3.73 POSI
Re: tpi motor pics
Attached Thumbnails tpi motor pics-13895379_1398216000194331_5412867287850631911_n.jpg
Old Jul 24, 2017 | 09:35 PM
Car: 88 IROC-Z
Re: tpi motor pics
How so?
Old Jul 24, 2017 | 09:39 PM
ViperSpec's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Re: tpi motor pics
How so?
It runs fine. Stronger than the stock TPI even. But seat of the pants feels like it is happier in an RPM range that the stock iron L98 heads and cam just can't support. Bit of a loss in off idle torque feel, good mid range push and you can tell it's better on the higher end but that's about when the heads and cam drop off. Something my new heads and cam will do much better with when they get installed.
Old Jul 24, 2017 | 10:26 PM
Car: 88 IROC-Z
Re: tpi motor pics
I too have a First intake (not on yet, gonna port and siamese the top half), my fully ported - partly siamese-ed tpi/SLP setup - I rev to 5500 (mhp and e.t. the whole way) and sometimes 5600.
I've got LTs and an open Y-pipe, the sound is LEGENDARY to say the least and leaves people worried and nervous. lol
-Procharger also in the works
Old Jul 24, 2017 | 10:37 PM
ViperSpec's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Re: tpi motor pics
I have been interested to see how the FIRST does with some boost. I am seriously considering going with a single turbo setup down the road as well. Thats a nice shine on that intake.
Old Jul 24, 2017 | 10:43 PM
Car: 88 IROC-Z
Re: tpi motor pics
Yep
Old Jul 25, 2017 | 03:16 PM
Jjmirocz's Avatar
Car: 88 Iroc Z
Engine: 350 (5.7L) TPI
Re: tpi motor pics
Old Jul 29, 2017 | 06:59 AM
KCG's Avatar
KCG
Car: 89 IROC
Re: tpi motor pics
Jj do you have a build thread?
I'm assuming not since this looks like your first post?
Old Jul 29, 2017 | 09:27 AM
Abubaca's Avatar
Re: tpi motor pics
Here's mine as of July 2017. It's changed a bit through the years! 383 with all the good stuff
...details are on the car's Facebook page in my sig below.
drewdock87
South Central
Aug 18, 2015 09:02 PM
mdtoren
Aug 16, 2015 05:45 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
