stainless works headers install
Car: 87 iroc z28
Engine: 5.3 under construction
Hello i having trouble installing the stainless headers. My driver side is perfectly fine a little tight but in. The passenger side is a whole other story. It seems to be stuck on the transmission flange/ dust shield. I already shaved roughly an 1/8th off it. Have any LSx swap guys run into this problem?
Car: 92RS
Engine: LS 402 inwork
Transmission: TH350
Axle/Gears: 10 bolt,3:73's
Re: stainless works headers install
If your speaking of the ear that sticks off the side on the passenger side, I just cut mine off with a cutoff wheel. Mine were hitting that spot only. My drivers side went in really easy with plenty of room. I'm using the 2" primary tube ones. I also have a tubular K-member so I have lots of room under there
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
I'm working on mine now I am installing a set of RI stainless headers and found the collector touching and tubes are extremely close to the right sub frame. No ear on my bell housing. On the left side pretty close to the fuel and brake lines. I am going to drop the engine back out of the car to reposition the brake line and remove the fuel lines in favor of a braided stainless line kit. Is it possible to slightly tweak the headers on the right side for the clearance needed from the sub frame?
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Thats a bummer I went with the headmans great fit
I just test installed a set of Speed Engineering headers on my '92 build. So far looks like they will be a good fit.
Not sure where they're made but I bought a set of Racing Innovations headers and the fit was horrible, poor construction, welds were really poor. Flanges looked like they were cut with a plasma cutter. Speed Engineering site says they manufacture them in Calif. I do know they fit well and quality appears very good.
