Third Gen. Orig. 500X447 power antenna
Old Nov 11, 2017 | 03:04 PM
George M's Avatar
I need the power antenna for my Camaro 87 like the one pictured.
Do you have one?
let me know.
George
bigbearblack@live.com
Old Nov 11, 2017 | 05:46 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: Third Gen. Orig. 500X447 power antenna
What picture?
Old Nov 11, 2017 | 09:06 PM
George M's Avatar
Re: ThirdGen. Orig. 500X447 power antenna
This one here. Power Antenna for 1987 Iroc Z Camaro
Old Nov 11, 2017 | 10:23 PM
red rock's Avatar
Car: 1987 iroc
Do you have your old one? Aftermarket is the only replacement, unless someone has a good used one on here. They are repairable with a new mast if the motor still works. Relay needs to be checked under the dash. Just helpful information unless you checked it already.
Old Nov 12, 2017 | 01:23 AM
George M's Avatar
Thank you red rock.
I have removed it and replace it with one from an '89 model camaro and that only lasted 2 weeks as it was also old and worn I guess. I had to cut that one out as it jammed extended. No other way to get it out.
I replaced the original and operate it manually, pulling it up and down getting out of the car each time.The mast is OK and motor works and now disconnected; its the flex rod mechanism on the inside that is broken.
Who would be an expert to refurbish that?
Old Nov 12, 2017 | 09:24 AM
red rock's Avatar
Car: 1987 iroc
The mast and nylon cog strip (that's what makes it move up and down) come as a unit and is totally replaceable and is a common repair. That's all that needed replacing on mine. This is just one example, they are getting harder to find. https://www.classicindustries.com/product/g4825.html You may find them cheaper with some research.
Old Nov 12, 2017 | 09:59 AM
red rock's Avatar
Car: 1987 iroc
Read through, especially the last few pages as they are more current. https://www.thirdgen.org/forums/hist...ld-thread.html
Old Nov 12, 2017 | 11:42 AM
George M's Avatar
Thank you again red rock.
After reading 100 or so posts on the thread, I think I will live with my original power antenna / manually operated each time the radio is turned on.
Old Nov 12, 2017 | 03:49 PM
red rock's Avatar
Car: 1987 iroc
It really isn't that hard to rebuild them. But feel free to do what you want.
Old Nov 12, 2017 | 04:13 PM
I had this gentlemen rebuild mine. This info is several years old, but contact him if you'd like.
Old Nov 21, 2017 | 05:05 PM
82tarecaro's Avatar
I replaced the nylon cable with a stainless steel cable. The nylon replacements will break again. Been there, done that.
Old Nov 21, 2017 | 07:42 PM
82tarecaro's Avatar
There is one on Ebay
https://www.ebay.com/itm/NOS-1978-19...RaE5qj&vxp=mtr
Old Nov 21, 2017 | 07:50 PM
red rock's Avatar
Car: 1987 iroc
How did you do that? The nylon one has teeth that run it up and down.
Old Nov 21, 2017 | 08:09 PM
82tarecaro's Avatar
Hmm... not on my 82. It was just a round nylon cable.
Linson
Oct 26, 2016 05:42 PM
rommel1940
Sep 30, 2016 01:45 PM
rommel1940
Sep 28, 2016 03:37 PM
retro-roco
Sep 11, 2016 01:46 PM
Linson
Mar 3, 2015 08:15 PM
