Pictures of Driver's Side Rear Brake Line Needed!
Old Nov 12, 2017 | 03:30 PM
ottothesilent's Avatar
Hi, I've been doing work on my 88 TA, and I noticed something.......odd. By "odd", I mean "The previous owner had a cranium full of gravel". Turns out, the brake line to the driver's side rear caliper is HARD LINED, instead of having the hard line leading to a rubber tube, as is SAFE AND OPERABLE. Anyhow, in reconstructing my poor, victimized brakes, I'd like to see if any of you could provide a picture of the end of the brake line leading to the driver's side rear caliper, where the hard line attaches to the soft line, so that I can rebuild this the proper way.
Any help is greatly appreciated!
Old Nov 12, 2017 | 05:07 PM
Re: Pictures of Driver's Side Rear Brake Line Needed!
That's normal, and how the Delco Moraine rear calipers were plumbed.
Old Nov 13, 2017 | 10:33 AM
jkris53406's Avatar
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
What Drew said
Old Nov 13, 2017 | 02:13 PM
Well, my passenger rear caliper has a soft line (about 6" long) leading from the hard line to the caliper. The driver's side is just plumbed directly into the caliper, and is obviously hacked together.
Old Nov 13, 2017 | 02:40 PM
jkris53406's Avatar
That is the way GM pumped them out of the factory. The Driver side was hard lined from the tee but the passenger for some reason had a hose from the caliper. This is not hacked together, it is from the factory. Try looking up a brake hose for it and you will only get the center hose and the and the passenger.
Old Nov 13, 2017 | 02:45 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
That is the way GM pumped them out of the factory. It's correct....for the 4th time
Old Nov 13, 2017 | 03:31 PM
Can someone provide pictures so that I can compare an absolutely correct example to my own car? I realize my poor explanation may be frustrating, so before I **** anyone else off, I'd like to close this topic with a definitive, non-verbal example. I really respect everyone on here, so I'd like to avoid burning any bridges with this helpful community.
Old Nov 14, 2017 | 09:38 AM
gt4373's Avatar
Transmission: 5-Speed Manual
Was Working Under The Car Yesterday,Took A Couple Pics The Hard Brake Line Comes Down From The Axle,Does A 180 And Bolts To The Caliper.
Old Nov 14, 2017 | 11:29 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
I was going to take a picture of my TTA rear brake line till I seen it has the hose. 1LE brakes are different. My GTA was in storage so I couldn't get a picture of it either.
Old Nov 14, 2017 | 11:54 AM
jworks's Avatar
Car: 1987 Trans am GTA
Engine: 5.7 liter
original hard line to driver side
this is a pic of my original driver side brake line next to a new one. for some reason a hard line to the rear driver side delco moraine is correct
Old Nov 14, 2017 | 02:26 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
Stock 9bolt
Old Nov 14, 2017 | 02:28 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Mark Williams 12 bolt:
Old Nov 14, 2017 | 07:03 PM
Thanks very much, and thanks for your patience!
Old Dec 10, 2017 | 07:27 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Should you require more info on thirdgen braking systems, the following sticky will provide many answers.
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
