Just picked up another thirdgen! #4 is a 92 Z28, 1 owner!
Old Jan 5, 2018 | 09:07 PM
themagicisback2's Avatar
Car: 2008 Range Rover Sport Supercharged
Engine: 4.4L V8 Supercharged
Hey guys! I just got a 1992 Z28 with the 5.7 350. Its been sitting in a garage for over 14 years! 1 owner with 106,000 original miles! All the fluids look surprisingly Good! I put some fresh fuel and a battery and she turns but won't fire! I ran out of daylight and wont have time to work on it over the next few days. AGHHH! 😓
I'll run through the basic checks to see if I got fuel and spark and we'll go from there! Stay tuned cause I may be back with questions or hopefully a running Z28!
Old Jan 6, 2018 | 07:29 AM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Re: Just picked up another thirdgen! #4 is a 92 Z28, 1 owner!
Nice but you know how we like pictures!
Old Jan 6, 2018 | 08:19 AM
Blackwoodz's Avatar
First thing with a car that's been sitting that long is fuel....check your lines...filter and pump for pressure.
No trap doors.... Lol
Old Jan 6, 2018 | 08:43 AM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Old Jan 6, 2018 | 11:37 AM
Old Jan 6, 2018 | 12:54 PM
gm muscle's Avatar
Car: '89 Iroc-Z
Engine: 5.7 TPI
Axle/Gears: 2.77
Congratulations! Pictures or it didn't happen...
Edit...oops!
Old Jan 6, 2018 | 01:05 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
So this is your new drift car right
Old Jan 6, 2018 | 06:23 PM
@Pro I'm old school. Lol! I'll be leaving it fairly original.
Old Jan 6, 2018 | 09:03 PM
cardo0's Avatar
Car: Fourth Gen '94 camaro
Engine: 350 Gen II
Transmission: A4
Cool! Nice straight looking body. Hope you have fun with it.
Old Jan 7, 2018 | 08:37 AM
Vader's Avatar
Should be an interesting resto. Apparently it either got running or it pushes/pulls easily.
Old Jan 7, 2018 | 01:11 PM
GOOD NEWS! The Z28 fired with the help of some starting fluid. It ran for a few seconds and died. Here's a few more pics.
Old Jan 8, 2018 | 06:44 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Nice but dont run it for too long, who knows what kind of crap is inside. Crappy gas, old oil, and in my case a dumb hypertech chip requiring premium that i didnt know about and i had been running regular for a year. So a full inspection is needed right
Old Jan 9, 2018 | 09:22 PM
UltRoadWarrior9's Avatar
Car: 1986 IROC Z-28
Engine: 383 Gen I SBC 11:1
Transmission: Rebuilt TH700R4 for 500+HP
Axle/Gears: 4th Gen 10 bolt Eaton Truetrac 3.23
To Mod or Not to Mod?
Old Jan 9, 2018 | 10:04 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
I just noticed the black valve covers.
Whats with the black covers.
Some had some didnt.
Old Jan 16, 2018 | 09:53 PM
@ultroadwarrior9; Not modding this one. Lol!
@pro; I didn't see that until you mentioned it. I'm not really sure.
Quick update! Tested the fuel pressure from the fuel rail and got nothing. 0 psi. No fuel pressure. It doesn't sound like the fuel pump is clicking on or pumping. Pulled the fuel filter and tried blowing through it. It was CLOGGED up! Looks like I'll be dropping the tank and giving it a good cleaning. Ordered the fuel pump and sending unit.
Old Jan 16, 2018 | 10:48 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
You may want to test the connection at the pump relay first, then work your way back to the pump. It could be a broken wire eaten up by a rat and not a dead pump, and replacing a good pump with a good pump is a waste of time.
Old Feb 1, 2018 | 06:50 PM
Today, I got the tank out. Check out this old mess! Sorry for the blurry pic. I believe this is part of the no fuel issues! Lol!
Old Feb 1, 2018 | 07:32 PM
Community Influencer
I’m sure the injectors look beautiful too lol
Old Feb 7, 2018 | 12:18 PM
I got a fuel tank from a donor 1991 Firebird and put a new sending unit/fuel pump in it. Got it in place and mounted the straps and then noticed the filler neck doesn't line up with the gas tank lid. (See pic) I ran out of time and I'll get back to it on Friday. Any quick suggestions before I start again on Friday?
Old Feb 7, 2018 | 12:24 PM
The flexi-straw looking part of the filler neck where it meets the tank is probably tweaked. Remove the tank and tweak it back. When you find the right position, clean and solder the joint between the filler neck and the tank.
That era of thirdgen tank is commonly afflicted with pin holes in the soldered joint. Some are so bad that they leaked when filled to capacity. Plenty were replaced under recall. Best to make sure it's sealed while you have the tank out.
Old Feb 7, 2018 | 12:39 PM
The alternate lazy-mans method is to just reach in there, and pull it into position. It works, it's just a bit sloppy. Use your best judgement.
Old Feb 9, 2018 | 09:58 PM
GREAT NEWS! I got the camaro running today! She lives after 14 years of hibernation. Thanks everybody! Now, on to the smaller things. Cheehoo!
Old Feb 10, 2018 | 07:42 AM
SirReveller's Avatar
Car: '89 'ROC
Engine: 5.7L
Rockin!
Old Feb 10, 2018 | 01:39 PM
irocwagon's Avatar
Car: camaro84.87iroc,91vert
Engine: Lt1, 383tpi,350tbi
Transmission: t56,T5,T5
Axle/Gears: 4thgenunknown,373,323?
Everybody knows we love somebody pics
Old Feb 13, 2018 | 05:28 PM
Passed the Colorado emissions test and got it all legal! Another back on the road!
Old Feb 13, 2018 | 05:45 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
That looks good. So what are next plans
Old Feb 13, 2018 | 06:02 PM
Thanks Pro! The next plans are probably sell it. I'd love to keep it but I bought it as a little investment project. If I do hang on to it, I'll get a new windshield and new top dash pad. It just hit 107,000 miles today!
85IROCzzz
Members Camaros
Aug 22, 2011 02:21 PM
jkris53406
Exterior Parts for Sale
Apr 4, 2011 01:09 PM
toolegit86
Aug 12, 2010 01:54 PM
chcgobearsfan3
May 21, 2010 06:44 PM
Ninetails
May 1, 2004 01:12 AM
