Edit Fan ON/OFF Temperatures
Old Apr 25, 2018 | 02:48 PM
J.C. Denton's Avatar
Car: 85 Iron Duke, 88 GTA and 92 TA
Hi,
I want my fan(s) to come on earlier. I am runnig an AXXF.bin with $8D.xdf for my 91 LB9. I have a stationary Moates Ostrich 2 in my car connected to my 7730 ECM, so I can edit my bin and upload it to the Ostrich within seconds. But I can't find the Scalar for editing the Fan ON/OFF temperatures in TunerPro. Am I blind?
I have the stock dual fan setup WITH working A/C.
I just found a line in the "Tables/Functions" that says "Fan On/Off Coolant Temp Thresholds" but I don't know how to set these values.
I had a V6 LH0 before, in that bin I was able to change the on and off temperatures in the Constants/Scalars.
Isn't that possible here?
Please help me, I am a little bit confused.
Old Apr 25, 2018 | 05:32 PM
ULTM8Z's Avatar
Re: Edit Fan ON/OFF Temperatures
It's no different here. Just set the temperature you want the fan to come on and go off.
Note there is no fan 2 for Camaros. The fan 2 is controlled by a separate temperatrue switch, not the ECM.
what thermostat do you have?
Old Apr 26, 2018 | 01:50 PM
Thank you for your answer.
I am a bit confused by the name of the tables. Why is there a table "Fan" with 151,25 and a table "Off" also with the value 151,25? And then the table "1" with 107,75 and the table "Fan" again with 104,75? Which value do I have to change? Don't want to do anything wrong here... still a newbie in .bin editing.
I have the dual fan setup, the second fan is controlled by the switch in the passenger cylinder head, is that correct? I don't need to change this, I think the first fan on at about 97°C would be enough.
I have a fresh ACDELCO 12TP1D 180°F Thermostat, opens a little bit earlier.
Old Apr 26, 2018 | 02:53 PM
Community Influencer
The secondary fan can be wired and programmed in .
Just Incase you can’t read the ecm pins they are e8 & d12 .
Old Apr 26, 2018 | 04:25 PM
ULTM8Z's Avatar
Maybe set it 5 set over your thermostat temp.
Old Apr 26, 2018 | 04:27 PM
ULTM8Z's Avatar
Yeah I did that. It's not hard to do... Just a pain to route the wire.
Old Apr 27, 2018 | 05:31 PM
But how? What is meant by the four temperatures? Sorry fo being so dumb, but I don't understand the table. Which values do I have to edit for on and off and why are there four values? Can you enlighten me?
Old Apr 27, 2018 | 05:40 PM
ULTM8Z's Avatar
Oh I see what's going on... the table entries are kinda strange yeah... no wonder you're confused! lol...
Ok, so ignore the top two entries that are saying 151.25. Those are for Fan 2 (and for that matter, should be labeld Fan 2 On and Fan 2 Off). Your ECM does not control Fan2, so again, ignore those.
On the bottom two entries, the top one that says 107.75 should be labeled Fan 1 On. The one that shows 104.75 should say Fan 1 Off.
Not sure why the xdf file has them labeled like that.
Any rate, the temps are in °C... With my 180F T-stat, I have mine set to come on at 190F (88C) and go off at 180F (82C). My huge Ford Taurus fan that I swapped in has the capability to cool the engine down past the T-stat temperature... lol... so I keep it at or above the T-stat temp.
Old Apr 27, 2018 | 06:24 PM
Thank you very much! That makes sense... I didn't think about the secondary fan, but that makes sense. It is maxed out because it is controlled by the A/C and the switch in the passenger head.
Thanks again!
urcuddleboy
Aug 11, 2002 08:21 PM
Amrish
Jul 22, 2002 03:11 PM
John'89L98
May 21, 2002 05:07 PM
Momar
Dec 24, 2001 11:41 PM
FastElectrics
Mar 19, 2001 08:11 PM
