READ ME! Before asking "Is my car rare/Desirable?"
Old Aug 1, 2017 | 11:00 PM
  #551
IMissMy86TA's Avatar
Car: 1991 Trans Am Vert
Engine: 5.0 TPI
Transmission: T-5 baby
Re: READ ME! Before asking "Is my car rare/Desirable?"
Originally Posted by tdboy362736
My first car was an 85 S/E with the Recaro seats. What is the best way to go about trying to locate it (or another like it)?
search on the "for sale" group on this forum?
Old Aug 3, 2017 | 01:15 PM
  #552
GTA1990's Avatar
Car: 1991 Trans Am
Engine: L31, LT4 hot cam
Axle/Gears: 3:42 LSD
Originally Posted by PurelyPMD
You are right - very odd.
55 Z28's in the same configuration.
I suppose the 5.0TPI Manual R6P firebirds could be had with T-tops for the 91-92 model year where as the equivalent G92 Camaro's were somewhat more restrictive with getting T-tops I understand
hmm...
Old Aug 5, 2017 | 09:19 PM
  #553
G92-Z28's Avatar
Car: 91 Z28
Transmission: 5 Speed
Axle/Gears: G92 (3.42)
So this may be a dumb question but where should I look to decode all of my rpo codes? I have a g92 91 camaro. I know it has dual cats and 3.42 gears it doesn't have rear discs. Any info on where I can find what all my rpo codes are would be great!
Old Aug 5, 2017 | 09:27 PM
  #554
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Originally Posted by GTA1990
thanks. Interesting; about ten times more than the equivalent camaro
I am not sure, I cannot look it up, the 5 Speed Trans Am's with T-tops did they all come with the 3.42 or did some come with the 3.08. The Camaro was NA with the 3.42 gear and T-tops IIRC from 1990-1992.
Old Aug 5, 2017 | 09:28 PM
  #555
okfoz's Avatar
Try starting a new thread...
Old Aug 6, 2017 | 12:10 AM
  #556
1992 Trans Am's Avatar
Engine: 5.0L 305ci TPI
Axle/Gears: 3.08
See below
Just google the search term GM rpo decoder and you'll see lots of printed lists of what each of your rpo's mean buildwise.
Old Aug 6, 2017 | 03:54 PM
  #557
GTA1990's Avatar
Car: 1991 Trans Am
thanks. Does make one think about why GM would hold back on the Camaro but not the Firebird (wrt the rear end and t-tops combination). I get the sense that GM restricted drivetrain/ t-top combinations solely because of EPA and car weight; and like-for-like, the firebird was heavier I understand.
Old Aug 15, 2017 | 10:54 AM
  #558
lugnut's Avatar
Car: 1970 chevelle
Engine: Lq4 408
Transmission: th400
Axle/Gears: 3:73
Im not really concerned about rarity justwould like to know about a iroc with camaro emblems instead of iroc on rockers also the rear says camaro not tuned port injection i plan on selling the car just wanted to verify Heres a VIN pic
Attached Thumbnails READ ME! Before asking "Is my car rare/Desirable?"-20170815_074458.jpg
Old Aug 15, 2017 | 11:15 AM
  #559
yo soy el warg's Avatar
Looks like you have a 1990 IROC which was the lowest production year with the 350 engine, N10 duel exhaust, G92 performance gears, and many other nice options according to your RPO list. I would say that at some time somebody replaced the IROC emblems with the Camaro ones. It is an IROC.
Old Aug 15, 2017 | 01:13 PM
  #560
okfoz's Avatar
Please start a new thread... this is just cluttering up this one. Not sure how this pertains to the original post, apparently forgot to read it.
Old Sep 28, 2017 | 07:16 PM
  #561
dragsta's Avatar
Car: 86 WS6 5sp TA
Transmission: 5sp
Axle/Gears: posi
ok, i have a 1986, Trans Am, WS6, 305 4bbl, 5sp. i'm thinking that this was an unusual combination. how do i find out how many were made in this configuration?
Old Sep 29, 2017 | 10:39 AM
  #562
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
48,870 Trans Am's built in 1986 - other than the L69 which are like hens teeth, that would be the top motor available with a 5spd. I doubt it's rare - likely in the high 4 digit, low 5 digit range.
Old Oct 5, 2017 | 09:03 AM
  #563
okfoz's Avatar
Although I do not recall ever seeing another, There is no way to tell how many were made. Unlike the later years where we can figure out how many 5 speeds were made with TPI based upon the RPO codes 1986 poses a problem doing so. The good thing is the V6 uses a slightly different manual trans than the V8, the gearing ratios I think are different, for later years the Manual trans for the V6 is MD8 the V8 TBI or TPI is M39 and the TPI W/G92 was MK6. Unfortunately GM purged the data for 82-89 F-bodies so without that getting those specific numbers is virtually impossible at this point
I can tell you that there were 16,640 Manual Transmissions in Firebirds in 1986, no further breakdown is available. This would have been between the V6 and the LG4 V8, and could have been installed in a Base Firebird, S/E or Trans Am.
John
Old Jan 29, 2018 | 05:34 PM
  #564
mcsilver's Avatar
Hello John and Forum Followers,
I read all 12 pages, and my brain is threatening to shutdown from info overload. Yet, I didn't come across what I was hoping to find. So, I hope that allows me to ask the following......
I'm on an info search to gather the number of LB9-powered cars built 1985-92. It appeals to me this engine is an under-rated hero.....TPI (all years), aluminum heads (most years), roller lifters (most years), and only available in higher end F-Bodies......and the top rated Gen III F-Body engine available with a m/t. I suspect build data will show it to be in the top three of the best selling specs ever of performance Gen I Chevy small blocks.
The nastyz28 website seems to give all the Camaro LB9 build numbers year-by-year, can anyone assure me those are reliable stats? I haven't found a GEN III Firebird friendly site yet for build numbers. I've talked to my librarian about borrowing a Camaro White Book by interlibrary loan, but there are no such copies in the Canadian system.
Any help on LB9-powered car build numbers would be greatly appreciated.
Tx, Kellen
Old Jan 29, 2018 | 08:39 PM
  #565
Big&BadGTA's Avatar
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
Tx, Kellen
Welcome to the site.
LB9 was Iron head 305. None w/ factory alumn. heads. Same w/ all other TPI 5.0 and 5.7L cars.
Only "RPO" V8 to get alumni heads was done by 2nd stage builder, SLP on the 91/92 Firehawk under RPO B4U.
Old Jan 29, 2018 | 10:14 PM
  #566
mcsilver's Avatar
Thanks for reply Big & Bad GTA. It sent me off reading as to how I thought F-bodies had aluminum heads in some years. Results, Aluminum Corvette heads in most years L98, but not in F-Bodies. LB9 something of a smaller L98, but a Camaro L98, not a Corvette L98. Point taken.
My quest is still to put together LB9-powered build total, as in the original post. Anyone have data or internet leads to same?
K
Old Jan 29, 2018 | 11:02 PM
  #567
Big&BadGTA's Avatar
Glad to help.
Mid 86-1991 L98 Corvettes got alumn heads w smaller chambers. 58cc vs 64cc
For f body iron version.
Old Jan 31, 2018 | 10:26 AM
  #568
okfoz's Avatar
You're Welcome. I like making people's head explode.
The aluminmum heads were covered, so I will not talk about those.
The Roller cam started in 1987 and lasted through 1992. The 1 piece rear main seal on the block started in 1986, and the center bolt valve covers started in 1987. The Serpentine belt started in 1988.
Tx, Kellen
Firebird:
85 16869 PHS
86 21176 PHS
87 16333 PHS
88 10379 PHS
89 6478 PHS
90 2570 PHS - Confirmed
91 548 (Conv) 5346 (coupe) (Comp Nine) +10% maybe
92 616 (conv) & 750 (Coupe) (Comp Nine) +10% maybe
Camaro (all from White Book)
85 32836
86 46374
87 28370
88 12620
89 8925
90 3092
91 9996
92 4002
Old May 21, 2018 | 09:19 PM
  #569
Bow_Tied's Avatar
Car: 1987 IROC-Z
Engine: L98 5.7L
Transmission: MD8 700R4
Axle/Gears: G80 GW6 3.27:1
To bring this all into perspective there were 1,517,623 Camaro's and 817,444 Firebirds made between 1982 & 1992. OR if you add them together 2,334,067 3rd Gen F-bodies...
Apologies if I missed seeing this reported..
Looking at the Tech Data Section for each of the years listed on this site (such as https://www.thirdgen.org/1982-chevy-camaro/) etc., I found these totals for Camaro (I didn't look at Firebird):
1982 189,747
1983 154,831
1984 261,591
1985 180,018
1986 192,219
1987 137,760
1988 96,275
1989 110,739
1990 34,896
1991 100,838
1992 70,007
Total: 1,528,921
Which is about 11k higher than the grand total noted in the post quote - just curious if the discrepancy was known and if it was accounted for?
Old May 22, 2018 | 01:03 PM
  #570
okfoz's Avatar
Different sources have different production numbers. I am not sure why...
There are some transposed numbers... I am not sure who is right...
Here is from dealer information: The information you gave is from the White book... It like any other source has some errors, as do my sources.
Camaro
82 - 178,808 Alternate: ( "L" Van Nuys 121,512, "N" Norwood 68,223 = 189,735)
83 - 154,381 Alternate ( L 68,810, N 85,571 = 154,381)
84 - 261,592 Alternate ( L 100,729, N 160,862 = 261,591)
85 - 180,018
86 - 192,219
87 - 137,760
88 - 96,275
89 - 110,739
90 - 34,896
91 - 100,838
92 - 70,707
Regardless, the fact remains there was about 2.3 Million 3rd gens
Old May 22, 2018 | 03:11 PM
  #571
The errors in the exact number illustrate the futility of trying to mathematically determine rarity of a thirdgen. Fact of the matter is the numbers only give you a general guideline and no one knows exactly how truly accurate they are. Aside from trivia they have little value.
Old May 24, 2018 | 08:50 PM
  #572
Bow_Tied's Avatar
Car: 1987 IROC-Z
Engine: L98 5.7L
Thanks for the alternate numbers, okfoz.
I agree it's trivial. It was just a curiosity.
Old May 25, 2018 | 02:37 PM
  #573
Bounty600's Avatar
Engine: 5.7L V8
So, does anyone know the whereabouts of that 1 1989 RPO coded AA8 Notchback GTA & is it safe to assume that it would be both rare and valuable regardless of LB9 or L98?
Old May 25, 2018 | 03:27 PM
  #574
okfoz's Avatar
From my understanding, there was actually more than 1 AA8 RPO in 1989, JT has a list apparently. But only one car got the actual hatch, the others just got the RPO. I want to think there was 11 or something that went to Canada...
Old May 25, 2018 | 05:09 PM
  #575
Bounty600's Avatar
Engine: 5.7L V8
I found what seems to be that unicorn earlier today and it was for sale, but its RPO code in the center console is missing.... any other way to validate that it is in fact the AA8?
Old May 25, 2018 | 05:37 PM
  #576
Rare? Sure. Valuable? Uhhhhh..... Maybe?
Old May 25, 2018 | 10:39 PM
  #577
okfoz's Avatar
The missing RPO sheet is convenient. For the owner that is. Chances are it is an 89 with the hatch. Make sure it is not an aftermarket hatch, I know some companies out there make similar hatches.
John
Old May 26, 2018 | 10:09 AM
  #578
Bounty600's Avatar
Engine: 5.7L V8
John
Agreed,
Thing is the guy who owns it isn't a pontiac guy, he's in the military and selling bc he wants to go back to carbed chevelles. Tells me he's owned it 6 months. It's clean, but not perfect. It's priced around 6800, which for the mileage and condition is more than reasonable. My only real hang up is that the RPO codes are gone. If it were there and I could validate it I'd be driving her home as we speak.
The guy has no real vehicle history, is there a tell tale for the hatch to not be original?
Attached Thumbnails READ ME! Before asking "Is my car rare/Desirable?"-33385272_2080593051969320_255724045020954624_n.jpg   READ ME! Before asking "Is my car rare/Desirable?"-33584471_2080593091969316_2318189494001467392_n.jpg
Old May 26, 2018 | 12:36 PM
  #579
I own a 1988 GTA notchback and the genuine rear hatches have the ridge down the middle of it like the one your looking at has. The after market ones I've seen don't have that center ridge. They also don't have the plastic trim under the hatch like this one does. I would say this car has a genuine factory hatch and interior trim. What this car doesn't have are the rear seats that only the GTA Notchbacks came with. The notch back has two tall head rests on it's back seat which are unique to them.
Old May 26, 2018 | 09:40 PM
  #580
I did not know that. Good info.
Old May 29, 2018 | 04:09 PM
  #581
okfoz's Avatar
I forgot about the special Back seats... They are also the same back seats as the TTA If I remember Correctly.
So, from this information, it is an 89 GTA, with an 88 Notchback on it. Probably got it from a junkyard, painted or maybe it was the right color...
John
Old May 29, 2018 | 05:36 PM
  #582
John
Your right about the TTA having the same seats in the rear. I have heard that too, but never seen one in person.
Seems like they had a use for the seats on the TTA that were left over when the Notchbacks were discontinued after a one year run. GM likes to recycle all the parts that they can.
Old May 29, 2018 | 08:46 PM
  #583
Fiero spoiler too.
Old May 29, 2018 | 09:13 PM
  #584
JT's Avatar
JT
Community Administrator
There are several 1989 GTAs with the Notchback code that went to Canada. Without seeing the cars in person, it's not 100% if they had the hatch or just the code. However, pulling a few invoices for them confirms the option and extra cost to the car for the option. That suggests to me they did come with the hatch. Unless there was some sort of credit after the invoice.
Old May 29, 2018 | 10:23 PM
  #585
okfoz's Avatar
I do not think they were "left over" per-se. With any part, the cost of the tool diminishes with the number of parts produced with the tool. Therefore I suspect that the TTAs used the back seats in order to justify the tooling cost for the part, and to make the car more special than just an engine transplant, some emblems and stickers. Keep in mind that all TTAs came with the tan interior, so the parts would have to be made for each car... As someone that is in production, When an order was placed for a vehicle, the parts that it needed for the assembly would have also been ordered. There are several parts that would have been off the shelf parts, IE suspension pieces, or windows, doors, hoods, hatches. But any of the parts that were to go onto any car would have to be ordered and shipped to the assembly plant. I do not think there was a pile of special cloth back seats sitting at Van Nuys waiting to be installed into a TTA, rather, the part was ordered, and then when everything was at the factory ready to be installed they put that car together. There may be over runs or extras that were on hand just in case of damage but I am not even sure about that. When I was at the GM employee reunion at Norwood I remember asking or someone asking about what happened if a part was not available for the car, they said there was a special place they would put the car if something was missing until the part came in or was available.
Sorry for the ramble.
John
John
Old May 30, 2018 | 07:14 AM
  #586
PurelyPMD's Avatar
That doesn't seem to be a bad price for a decent car with such an unusual option.
Old May 30, 2018 | 09:30 AM
  #587
John
John
I like your rambling. It usually gives me information I've never read elsewhere. I'm not very familiar with the TTA and also didn't know that they only had a tan interior in them. Thanks for the info.
Old Aug 21, 2018 | 03:54 PM
  #588
Tim Mariano's Avatar
Car: 1987 gta
Engine: 305 tpi
Transmission: 5 speed
Axle/Gears: 3.45
what about my 1987 gta m5 paddle mirror car ? 1987 5 speed paddle mirror gta
Old Aug 21, 2018 | 04:39 PM
  #589
okfoz's Avatar
They are a novelty, honestly I would not buy one just to get the mirror option. I think they were dropped because they were unpopular more than anything
Old Aug 24, 2018 | 10:20 AM
  #590
Engine: 5.0 TPI
I wouldn't buy it just for the mirror option but it is a nice to have and is desired among GTA fans. I wish mine had had it but it was a short run feature
Old Aug 24, 2018 | 10:24 AM
  #591
okfoz's Avatar
They are neat, do not take me wrong. Actually they were a short run feature in the Domestic markets only... The Mirrors were used on F-body European export models until 1992 IIRC due to their breakaway collapse capability...
Old Sep 6, 2018 | 05:10 PM
  #592
jeffas000073's Avatar
Car: 1991 Pontiac Firebird Trans Am
Engine: 5.7L TPI
Transmission: 4 speed 4L60/700R4
Is there a website out there where I could just plug in my VIN (1G2FW2387ML210240) to determine production numbers of a given model with certain RPO codes? I've got a 1991 Trans Am, Blue, Grey interior, 5.7L. Just curious.
Old Sep 7, 2018 | 10:25 AM
  #593
okfoz's Avatar
You mean like this?
1G2FW2387ML210240
Vehicle:
FIREBIRD 2 DR
Year:
1991
Build Date:
1990-04-26
Found 47,612 vehicles matching that year and model in our database.
RPODescriptionMatches
UB3 CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER)(USED WITH DELUXE SPORT PKG W32) GA(UB3)47,612
UM6 RADIO,AM/FM STEREO,CASSETTE,ETR,INCLUDES CLOCK STEREO CASSETTE(UM6) 17,942
UQ1 RADIO,PROVISIONS FOR STEREO STEREO RDO PR0VISIONS(UQ1)47,612
U62 SPEAKER SYSTEM,4,DUAL COAX FRONT,DUAL COAX PACKAGE SHELF 4 SPKR SYS(U62)47,612
U75 ANTENNA,POWER(CHROME) PWR ANT(EXPORT)(U75)18,779
VAN PLANT CODE VAN NUYS, CA, CPC VAN NUYS,CA PLANT CODE(VAN)47,612
VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3)37,477
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)44,388
WDV WARRANTY WAIVER - PARTIAL DEDUCTIBLE1,972WS4TRANS AM(MERCHANDISING OPTION)(2FS87 + WS4 = 2FW87) TRANS AM(WS4)6,182
WS6 PERFORMANCE PACKAGE,SPECIAL(MERCHANDISING OPTION) SPECIAL PERFORMANCE PKG(WS6)10,360
Y83 TRANS AM PACKAGE(MERCHANDISING OPTION) TRANS AM(Y83)3,313
1SC PACKAGE-OPTION 03 (1SC)24,56918PWHEEL COLOR,CHARCOAL METALLIC (18P)37,994
24Q MOLDING COLOR,BRIGHT BLUE METALLIC (24Q)3,023
6ZX SPRING COMPTR SELECT FRT LH SUSP(6ZX)3,843
7ZX SPRING COMPTR SELECT FRT RH SUSP(7ZX)3,843
8NL SPRING-COMPTR SELECT RR LH SUSP(8NL)11,102
82C TRIM COMBINATION,CLOTH,MEDIUM DARK GRAY (82C)31,438
82I INTERIOR TRIM,MEDIUM DARK GRAY (82I)31,861829SEAT BELT COLOR - MED DK GRAY (829)31,8619NLSPRING-COMPTR SELECT RR RH SUSP(9NL)11,10298UEXTERIOR COLOR,PRIMARY,BLACK SAPPHIRE METALLIC (98U)3,092AAAUnknown46,052AH3ADJUSTER,SEAT,4-WAY MANUAL,DRIVER 4-WAY MAN D/SEAT ADJR(AH3)13,751AJ3RESTRAINT SYSTEM,FRONT SEAT INFLATABLE DRIVER SI INFL RST SYS(AJ3)47,612AR9SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST,DELUXE(AR9)44,743AU3LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3)41,671A31WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31)41,671A90LOCK,REAR COMPARTMENT LID,REMOTE CONTROL,ELECTRIC RELEASE ELEC REL LID LK(A90)28,389BC8ORNAMENTATION,INTERIOR,FRONT DOOR MAP POCKET RH AND LH DR MAP PKT(BC8)41,671B2LENGINE PACKAGE-V8 5.7L, PFI ENG PKG(B2L)3,489B84ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING(USED WITH APPEARANCE PACKAGE Z12) BODY SI MLDG(B84)46,790C49DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49)33,076C60AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60)46,946DC4MIRROR,INSIDE,REARVIEW TILT,DUAL READING LAMP I/S DUAL READING LP RR VIEW MIR(DC4)46,761DG7MIRROR,OUTSIDE,RH AND LH REMOTE CONTROL,ELECTRIC(PAINTED)(USED WITH SE Z7M,STE Z7N,LE Z7K) O/S ELEC R/CON PAINTED MIR(DG7)27,108D42COVER,REAR COMPARTMENT SECURITY(SHADE) R/CMPT SECURITY SHADE(D42)25,346D5XGEAR-SPEEDO DRIVEN (D5X)3,489D8FSENSOR (D8F)1,221D81SPOILER,REAR,AERO WING RR AERO WING SPLR(D81)13,733E5ZADAPTER - SPEEDO - DELETE47,612E9ZKEY - SPEEDO - DELETE47,612FE2SUSPENSION SYSTEM,RIDE AND HANDLING(USED WITH PERFORMANCE PACKAGE WS6) RIDE & HANDLING SUSP(FE2)10,360GU5AXLE,REAR,3.23 RATIO 3.23R(GU5)26,461G80AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)9,171IPCTRIM,INTERIOR DESIGN (IPC)44,743JG1SHAFT,PROPELLER(ALUMINUM) AL PROP SHF(JG1)4,548J65BRAKE SYSTEM,POWER,FRONT AND REAR DISC 4-WHL DISC BRK(J65)3,474KC4COOLING SYSTEM,ENGINE OIL(EXPORT-IRAQ) KC4(EXPORT IRAQ)4,569K34CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)30,237K68GENERATOR,105 AMPERE 105 AMP(K68)8,835L98ENGINE, 5.7L, (5.7-8) 350 CID, V8, TPI 5.7-8(L98)3,489MD8TRANSMISSION,AUTOMATIC 4-SPEED(THM700R4/4L60) 4-SPD A/TRANS(MD8)43,399MX0TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION)(MD8) A/TRANS PROVISIONS(MX0)43,399NA5EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5)43,196NP5STEERING WHEEL,SPORT,3-SPOKE,LEATHER WRAPPED(USED WITH PERFORMANCE PACKAGE Y56,SPORT PACKAGE WN2) LEATHER WRAPPED STRG WHL(NP5)6,182N10EXHAUST SYSTEM,DUAL(USED WITH TOURING YP6) D/EXH(N10)4,569N64WHEEL AND TIRE,SPACE SAVER SPARE(ALUMINUM) STOWAWAY SPARE(ALUM)(N64)7,327PW7WHEEL,16X8,STYLED(ALUMINUM)(SUPERLIGHT) STYLED AL WHL(PW7)6,264QLCTIRE,ALL P245/50ZR16/N BL R/PE ST TL HWY TIRE(QLC)10,360R6PCONTROL - SALES ITEM NO. 153,005T93LAMP,TAIL AND STOP(SPECIAL)(DELETES CHROME EDGING)(USED WITH INTERNATIONAL WJ9) SPECIAL TAIL & S/LP(T93)5,059T96LAMP,FRONT FOG(USED WITH APPEARANCE PACKAGE WS4) FRT FOG LP(T96)33,888
compnine.com
Old Jan 5, 2019 | 11:41 AM
  #594
694275sp's Avatar
Hello,
I am new to this posting questions on sites, but I have a 86 IROC/Z that I have owned for a number of years now and I think it is unusual because it has very few options. AC delete, manual windows, non tilt column, etc. Based on the RPO codes am I correct in assuming this? I would appreciate any information pertaining to this car. Thanks!
Old Jan 5, 2019 | 05:46 PM
  #595
881SA's Avatar
Car: 1988 Camaro Z28
Engine: 5.7 / L98
Axle/Gears: 3.27 BW
Yes you are correct as based upon your SPID being a 1AZ it was a costumer ordered car. How many miles are on the car?
Old Jan 5, 2019 | 07:00 PM
  #596
694275sp's Avatar
Thanks for the reply,
The car just breached the 50k mile mark this year. I am the second owner of it and the lack of options is what I liked about it!
Old Jan 7, 2019 | 08:09 AM
  #597
okfoz's Avatar
It is an interesting car, LB9/A4, Very few options beyond that. Someone wanted something to just "go fast", no frills car...
John
Old Jan 7, 2019 | 06:51 PM
  #598
Engine: 5.0 TPI
I have followed collectible cars for quite a long time and low optioned cars are desired if they have high-performance options for the year. They are seen as purpose-built cars and are desired. 1960s muscle cars and corvettes with AC delete or radio delete are sought after by a lot of buyers. they are rare due to this. that 50K miles I would store it.
hopefully, you got it at a good price!
Originally Posted by 694275sp
Hello,
Old Jan 7, 2019 | 07:02 PM
  #599
694275sp's Avatar
It certainly is a fun car to drive. The fact that it was built pretty much like a car from the 60's, (clear glass, roll up windows, vinyl seats, biggest exhaust, 4 wheel disc) is what really attracted me to it. I have not seen another one with so few options.
Old Jan 7, 2019 | 11:44 PM
  #600
3rdgenzroc's Avatar
Car: 86 Iroc-Z
Engine: 383 HSR
Interesting, do you have any other pic's of the car, I'd love to see it in its entirety.
