READ ME! Before asking "Is my car rare/Desirable?"
Car: 1956 Chevrolet 210
Engine: Chevy 305 V8
Transmission: TH350
Axle/Gears: Posi 3.42
Re: READ ME! Before asking "Is my car rare/Desirable?"
I was thinking mine would be in the 15-20% range with L69 and 5-speed.
Just FYI I used to have an '84 L69 automatic and it DID have 3.73 gears. I believe it was RPO G92. It's listed in tech data on homepage of TGO too.
Mine may be going up for sale if the price is right...5 person family can't do much in a fun car with only 4 seatbelts! Lol
13,041 (1989) Formula, GTA & Trans Am W/L98
So are you saying that out of the 13,xxx made in 1989, most 350's were GTA's and TA's? Any further breakdown info?
Just curious, as I just bought a 89 Formy 350 with T tops, 65k, original and unmolested, but has had exhaust replaced with Flowmaster. I thought they were more common than not.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I have seen an unconfirmed number of about 1000 - 1300 Formula 350's with T-tops for 1989... the 91 & 92 is closer to 200/ year Formula 350/T-tops.
I do not remember the final number off the top of my head for the Formula 350's in 1989 If I even know it.
All I know is about 43 Formula 350 Convertibles in 1989...
Keep in mind only 1989, 1991 & 1992 are the only 3 years you could get a Formula, 350 & T-tops. 1987, 1988 & 1990 No Formula 350/T-top cars
I think the 3.73 was for the Manual, and 84 L69 used 3.42 was for the Automatic, I would like to see something to the contrary, I could be wrong, but it would be interesting nonetheless.
John
Car: 1983 Daytona 500 Pace Car
Engine: CFI - 305
Transmission: Automatic-700R4
N/A
My 15th Manual L69 Build Sheet 3.73 Ratio
Attachment 271605
My 15th Automatic L69 Build Sheet 3.73 Ratio
Attachment 271606
Attachment 271605
Attachment 271606
Car: 1985 silver metalic iroc
Engine: 305 tpi
Transmission: auto
Axle/Gears: 373 posi
how many 1985 silver irocs were produced .cant seem to find that out
the number of silver IROC-Z's produced may not be available. However take a look at the Camaro White book, it would give you the total number of Silver cars, and whether or not the IROC Z was the only car to get the color, which might be possible.. I don't have the WB here or I would look it up for you.
According to White Book The Silver was an option on, the Berlinetta, IROC, Z28 and Sports Coupe 11,684
I assume you have an 83, or are looking to buy one.
The best you will find for 83 is a Daytona Trans Am, nothing more than a sticker package and some ground effects, which was in turn used on most 1984 Trans Ams
The Camaro (as in your question) nothing spectacular comes to mind off the top of my head, 84 had the Olympic Edition, which again was a sticker package, the 82 had the INDY, The best thing you can hope for is the HO engine, which IMHO is superior to the Cross fire, just because of reliability.
The other day i picked up a 83 Camaro for like $350 it is a Brown Berlinetta with gold trim and on the doors it had limited edition on it so i was just curious if theres anything special about it it also has only 26,000 original miles.
[quote=GPHOGAN09;5798281]The other day i picked up a 83 Camaro for like $350 it is a Brown Berlinetta with gold trim and on the doors it had limited edition on it so i was just curious if theres anything special about it it also has only 26,000 original miles, it has a 305 v8 with a quad jet i bought the vehicle to sell but want to keep it now but my wife still wants me to sell it I have no idea what its really worth or if i should convince her to keep it?
Car: 1991 Trans Am Vert
Engine: 5.0 TPI
Transmission: T-5 baby
None that I ever saw back in the day. Some dealers added tape that said it to try to pass off a less stocked car as a Limited Edition
Chances of it being a 26,000 mile car... slim... more than likely 126,000... never know, but it seems awful cheep for a low miles car...
John
John
I work for a dealership and i can pull the carfax on the vehicle everything lines up with milage it can from texas in 93 with 12k miles and the guy said he bought it in 2003 with 19k miles which the car fax shows and he stored it in a barn until i bought it, it didnt run when i bought it and the body paint was pretty chipped up from him putting stuff on the car just wondering if i got a good find 83 berlinetta with the 305 which i didnt think they put in the berlinetta in 83 but could be wrong.
Could be then, just seems low. If so great find...
I am by no means a Camaro expert, but I believe that the 6 Cyl was standard in the Beryl, and the 4 cyl was a credit option, and the LG4 5.0 was an up-charge option in 1983. The Beryl was more of a luxury model, less interested in speed than refinements. Some years they had a unique dash, with a unique radio tower in the center console. The turn signal leaver/switch was not on the steering column, but on the dash itself. I believe they also got special (added) insulation for sound.
Car: 1986 Firebird Trans Am
Engine: 305 4BBL
Transmission: 5 speed
Axle/Gears: 9 bolt LSD 3.27
My 1986 Firebird Trans Am would probably come under the "Desirable" category. I'm a Aussie and the car was converted in 1991 to right hand drive. She's original black & gold with gold 15" x 7" cast wheels (N90), 75,000 original miles, 305 Quadrajet (LG4), 5 speed manual (M39), 3.27 (GW6) Posi (9 bolt G80), 4 wheel discs (J65), dealer added WS6 package with 36mm front sway bar, 24mm rear etc.. Has "Limited Edition" on the door handles, power everything including hatch, even rear vision mirror! It also has C&C T Tops. Has a new dual 3" exhaust set up, i have got new headers to put on soon that came with it. I have only had it for a couple of weeks, it sure does attract attention. I love it
Engine: 5.0 TPI
I sure bet it turns heads! great color combo. very 80s
I think it would be fun to have a RH drive car here in the States... might not be practical for us, but it might turn some heads...
Engine: 305 4BBL
Thanks! You have a nice car as well. I have all the registration papers (titles) from the original owner from the U.S and from the other 3 owners from Australia plus lots of receipts. The original owner (from L.A California) moved out to Australia (only a 20 minute drive from where i live!) and then shipped his car out here and converted it to RHD (cost $8500 to convert!) in 1991 (i have receipts for $32,000). On the VIN label it has "Pontiac Greenback Firebird" and even comes with a user manual titled "Greenback Firebird". I have taken friends for a drive and they can't believe it only has a 305 under the hood, the previous owner built engines for race/drag cars so maybe he's tinkered with it. Just looking forward to summer, it's freezing here and i want to take those T Tops off! Cheers
Engine: 5.0 TPI
Car: 1991 Z28 1LE
Engine: LB9 305
Transmission: Borg Warner T-5
Axle/Gears: GM 7.5 3.42 Posi
Is there any information on paint color production numbers through the years? E.G. How many Ultra Blue Metallic cars for 1991, etc?
Coupes: 3658+
Conv: 121+
White Book Total - 3873
37 Teal Metallic
Coupes: 20,005 +
Conv: 405 +
White Book Total: 22093
98 Ultra Blue Metallic
Coupes: 10,208 +
Conv: 568 +
White Book Total 11,038
i just bought a trans am 1983 daytona pace car..ricaro package. 4 wheel disc brakes,5 speed manual, 305 lg4, 4 pq 3.73 rear end, i could post vin and cowl plate if someone could help me figure out if i should rebuild to original condition or should i just put a different motor in her. thanks for your time
Car: 1991 Z28 1LE
Engine: LB9 305
Engine: 5.0 TPI
here is one for 10K
http://gtcarlot.com/colors/car/7636620-31.html
Car: Bright Red 1989 Firebird Formula
Engine: LB9 5.0L TPI
Transmission: MM5 5 Speed Manual
Axle/Gears: 3.45
You seem to have all of the numbers and information. Can you tell me how many 1989 Formulas were built with the LB9 5.0L TPI, MM5 5 speed manual transmission, N10 dual exhaust combination? I have read articles stating less than 50 and I have read arguments and discussions stating over 2000. I special ordered one in December 1988 and sold it 5 years later. I have kicked myself in the butt since then for letting it go and have kept an eye out for another one for the last 10 years. I finally found another one in the same colors (bright red on grey) in original condition, so I bought it. The only thing missing from my original is the T-tops, but I was willing to sacrifice that option. Just curious what the correct production numbers are. Thanks for your help.
As cool as it would seem 50 is a neat number... I hear that same 350 number about the GTA 350's as well...
My hunch would be around 500-800 or so TPI/MM5 Formulas/Trans Ams or GTA's were made
Axle/Gears: 3.45
Thanks OKFOZ. At the beginning of this thread, you have some pretty solid numbers on a lot of different combinations. Is there any way to find out an exact number of Formulas with TPI/MM5?
Unfortunately no, not for 1989 Firebirds at least... All I can get you is the number of
MM5 - 8,495 (Wards)
LB9 - 6,478 (PHS)
The Camaros you can sometimes deduce things from the numbers, but there are no solid numbers for Firebirds...
Keep in mind that after a certain point in 1989, ALL Formula LB9/MM5 got the N10 dual cats, Also ALL Formula LB9/MM5 got the 3.42 or 3.45 axle depending on year in the US.
John
MM5 - 8,495 (Wards)
LB9 - 6,478 (PHS)
John
Axle/Gears: 3.45
Thanks for the info. I guess I will just have to love the car no matter how many others there are out there like it!
Because a color may increase desirability, but it would not typically make a break a sale to someone that is otherwise looking for a 1LE, convertible, Firehawk, TTA (might hurt there), 350 or other option.
Also there are no other special colors mentioned in the list. Other than for reference, I do not think I called out any particular color. Otherwise I would have had to included the 700 Yellow Formula's in 1988, or the 2 Copper cars in 1986 or whenever.. It is not the intent of the thread... I would not be against you going through 11 years of information and compile how many of each color car there was and organize it into a new thread, go for it... I would strongly recommend you include Firebirds in your list, otherwise it would not be complete IMHO.
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
John, anything in the white book on the production of G92 camaro's in 1987 & 88?
Engine: LB9
Damn - that ain't rare at all! So where are they all now?
If I didn't know better I'd think that was for G80 & not G92.
Edit - you sure about those numbers Scott? Not to question you but how did they drop to only a few hundred units in 89 & 90?
Scott was only half right, they only show 5252 G92 cars in 1988... He was looking at the G80.
For production it appears that 1988 was kind of a low year for G92.
I will say that on the Camaro it was not an expensive option, only $20 or so...
John
John
John
John
Hey. My eyes aren't what they used to be. I tried following the line item, but I guess my eyes drifted up to G80. You're correct. The 5252 is correct for the 1988 count.
John
Engine: 5.0 TPI
yeah but I can relate... just try to read a serial number for a apple product...sigh.. heck a serial number for any electronic device these days... sigh..I cant. I am only 47...young
Car: '09 Pontiac G8 GT - 12.76@109
Engine: 436HP 6.0L
Transmission: 6L80E
Axle/Gears: 2.92
I wanted to check in here to let you know that the gentleman in Scottsdale, AZ who bought my Black 1989 Carroll Supercharged 350 VHO also now owns the Red 1988 Carroll Supercharged 350 VHO. He has the only two left. Amazing!
Thought you guys would like to know this.
Car: 1992 Pontiac Trans Am Convertible
Engine: 5.0L 305ci TPI
Transmission: 5 Speed Manual, World Class T-5
Axle/Gears: 3.08
I think that at this point in time, a mint original condition, low mileaged, fully documented car that may not have been so rare when it was first manufactured can now be more rare and desirable than a wrecked or beat up car that was produced in limited quantities. So many 3rd gens have been wrecked or mutilated, that a clean original car is rare and desirable to some degree no matter what trim level or model it is. A few years back, you could go to any local junkyard and still see multiple 3rd gens, now that is not the case. I have been going to local wrecking yards for the past few months, and several did not have even one 3rd gen. If there's 2 or more, that is shocking now. Another consideration is originality. A mint stock car, or a restored to factory specs using NOS and original GM parts also increases the value and desirability of any given 3rd gen. So many considerations...!!!
I am trying to find out how I can locate how many 1991 Z28 Camaros were made with 305 V8 5 speed manually with T tops. when this car was ordered they did not want to do 5 speed with t tops. they finally agreed to it. thanks
Engine: 5.0 TPI
who is they? 5 speeds are always rarer but the exact numbers I do not have.
in 1990-1992 AFAIK the G92 was NA with CC1 (Don't confuse this with the Firebird R6P)
1991
5 Speed TPI (MK6): 1,112 (Compnine number is about 5% or so low)
1991
