[AL] anyone Need parts ?
Car: 1991 Firebird Formula
Engine: 5.7L TPI
Re: anyone Need parts ?
Browsed through the build thread but didn't see: what color and condition is interior in?
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
Yea I guess so ... n I'm hurt in for $ right now so yea ... kids need Christmas ... the fender on the other side is pushed outlet at the top a inch !
Car: 86 2wd
Axle/Gears: 2:73 open (for now)
Engine: 5.7L TPI
I don't know how far you're parting this, but there's a triangular bracket that supports the flat panel where the bumper cover and hood release are mounted. Mine has some mounting holes broken off, so if it's in good shape let me know.
Just to be sure, when you say gray you mean Med. / Dk. Gray like they have here http://www.3rdgenformula.com/91/91options.htm right? If so, are the front two seat belt receivers in good shape / still in their sheath?
How many switches are on the switch bezel above the heater controls?
If there's the courtesy light in the rear trunk panel, I could use that too.
Car: 1991 firebird
Axle/Gears: 4.10
There only 2 switches rear hatch and defrost .. and whatever color came factory in 91 .. and yes the rear hatch light works .. make offers Idk what some of this stuff goes for but I know there's a lot a $ setting in the garage
Car: 1991 firebird
Axle/Gears: 4.10
The car also has a fairly new rearend with 4.10s Yukon gears and Eaton posi.. all new bearings and seals brake lines e brake cables disc brakes with new rotors calipers etc.
Car: 1989 GTA
Engine: LS coming soon
Transmission: 80E coming soon
Axle/Gears: S60/35 Spline/S-Trac/3.73
If you still have the seat belt set and they are clean or cleanish how much?
Car: 87 Iroc Z 28
Engine: 355/ 600 Holly
Transmission: 700R4 shift kit & vette servo
Axle/Gears: 9 bolt 3;70s
Car: 1991 firebird
Axle/Gears: 4.10
Idk man .. I would have to get a good bit a $ for that cause I still don't know what I'm a do about the next third generation ... and if I get another one to also gonna have to b 5 speed ... and I'd like to sell the bmr Trans crossmember with the t-5 if I did sell it which I paid over 300$ for so I'd need at least 200 just for the crossmember
Car: 1991 firebird
Axle/Gears: 4.10
And yes the T5 is in perfect order with a fresh fluid change 1000 miles ago ... never had any problems out of the trans
Car: 1991 firebird
Axle/Gears: 4.10
Make offer
Car: 1991 firebird
Axle/Gears: 4.10
Make fair offers worst I can say is no ... I'm not gonna charge top $ but I would like to get 60-75% of what parts are worth especially for fairly new suspension drive train items
Car: 1991 firebird
Axle/Gears: 4.10
Car: 89 Firebird Formula
Engine: 3500T
Axle/Gears: 9 bolt/4.11
What does it have for shocks/struts?
Also how much for the panhard bar, torque arm, LCARBs, and/or caster/camber plates?
Car: 1991 firebird
Axle/Gears: 4.10
Panhard bar and Lca 225
Torque arm 150
Lcarbs 50
Caster camber plates 100$
ALL PARTS PLUS SHIPPING
THANKS NATE !
Car: 1991 firebird
Axle/Gears: 4.10
Car: 1991 firebird
Axle/Gears: 4.10
Car: 86 T/A/1990 Firebird
Engine: 5.3 L33 pt7675 / Ls1
Transmission: 4L80E/T56
Axle/Gears: 3.73/4.10
what can you tell me about the pillar pod with the gauges and what kind of panhard bar is on your car? like poly, del sphere (roto joint) etc.
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
Car: 1991 firebird
Axle/Gears: 4.10
Car: 1991 firebird
Axle/Gears: 4.10
Car: 1987 Trans am
Engine: 350 Vortec Stealth Ram
Axle/Gears: 02 SS Torsen Zexel 3.42
Do you have the slave cylinder bracket that mounts to the bell housing and the torque arm mount from that t5?
Car: 1991 firebird
Axle/Gears: 4.10
So I take it that it's a goner?
