Lots of Chevy Gen 2 and LS parts! Need gone!!
Old Dec 22, 2014 | 12:08 AM
JCS94's Avatar
Car: 89 Formula WS6
Engine: LQ4 h/c/i
Transmission: TH-FO-HUNNIT
I have a lot of SBC and Gen III LS parts for sale.
For starters, from the SBC came from an 89 Firebird with 81,xxx miles:
3rd gen water pump: $10
Power Steering Pump: $5
Smog Pump: $5
Alternator from 305ci Firebird, not sure of amperage: $20
Starter from same motor: $50
Hooker shorty headers, cut in front passenger side primary from sawzall, easily fixable by welding: SOLD
From Gen III LS: LQ4 2002:
Oil pan, pickup tube, baffle and windage tray, could use a heavy cleaning but nothing wrong with them. Comes with oil level sender: $125
Oil pump: $30
Water pump for truck with stock thermostat: $50
Truck tensioner: $20
317 heads, could also use a good cleaning. 5 exhaust manifold bolts stuck, but very easily accessible for removal, I just do not have the means to remove without taking to a shop: $250
lQ4 intake manifold with throttle body: $150
LQ4 stock injectors: $100 for set
Intake can be sold with intake, fuel rails, injectors, and throttle body (cable driven): $200
All of these items are priced OBO. Just need all of these gone ASAP because I am trying to drop my LQ4 into my Firebird and need the money to buy the 2 parts left to drop it in! Thanks in advance and thanks for looking! Easiest and quickest way to reach is via text: (812)202-9846
Old Jan 2, 2015 | 12:02 AM
JCS94's Avatar
Car: 89 Formula WS6
Engine: LQ4 h/c/i
Re: Lots of Chevy Gen 2 and LS parts! Need gone!!
To the top...
Old Jan 6, 2015 | 12:57 PM
JCS94's Avatar
Car: 89 Formula WS6
Engine: LQ4 h/c/i
Bump it up
Old Jan 10, 2015 | 10:17 AM
JCS94's Avatar
Car: 89 Formula WS6
Engine: LQ4 h/c/i
bump...
Old Jan 13, 2015 | 06:58 PM
JCS94's Avatar
Car: 89 Formula WS6
Engine: LQ4 h/c/i
Need all this gone guys
Old Feb 2, 2015 | 08:01 PM
JCS94's Avatar
Car: 89 Formula WS6
Engine: LQ4 h/c/i
bump...
Old Feb 4, 2015 | 09:50 PM
kuddybing's Avatar
Car: 85 Trans Am
Engine: carbed 350 four bolt
Transmission: 700R4 with shift kit
Axle/Gears: 373's
Where are u located and/or do those prices includ shipping?
Old Feb 4, 2015 | 10:54 PM
JCS94's Avatar
Car: 89 Formula WS6
Engine: LQ4 h/c/i
I am in Southern Indiana or Southern Illinois, depending on if I am college or not.
Old Feb 4, 2015 | 10:57 PM
kuddybing's Avatar
Car: 85 Trans Am
Axle/Gears: 373's
Do the prices on the p.s.pump and w.t. pump include shipping? Do u have pics? what kind of condition are they in?
Old Feb 4, 2015 | 10:59 PM
JCS94's Avatar
Car: 89 Formula WS6
Engine: LQ4 h/c/i
No they do not include shipping but I could do about $10 for both, so $25 for both. And I do not have pics but they were both working perfectly when removed from my engine. No cracks or harmful blemishes, just showing age.
Old Feb 4, 2015 | 11:01 PM
kuddybing's Avatar
Car: 85 Trans Am
Axle/Gears: 373's
Im im M.I. so we arnt to far from each other.... let me guess u swapped your 6.0 heads for some ls1 are ls6 heads didn't you? For your l.s. swap
Old Feb 4, 2015 | 11:03 PM
JCS94's Avatar
Car: 89 Formula WS6
Engine: LQ4 h/c/i
Yeah man it ain't too far away. And yeah I swapped my 317 (LQ4) heads for some 243 (LS2, bumps up compression cuz I'm not going forced induction, and because I wanted a higher compression for my 239/244 cam) heads.
Old Feb 4, 2015 | 11:22 PM
kuddybing's Avatar
Car: 85 Trans Am
Axle/Gears: 373's
Can you get pics? I ask because I want to make sure the p.s. pump has no dents are anything wrong with it(mines works fine I just dented it when I adjusted the belts last time). and what type the w.p is (long r short)? Im going to change my head kn my carbed 350 to some #461 and then start saving for my ls swap I wad thinking about the same as you just 6.0 block ls6 heads, ls6 cam and a carbed with a rpm air gap ls intake m.s.d. box for ignition (the programmable one for both carbed and e.f.I.
Old Feb 4, 2015 | 11:27 PM
JCS94's Avatar
Car: 89 Formula WS6
Engine: LQ4 h/c/i
Uhh I can get pics when I go home in about a week. I am at college right now and won't be going home until february 13th.
Old Feb 4, 2015 | 11:37 PM
kuddybing's Avatar
Car: 85 Trans Am
Axle/Gears: 373's
Ok man put some pics up when u get back home and il let you know my cars put up for the winter so I can wait on the pics
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
Reborn756
Sep 4, 2015 03:42 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
1nastygta
Aug 8, 2015 07:38 PM
