[NJ] LT1 Throttle Body w/Elbow & Tube...
Old Jul 16, 2015 | 10:57 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Grabbed an LT1 throttle body with elbow and tube awhile back, as I was going to use this for a project. The elbow has the location for the IAT sensor, which is good for TPI guys looking to relocate your sensor away from engine heat which was the original plan for my project, as well as making a cold air intake. The IAT is not a screw in sensor, you have to use the LT1 sensor that pops into place. Or, you can just seal it closed and retain your original heat soaked sensor under the plenum. The throttle body comes with the IAC and TPS sensors, as well as the IAC housing underneath. It does not come with the upper cover though, but any TPI upper throttle body cover will fit. Needs to be cleaned, too tired to do it myself. Be sure to check your application as it uses the newer style throttle cable feed that wraps around with the groove...
$25.00 for what is in the pictures...
Old Jul 16, 2015 | 02:12 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
PM sent.
Old Jul 16, 2015 | 06:44 PM
Re: LT1 Throttle Body w/Elbow & Tube...
Items were sold, thanks Shaun!
- Rob
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
DIY PROM
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
lakeffect2
Aug 23, 2015 08:44 AM
mdtoren
Aug 16, 2015 05:45 PM
