Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
HIGH compression e85 guys come on in :)
Old 03-05-2017, 08:42 PM
fbodyfreakls1's Avatar
Car: 1984 z28
Transmission: Viper prepped LT1 T56
Axle/Gears: strange s60 4:10 locker
Building a 13.5:1-14:1 comp LS1 e85 carb engine for my 84 z28, t56 car, hoping to run in the tens on motor and idk what to expect when I give it the 300 shot I'm planning on. Just wanna hear from other guys with gen1,2,3,4 small blocks that are running 12:1 and higher compression e85 Cambo's and what kinda power and times y'all are putting down. Hard to find any LS engines on line with steep compression ratios to see results from. Figured it'd be cool to hear what kinda power you gen one and two guys are seeing as well. Now discuss 😊
Old 03-25-2017, 11:21 AM
TB2
TB2's Avatar
Car: 84 Transm
Engine: 350 sbc
Transmission: t400
Axle/Gears: ford 9", 3.90
Re: HIGH compression e85 guys come on in :)
I'm running a gen1 350. 13.8-1 comp with ross pistons and a lightened stock forged crank. I'm presently considering having my 23 deg dart heads angle milled, as the e85 can still handle more compression. TH400 with a brake and 4:10 gears. I'm running a 1050cfm 4150 style carb I built myself using mostly proform and quickfuel parts. Use a wide band gauge for tuning because its very hard to read plugs, as it burns so clean. Best is a 10.9 so far N/A with traction/suspension issues. If I can get the suspension sorted out I think it should do 10.5 consistently without any more changes to the car. The car is also regularly street driven. It's a lot of fun on the street!
Old 03-27-2017, 09:22 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i'll tell you more about my experience with compression and e85 later this year.
your goal is obtainable with less engine than you proposed though, so it should have no issues with 10's with what you're building.
Old 03-28-2017, 09:22 PM
Car: 1984 z28
I'm watching yours closely Matt, have been for a long time, sucks the T56 didn't work out :/ hope I have a better experience!! My build isn't going as fast as I want so its motivational hearing what similar combos are doing!
Old 03-28-2017, 09:25 PM
Car: 1984 z28
What's your race weight and what kinda rear tire/suspension you running?
Old 03-29-2017, 12:09 PM
TB2
TB2's Avatar
Car: 84 Transm
Engine: 350 sbc
Transmission: t400
Never weighed. But around 3000lbs. Moser 9" with single adjustable coilovers, all tubular rear susp pieces and a Wolfe drag bar. 26" x 10" slicks.
Old 03-29-2017, 12:14 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
My buddy street drives and street races a s10 pickup. Was a 434 sbc, mid 13:1 comp i believe. Sprays a ton of gas on it. 350-400 shot. E85 just fine
Old 03-29-2017, 04:58 PM
Car: 1984 z28
im hoping to be around 3200 wo/driver, that would put me around stock weight with all tubular chromoly suspension and cage with a/c and heat, full interior etc. nice to see something very similar. gives me a idea of what to expect.
Car: 1984 z28
what kinda times did he run at the track? if you know, thanks.
Old 03-29-2017, 04:59 PM
Car: 1984 z28
thanks for the positive reinforcment!
Old 03-29-2017, 05:08 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Street racer, never runs track but i raced him. I would guess hes a higher 8 sec truck
Old 03-29-2017, 08:58 PM
Car: 1984 z28
Nice! I'm kinda hoping on low 10's on motor and low 9's/high 8's on the 300 shot. Never messed with nitrous before so I might be a little optimistic. Especially since I'm more concerned about how it's going to run on motor than spray. I don't want to give up a bunch of power on motor with a nitrous grind cam, but I don't want to not run spray and not be competitive at events. I guess that's all a different thread for a different day though and I need to do some research on all that before I start asking a bunch of rookie questions.
Old 03-30-2017, 05:23 AM
mw66nova's Avatar
Engine: 7.0L
what are you doing for clutch management?
Old 03-30-2017, 11:55 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
If car is under 3500 it will have no problems. Low 9's on spray if you can drive. High hp nitrous stick car aint easy lol
My buddy's old 406 sbc was a 500 whp car all motor and 775 on spray. Ran 9.3 at like 147 i think with his t56. 93/94 trans am
Old 03-30-2017, 02:33 PM
VAGOGTA's Avatar
Car: 1987 IROC Z
Engine: OLD SCHOOL SB 383 stroker
Transmission: TH 350
Axle/Gears: F9 3.90 gears 35 spline
3200 lbs car with old school SBC 383 and around 12.7 CR our best with DA of 4000ft has been 10.50's and 60 fts of 1.36 running VP c-12 ,made some change to suspension and looking to hit 10.40's really soon
Old 04-08-2017, 08:36 PM
Car: 1984 z28
I know your a monster guy im going spec tho had a spec 2 in my 99 z28, was installed at 60k and still rocked out hard when I killed the car at 231k. That same car made me a mobil 1 guy for life as well.
Old 04-08-2017, 08:41 PM
Car: 1984 z28
I read somewhere that my car stock curb weight was like 32xx, that's with the all iron L69 and t5. So I'm hoping with a full tubular chromoly suspension and cage and the LS1 that I'll end up around that weight. I'm keeping heat and air and it will be a full weight car. With a t56 witch adds a few pounds. So I'm hoping with all the weight loss and weight adding with trans and cage that I end up the same or lighter. I would love to be 3000 w/o driver. I'm 290 right now, gotta go on a diet lol
Old 04-09-2017, 08:08 PM
mw66nova's Avatar
Engine: 7.0L
i am a monster dealer and have used monster in the past, however i am using a real adjustable race clutch from Black Magic this time around. clutch management is easily the most over looked part of this whole deal, and is also easily the most important part.
Old 04-10-2017, 11:11 PM
Car: 1984 z28
I plan on driving this car 10,000+ miles on this car a year and just with my spec experience I feel good about going that route. Car will see wayy more street use than track use. Hope to do a fair amount of street racing with the car. Been quite some time since I've got out and had a good time. I've looked at monster and have never Hurd one bad thing about them but for the money I feel good about spec. Im open to other options tho, like any guy should be!
Old 04-11-2017, 05:31 AM
mw66nova's Avatar
Engine: 7.0L
well, i can't advertise my pricing publicly because it's too low, but pm me if you're curious about pricing and options.
Old 04-11-2017, 06:30 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
My buddy used to run spec 3 clutches in his t56. They seemed to work very well. It was a high 9 car then
Old 04-11-2017, 06:53 AM
mw66nova's Avatar
Engine: 7.0L
tom also ran an lt1 type t56 and his options were limited
Old 04-11-2017, 07:43 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
True dat lol
Old 04-12-2017, 09:54 PM
Car: 1984 z28
I am also running a LT1 type t56, wanted the external slave cylinder. PM is being sent now, you've got me curious.
