Fuel Door Alignment Issues? Here's the fuel door gasket part #
I couldn't find this on here before, but here's the part # for the proper way to align the fuel door (i know there's a tech article saying to use washers) but this is the proper way. Usually need 1-3 of these from what I've been told
20418784 - fuel door gasket
Pic shown
tag words:
Fuel door gasket
Fuel door alignment
Pic shown
tag words:
Fuel door gasket
Fuel door alignment
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Re: Fuel Door Alignment Issues? Here's the fuel door gasket part #
It's a discontinued part, sadly.
If you could maybe put a ruler next to the scanned image of it.. it could be re-created most likely.
I just found and purchased the last 2 known in existence about 20 minutes ago from Canada
Maybe I'll copy the dims and re-make them for you guys
Engine: 4++,350 & 305 CIs
One of the many things I grab while at the junkyards.
What is this junk... yard? that you speak of? It sounds like an amazing place with streets paved of thirdgen parts.
Last thirdgen I saw in a junkyard here was so bad, I'd be hard pressed to find anything on it of any use...
Tons of "junk" around here still.
Car: 1991 Firebird Formula
Engine: 5.7L TPI
There's been a bit of a dry spell as far as thirdgens in junkyards here in Colorado. Having just shimmed my fuel door with washers, I find it quite interesting that there was actually a gasket used to shim it. I imagine it wouldn't be too hard to make one yourself, even without the exact measurements.
If you do, I am in for a few. When I had my car repainted, the painter lost the gasket and I had to buy a thin sheet of gasket material and trace out a new one, to the best of my ability. It did the job, but I would prefer a copy of the original.
Will let everyone know on here if/when it's available. May be a little time with trying to get the car done before Thirdgen Expo. Once I figure out a way to mass replicate them, I'll put them up for sale for those that want to repair their car correctly
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
I was actually surprised today at how many were at the small local pick n pull here in town. Theres always a couple, but today i seen atleast 4 third gens and another 5 or so fourth gens.
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
After a disassemble and respray, the fuel door just doesn't seem to align well.
Might try a new gasket to see if that helps..
My 82 still has the rubber gasket. When I was putting the car back together from paint recently, I reused it and I still spent 2 hours trying to get the door the way I wanted it. It's a little finicky even with the gasket.
"Door doesn't like up?"
"ahhhh just slap a few shims in there, it'll be ok"
"GM PN # created"
lol
See my new tech resource website http://thirdgens.com
has a pdf print of the gasket that is 1:1 scale so you can print and trace
Looking forward to seeing your site develop.
