I need a Tuner Pro crash course
Old 05-24-2017, 06:22 AM
HellHound's Avatar
Car: I drive trans am. Duh
Engine: Yes, I have one in the trans am
Transmission: I have one of those too In trans am
Axle/Gears: In the rear of trans am
ok. So my buddy's Camaro has a vats problem and the module is bad. So I need to shut off vats. I've already made a few changes in the program. I understand what I am looking at. I have burnt many chips and done tuning in the past. I have a burn 2 and an emulator. I have down load the files I need and he has a prom converter on the way. We will be using the 512 chips.
Here is the question. I don't see a burn button, or one to pull the file off a chip. Or am I just missing something here and just blind? Other programs I've used the burn 2 just plugged right in and I pull files or burn them through the program I am using. Do I need another program to burn the chip after it is created and have saved the file/bin? Also Can I read the old chip? I don't see a button for this either.
Thanks.
Old 05-24-2017, 06:33 AM
ULTM8Z's Avatar
Re: I need a Tuner Pro crash course
I believe you need separate software to program the chip.
Old 05-24-2017, 09:14 AM
HellHound's Avatar
Do you know which one or what it is called?
Old 05-24-2017, 09:25 AM
HellHound's Avatar
Is it the flash and burn software?
Old 05-24-2017, 09:43 AM
GeneralDisorder's Avatar
TunerPro can erase and flash the chips it's under like hardware utilities or something. At least that's how it is with the Autoprom.
GD
Old 05-24-2017, 09:46 AM
ULTM8Z's Avatar
I use the minipro programmer...
m.ebay.com/itm/221092473435?_mwBanner=1
Old 05-24-2017, 03:29 PM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
You can use this instead of through tp. Watch your burn offsets moates has offsets listed for file size.
Old 05-24-2017, 08:05 PM
HellHound's Avatar
GD
okay, thanks. I'll look again tonight. Maybe I am just blind, cause I didn't see anything. If I have anymore questions I'll post here.
Old 05-25-2017, 04:02 PM
It's under tools->hardware utilities->moates prom I/O
GD
Old 05-25-2017, 07:05 PM
HellHound's Avatar
I just don't see it. I must be blind.
Old 05-25-2017, 07:26 PM
Engine: Lb9
Transmission: M20
Your not using tp rt.
Old 05-25-2017, 08:07 PM
HellHound's Avatar
Okay so I am using the wrong one?
Old 05-25-2017, 08:26 PM
Engine: Lb9
Transmission: M20
If your wanting to use the burn 2 use flash and burn or tunerpro rt.
Old 05-26-2017, 04:52 PM
Ok I guess that's not an option in TunerPro - you have to download the RT edition. That seems odd because burning chips isn't a "Real Time" operation. But there ya go!
GD
Old 05-26-2017, 05:39 PM
HellHound's Avatar
Thank you guys. I got it done.
Old 05-26-2017, 06:04 PM
Excellent!
Old 05-26-2017, 09:54 PM
HellHound's Avatar
And the car is running!
feels good. Now the real fun begins.
