Gear pattern (used gears)
Old 05-26-2017, 07:36 PM
zebbe152's Avatar
I've just replaced the carrier and pinion bearings in my BW 9-bolt rear end. This is the first time I'm doing this so I'm hoping that you guys can have a look at this gear pattern and tell me what you think.
Backlash is set to 0.007". Keep in mind that these gears are not new.
Attached Thumbnails Gear pattern (used gears)-gear-drive.jpg   Gear pattern (used gears)-gear-coast.jpg
Old 05-26-2017, 10:47 PM
big gear head's Avatar
Re: Gear pattern (used gears)
Looks like the pinion is a little deep, but it would probably run fine like this. If it was me I'd take about .003 out of the pinion shim and check it again.
Old 05-27-2017, 01:00 AM
NoEmissions84TA's Avatar
These should help you decide.
Attached Thumbnails Gear pattern (used gears)-acceptable.gif   Gear pattern (used gears)-too-deep.gif   Gear pattern (used gears)-too-shallow.gif   Gear pattern (used gears)-toothterms-e1315948831207.gif
