Changing Motor Mounts
Car is my 1987 IROC with the 350 TPI.
Thinking this is pretty straight forward. I tried the search function here and didn't find any info which I found odd. So to YouTube I went and found this video.
Seems pretty straight forward but wondering if you guys have any reccomendations on what type to purchase?
Thanks.
Thanks.
Re: Changing Motor Mounts
Not that hard as long as you can safety raise car and motor enough to unbolt and remove frame clam shell mounts. Use best quality inserts or OE mount if you can find them. They have been discontinued for along time.
Joe
Joe
When I replaced mine the AC delcos were running around $180 a pair so I went with the Energy Suspensions for around $50 a pair.
Not quite sure why the guy in the video removed his spring... If you have a long box end wrench you can get them out with a little effort. However when you put the nuts back in put a piece of tape on the wrench to hold the nut in place and it will go a lot quicker.
When I did mine I supported the car with stands towards the rear of the k member and let the front suspension hang down with both front wheels off. I removed the three motor mount bolts by sticking a longer box end wrench up into the lower control arm hole in the frame to access the nut. Turned the bolt from the top side of the mount using a ratcheting wrench. Repeated the process for the other two bolts.
When I went to bolt the new mount in, I held the nut in place on the end of the wrench by putting a piece of duct tape across it and started the bolt by hand. Repeat the process for the rest of the bolts.
It is not a fun job and I don't want to do it again anytime soon, but i don't have a spring compressor and it just seems like a huge hassle to gain a few inches.
I borrowed a professional grade spring compressor from Auto Zone to compress the springs and get the control arms dropped and out of the way. I used a jack and a length of 2x4 to lift the engine by the oil pan to get clearance. Not a fun job but do-able. Don't expect to go to fast and you won't get frustrated. The first side took me 2 hours, the other side took me 30 minutes.
I suppose one could take a long box end, like a distributor wrench, and bend it around to hold the bolts and get it around the control arm without taking the arm out. A good idea would be to get nuts that have the captive washer on them, that way they would sit in the box end without falling through.
That all being said, I can see it both ways. I do not like using spring compressors and working so close to them. Those springs are really loaded but the extra access makes it nice and you can change the control arm bushings while they are down. If you are going to use a spring compressor use a good one.
