"it" has begun....
Old Oct 24, 2017 | 09:16 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
"it" has begun.... JY 92 Formula
1st time I saw it on tgo, 10-13-2008
Greg n I, Thanks, you have noooooo idea what it means to me !!!!!
305 tpi 5speed R6P car with the dealer installed SLP 50hp kit. Original owner didn't opt for the air box though. "As is" needing a bath
Greg burning them down before it leaves
Loaded up
Planned to restore it back to stock with it's dealer installed SLP parts but with all these other SLP parts I've collected, "what if" I went next level?
Either way, "It" has begun..
Some 1st year pictures.
https://www.thirdgen.org/g/album/3010400
Old Oct 24, 2017 | 10:33 AM
jkris53406's Avatar
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
Re: "it" has begun....
Well that looks interesting
Old Oct 24, 2017 | 12:43 PM
Drew's Avatar
Hmm... Now I have to remember how to subscribe a thread.
Old Oct 24, 2017 | 01:41 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Sweet. I love "it". I've seen "it". I totally approve and am an enthusiastic supporter of "it".
Old Oct 26, 2017 | 10:16 PM
TTOP350's Avatar
Old Oct 26, 2017 | 10:18 PM
Drew's Avatar
Sweet Doug Nash 6spd!
I'm loving seeing this come together. Don't often get to see these pieces apart.
Old Oct 27, 2017 | 09:22 AM
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
I've been waiting for you to make this thread.
Old Oct 27, 2017 | 03:22 PM
George Klass's Avatar
Car: 1989 Trans Am
Wow, nice car. Can't wait to see this build.
Old Oct 27, 2017 | 09:25 PM
instro84's Avatar
Car: 89 tta
Engine: turbo v6
Transmission: 200r4
i remember test driving a TA in that color back in the 80's.
Old Oct 28, 2017 | 08:02 AM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Seen these pictures already - where's the motor?
Old Oct 28, 2017 | 08:17 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Interested to see how "it" turns out, subscribed.
Old Oct 28, 2017 | 08:22 AM
TTOP350's Avatar
It's on the stand, trying to figure out if I want the prototype cars cam specs or production cam specs.
Old Oct 28, 2017 | 12:16 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Prototype sounds like it may be healthier.
Old Oct 29, 2017 | 07:43 AM
PurelyPMD's Avatar
Engine: LB9
Be special - go prototype - and bring on the ****!
Old Oct 29, 2017 | 08:40 AM
TTOP350's Avatar
That may add an extra 15 hp!
I'm sure this thread will be active till sometime close to the Norwalk show. (hope to have it out there for that)
Old Nov 3, 2017 | 05:53 PM
thebandit50187's Avatar
Car: 92 Trans Am, 87 Formula
Engine: 305 soon to be TBI, 91 305 TPI swap
Axle/Gears: 10 bolt
Old Nov 3, 2017 | 11:03 PM
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
"it" is gorgeous. I'm in love with that yellow and looks like you have two of them in it!
Old Nov 6, 2017 | 01:01 PM
TTOP350's Avatar
Cleaned up a bit, a header checkvalve was broken and had leaked exhaust carbon all over. Everything was covered in black nasty stuff.
Engine coming out
Bath time
Cleaned and Painted
Details
Steering box out and cleaned up
Cleaned up, painted and semi detailed. The black over spray looking stuff is factory undercoating from when it was applied in the wheelwells. Not sure how it got there but i have seen it on almost all the cars I've seen
Working on caliper/rotor fitment incase I had to make the caliper bracket and rotor hub/bell. These parts are from a 4thgen F-body kit.I lucked out and found an original set of Brembos for the 3rdgens that SLP made
A picture of the factory panel bond before the cleanup/detail..
Last edited by TTOP350; Oct 6, 2024 at 07:56 AM. Reason: JFC how come the pictures got wiped when editing txt and cant add pix back individually wtout it wiping the other pix? ?
Old Nov 6, 2017 | 01:03 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
That is a good looking caliper. I also like the body colored inserts in the wheels. I have always wanted to paint my Ronals like the Firehawks
Old Nov 6, 2017 | 01:26 PM
DynoDave43's Avatar
Sweet.
Is that a full floating rear axle?
Old Nov 6, 2017 | 01:28 PM
TTOP350's Avatar
Sweet.
Nope,its a GM Dana 44. Supposedly ran some test laps (to make sure it was ok) for a certain firehawk race team and then was set aside as a backup.
Old Nov 7, 2017 | 03:50 PM
scholtmj's Avatar
Car: 88 Trans Am Hardtop
Engine: 350 L98
Transmission: Stock 700R4
Axle/Gears: 3.27 Aussie 9
Old part gold mine!
Old Jan 11, 2018 | 04:59 PM
TTOP350's Avatar
A little more SLP **** for the cold winter days
Old Jan 11, 2018 | 05:01 PM
Drew's Avatar
I don't think I could bring myself to wipe my feet on the Pontiac logo.
Old Jan 11, 2018 | 05:58 PM
TTOP350's Avatar
It's in front of my bathroom in the garage, I step over it lol
Old Jan 11, 2018 | 06:00 PM
Drew's Avatar
Wait, wait, wait.... Hold up a second... Your cars have their own bathroom? That's dedication!
Old Jan 11, 2018 | 06:09 PM
TTOP350's Avatar
Yup! Have a urnal, azz gasket despenser above toilet and even a hand dryer... (maybe went a bit overboard)
Old Jan 11, 2018 | 06:30 PM
gp90gta's Avatar
Car: 1990 GTA
Very cool, is that the same crossmember the tta uses?
Old Jan 12, 2018 | 03:16 AM
Axle/Gears: 10 bolt
Quick teaser
those 13" Brembos. Very nice
Old Jan 12, 2018 | 06:42 AM
TTOP350's Avatar
Nope,
Hawk left, TTA 2piece middle, stock right. <br/>The TTA piece has been used with a few GM engineering ZF swaps I've seen so I know it will work.
Hawk left, TTA 2pice middle, stock right.
Old Jan 12, 2018 | 07:15 AM
TTOP350's Avatar
T5 vs F-body ZF trans bellhousing and TTA trans crossmember. <br/>I didn't have a corvette bellhousing at the time to compare.
Old Jan 12, 2018 | 07:52 AM
gp90gta's Avatar
Car: 1990 GTA
I assume you sourced a consol for this and was the throttle bracket for manual different, I've seen the auto but not the manual one.
Old Jan 12, 2018 | 08:15 AM
TTOP350's Avatar
. Throttle bracket is the same for each. The cruise control and auto bracket (mounted to side plenum) was a later SLP addition.
Old Jan 12, 2018 | 08:39 AM
Ct1987's Avatar
Very Nice. Love the Yellow's
Louis
Old Jan 29, 2018 | 07:23 AM
TTOP350's Avatar
Still need to get the NOS nose (not pictured) and aluminum hood painted
Old Jan 29, 2018 | 07:39 AM
scholtmj's Avatar
Engine: 350 L98
Is that the reproduction bolt in cage?
Old Jan 29, 2018 | 10:27 AM
TTOP350's Avatar
Yes it is.
Old Jan 29, 2018 | 10:36 AM
rdhanded2's Avatar
Top Answer: 1
Car: 91 TA / 91 Formula
This is awesome.... So when shall we see it alive?
Old Jan 29, 2018 | 11:05 AM
TTOP350's Avatar
There are a few things that may keep me from completely finishing it but I'm shooting for this date. http://www.pontiacnationals.com/
Old Jan 29, 2018 | 11:40 AM
scholtmj's Avatar
Engine: 350 L98
Yes it is.
Very cool. Are you happy with the fit and finish?
Old Jan 29, 2018 | 12:37 PM
TTOP350's Avatar
Yes, a couple of very small things I mite have changed for what I'm doing but for what it is, it's just fine.
Old Jan 29, 2018 | 12:49 PM
scholtmj's Avatar
Engine: 350 L98
Good feedback, thanks!
Old Jan 29, 2018 | 01:23 PM
PurelyPMD's Avatar
Engine: LB9
Looking forward to seeing it (& you again) in Norwalk.
Old Feb 4, 2018 | 07:23 AM
TTOP350's Avatar
Pic from a few yrs ago, sold off 2 of them.
Test run with wrong font. Bought some repops so i don't have to screw up the 1991 original centercaps.]
Old Feb 4, 2018 | 08:05 AM
PurelyPMD's Avatar
Engine: LB9
Likie!!!
Old Feb 4, 2018 | 09:36 AM
TTOP350's Avatar
That one is going to take some cash to build, down the road engine!
Old Feb 4, 2018 | 04:55 PM
Anti-Venom's Avatar
Car: '89 Formula WS6
Transmission: 700r4/T56
Axle/Gears: BW 3.23
Mmmmm....Mmmm...Mmmmmmm...............
Old Feb 4, 2018 | 06:21 PM
Steve86TA's Avatar
Car: To many to list
That one is going to take some cash to build, down the road motor!
Just a little $$...looking good though
Old Feb 5, 2018 | 08:55 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Damn hoarders, lol.
I would potentially be interested in some of those cap "jewels" if you have more made, or want to part with those. I got some last run R15s and the center caps just say "Ronal", very boring.
Old Feb 11, 2018 | 09:38 AM
punzak9's Avatar
Car: 1990 Firebird Formula
Engine: 305 V8
I wish i had the energy to put into my car like you do for yours. Looks like a great build already. Future COTM right there lol
