Anyone ever used SEM Color Coat?
Old 11-06-2017, 09:31 AM
86IROC112's Avatar
Car: 1986 IROC Z
Anyone tried this on interior plastics? I know a lot of guys use the PPG dye but was wondering if anyone has tried this stuff? I know SEM makes good products.
Old 11-06-2017, 10:20 AM
Abubaca's Avatar
Car: 1988 Iroc
Engine: L98 350
Axle/Gears: Hawks 8.8 - 3.73
Re: Anyone ever used SEM Color Coat?
I have a buddy who used it on his 2nd gen Bandit TA with the tan/beechwood/camel whatever you call it brown interior. Came out amazing, but as with all paint and coating, it's all about the prep. Follow directions to the letter.
I think there's various threads on here too, but that's my only firsthand experience. Just search SEM.
Old 11-08-2017, 02:15 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
SEM is the best from what I've heard. See this thread https://www.thirdgen.org/forums/inte...ic-carpet.html
Old 11-10-2017, 05:04 PM
crossrush's Avatar
Car: 1986 Iroc z
Axle/Gears: 3:42
I used the SEM stuff on my interior and it looks great. Just make sure you clean the plastics really well and let dry. Before coating with the color use a good adhesion promoter.
Old 11-10-2017, 07:12 PM
Ct1987's Avatar
Car: 1987 Firebird Formula
Engine: CharlesOdoryOB
Transmission: 87587369775
Axle/Gears: CharlesOdory
Hi, I have used it with great success on several cars. I use an unorthodox cleaning method. I clean the plastic parts with lacquer thinner. This softens the plastic and the SEM paint adheres great and has never come off. Many years ago I did the vinyl seats in a Cherokee Jeep and to this day they look new. Use at your discretion.
Louis
Old 11-10-2017, 10:33 PM
86IROC112's Avatar
Car: 1986 IROC Z
Louis
Louis, do you also use an adhesion promoter or just the lacquer thinner to soften? Interesting idea..
Old 11-11-2017, 07:53 AM
Ct1987's Avatar
hi, no adhesion promoter. I wash the parts thoroughly with Dawn detergent. Let them dry and then wipe down with thinner and do the paint as soon as I can while the surface is a little soft. Never had a problem.
Louis
Old 11-12-2017, 02:20 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I used SEM on the rear panels in my vert. Went from a grey to a black. Very satisfied with the SEM and definitely recommend it. I clean them with soapy water and then alcohol. I then scuff them with a red scotch bright pad and prep them with acetone. After painting the vinyl it did not feel crinkly but it can be scratched if a sharp edge is dragged across it with pressure.
Old 11-12-2017, 02:21 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Used it on mine also, going from grey to black. Great stuff and it works well on leather too.
Old 11-17-2017, 12:32 AM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
Axle/Gears: 9", 3.50
I used it black on black. Workout out great. Has held up for a long time.
Old 11-17-2017, 11:34 AM
82tarecaro's Avatar
Use an adhesion promoter. The paint won't scratch off as easily. My painting routine is - scrub with scotchbrite and a degreaser like simple green. Rub it down with acetone, or a plastic prep spray. Then shoot with Bulldog Adhesion promoter. Wait for it to get tacky and then paint.
Old 11-17-2017, 11:36 AM
82tarecaro's Avatar
BTW - you have to be careful with acetone, as it will melt some plastics. Test in an inconspicuous spot first.
Old 11-18-2017, 01:27 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
If I recall they ask you to check with acetone (or something) to determine what type of plastic you have (they say 2 various ones) and 1 requires 1 of their products in particular and the other a different kind of their product. Find the PDF, it notes specifics. I'm happy with mine. Black to Palomino... there were pics on this board, but Photobucket no longer displays it...
Old 11-22-2017, 11:31 AM
86IROC112's Avatar
Car: 1986 IROC Z
Center console turned out incredible... Very pleased..
Old 11-25-2017, 05:47 PM
Tibo's Avatar
Car: 1991 Z28 Vert
How close of a color match is the sem on the center console to the dash?
Old 11-26-2017, 10:25 PM
86IROC112's Avatar
Car: 1986 IROC Z
From what I can see in garage light it's real close. I used the Satin Black color.
Finished all my plastics this weekend and got them carpeted. Man the interior is coming out nice. I can't wait for Spring to start driving her.. It's gonna turn some heads..
