Help! I tried searching no answers for my problem
Old 04-17-2018, 01:57 PM
trevor1010's Avatar
Okay long story short I have an 89 iroc with an 406 hsr it was running perfect before I pulled the engine to change the oil pan. Once I got it back in it wouldn't crank believed to be the coil or module so I just changed the entire distributor since the old one was from 89. Now it will crank and run just shuts off after about 20 secs. I was told to change the plugs since there covered in oil and gas and they're black.. I just wanted some info here before I bought anything else the injectors are accel 32 only 3 years old.... oh and when the timing light is hooked up on the 1 spark plug it doesn't read anything when running. It's fairly new too.. I hope the is in the right forum I need help seriously.. let me know what you guys think.. plugs are accel 3924 I think was previously running 3923 before I pulled the engine
Old 04-17-2018, 03:51 PM
Go Blue's Avatar
Re: Help! I tried searching no answers for my problem
Well, if the timing light isn't flashing then the problem is definitely ignition related. Are you positive that all of the connectors are connected perfectly after the engine was put back in? Check the wiring to the ignition module and coil to make sure that it's tight and all of the spark plug wires are seated. When you can get the engine to start even a little bit, is it stumbling and dieing or just shutting off quickly? If it's stumbling, then there's more than likely an issue with the fuel system. If it shuts down quickly, it's more than likely the ignition system or something else electrical. When you replaced the distributor, did you check to see if the rotor spun when you bumped the engine. Just to make sure that the gears on the cam and distributor meshed? It's generally not the problem, but just thought I would make the suggestion as I've seen it happen once or twice where either the cam gear was trashed or the distributor wasn't set in totally. Just some thoughts off the top of my head.
Old 04-17-2018, 04:08 PM
trevor1010's Avatar
Yes it stumbles then shuts off makes a tapping noise like it starving for fuel the pump comes on it reads 40psi at start and the rotor does spin
Old 04-17-2018, 04:14 PM
Go Blue's Avatar
Do you have HEI or not? Meaning is the coil on the top of the distributor or not? If it is on top, check that spring that the coil sits on as they are known to burn or can go missing when you swap the coil out. Also check the leads from the coil to the electrical connector. Stumbling to me, still sounds like it's fuel related. 40 psi at idle is about right if I remember correctly.
Old 04-17-2018, 04:24 PM
trevor1010's Avatar
No it's not hei and the distributor is brand new it's getting spark at the plug when i had the old the distributor in it wasn't doing anything but turning over now it will crank but it stumbles and the plugs are wet with gas.. can I test the injectors or just try new plugs
Old 04-17-2018, 04:25 PM
Go Blue's Avatar
You can do a resistance check on each injector. If you search on here, i'm sure someone has a spec for it somewhere. I don't remember what it is to be honest. Also, your timing might be off depending on how well you set that new distributor in. Even a tooth off can make it run horribly!
Old 04-17-2018, 04:28 PM
trevor1010's Avatar
Ok are there any chances I may have jumped the timing chain or stretched it it's a double rolling
Old 04-17-2018, 04:31 PM
Go Blue's Avatar
Not likely. But if you set the distributor in and it's even a tooth off 1 way or the other, that throws off everything. Sometimes you can get away with moving the wires, but the best way is to pull the #1 plug and then bump the engine to TDC and see where the rotor is and put the wires on the distributor accordingly. That way, you can possibly mess with the distributor to see if you can advance or retard the timing enough to get it back where it was before you swapped in the new distributor
Old 04-17-2018, 04:36 PM
trevor1010's Avatar
Ya I tried that seems like it's not advancing or retarding when I move it..smh this has me clueless
Old 04-17-2018, 04:59 PM
Go Blue's Avatar
Then you’re at least 1 tooth off from where you should be
Old 04-17-2018, 05:04 PM
trevor1010's Avatar
Ok I'll try to set it again.. any pointers?
Old 04-17-2018, 05:08 PM
Go Blue's Avatar
Bump your engine so that the #1 cylinder is at top dead center and take the cap off of the distributor when you set it in to see where the #1 wire should go. Once it’s in, then, 1 at a time move the wires so that you don’t mess up the firing order of the wires on the cap. Also, make sure that you have them in the correct order.
Old 04-17-2018, 08:07 PM
trevor1010's Avatar
Tried that still the same spined the rotor to tdc and it still cranks them stumbles
Old 04-17-2018, 08:12 PM
Go Blue's Avatar
I just want to make sure that I’m clear on what you did. You took the #1 spark plug out and bumped the engine over until the piston was at the top of the cylinder. Then you moved the spark plug wires so that the rotor on the distributor was pointing to the #1 spark plug wire on the distributor cap?
Old 04-17-2018, 08:19 PM
trevor1010's Avatar
Yes I did that it and it still stumbles with soaked spark plugs I think it's a fuel problem
Old 04-17-2018, 08:28 PM
Go Blue's Avatar
Have you checked the spark from the ignition coil to the top of the distributor by taking the wire off the top of the distributor cap and just laying it there and starting the car?
Old 04-17-2018, 08:29 PM
trevor1010's Avatar
Yes and it has spark at the plugs
trevor1010's Avatar
I was told to change plugs an that will fix it
Old 04-17-2018, 08:32 PM
Go Blue's Avatar
And there’s still no light from the timing light when you can get it to run a little??
Old 04-17-2018, 08:36 PM
zed-028's Avatar
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
fuel is making it as far as the plugs and soaking them, youve got fuel - this leaves spark and air
ive had this with a clogged cat as have others, weak spark is another option. did you confirm whether the timing light was flashing?
trevor1010's Avatar
Not at all.
Old 04-17-2018, 08:38 PM
zed-028's Avatar
if youve got no flash on the timing light, its either dead or you dont have strong enough spark running from the distributor to the leads.
as its the cheapest i would be looking at spark first. Rotor button, rotor and cap.
Old 04-17-2018, 08:42 PM
trevor1010's Avatar
Not at all
trevor1010's Avatar
I'll try that
Old 04-17-2018, 08:44 PM
trevor1010's Avatar
What about to module on the outside of the distributor the one that the single spark plug wire runs too
Old 04-17-2018, 08:48 PM
zed-028's Avatar
the coil, thats also something to check
Old 04-17-2018, 08:51 PM
zed-028's Avatar
if you put the timing light lead on that wire and crank, the light on the timing light will be pretty much solid! - if its not then youve either got a dead light or a dead coil or a broken connection somewhere before the coil - or the dreaded ignition module
chaosseeker
09-24-2006 10:48 AM
993TT
01-23-2002 11:27 AM
Red Devil
02-25-2001 11:40 AM
Quick Reply: Help! I tried searching no answers for my problem
