puzzled
Old 10-20-2018, 08:43 PM
Spenc's Avatar
Car: 84 z
Transmission: 700
Axle/Gears: auto overdrive
puzzled
2000 miles on a new 290 h.p. crate motor with new distributer/ wires/ plugs/ shorty headers/ taller intake/ Rochester carb with 3x14"/: filter /battery/ starter/ temp and oil pressure sensors and ( yes I trust the gauges) flushed and tested 2 row aluminum radiator with Evans coolant/ and a190 degree thermostat. she ran very hot until I got the air out of the block...but...now that it's cooled down here in Detroit it won't climb past 140 even with half the radiator covered over. coming of the highway we climb back to 185 for a while but driving around town it's back down to 140. owned this car for 23 years and sometimes think fondly of that normal and easy going 305. thanks guys for any ideas. spenc
Old 10-20-2018, 08:50 PM
GeneralDisorder's Avatar
Re: puzzled
If it's a fail safe thermostat it may stick open when overheated. You may have to replace it.
GD
Old 10-20-2018, 09:54 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: puzzled
You not running any water with the evans coolant correct?
Old 10-22-2018, 10:55 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: puzzled
What temp thermostat do you have in it and what brand? Like tealman said, failsafes will stick open if they get too hot.
Old 10-22-2018, 12:27 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Re: puzzled
I'd start with the thermostat. Cheap and easy and could very well be stuck open.
Rogue86
09-08-2004 08:00 PM
themodifier
02-29-2004 11:35 PM
nd4spd
11-07-2003 09:27 AM
Justin91RS305
03-16-2002 10:48 AM
Quick Reply: puzzled
