LT5 IROC Vert
Old Dec 27, 2021 | 02:29 PM
BajaDaze's Avatar
Car: 1989 IROC vert UMI sus w/1LE brakes
Engine: 1990 ZR1 LT 5, alum flywheel
Transmission: Tick built T56
Axle/Gears: 3.7 Borg Warner
LT5 IROC Vert
First off I would like to give a huge thank you to those with intelligent posts insights and responses, they have been invaluable through the course of my build. I know there have been a number of attempts at this chronicled on TGO but this is the story of a completed LT5 IROC build.
I purchased my 1989 IROC vert in 2014 it had been sitting on the side of the road for 6 years and still rust free which was amazing. After having it trucked home we got it running but the 5.0L TPI engine and trans were shot and it did not run very long and leaked like a sieve. As these things tend to snowball, I found a wrecked 1989 IROC with 5.7L TPI with same dove grey interior. I installed the 5.7L engine and trans along with the 9 bolt Borg Warner rear end with discs and PBR calipers. After swapping the engine, trans, 3” exhaust and rear end along with a complete suspension rebuild including all bushings my vert was on the road again. I then picked up off CL a set of 1LE front spindles with brakes and along with new braided SS brake lines and the car was again on the road and but it was not for long before the 2nd trans went out. At this point we located a T-56 from a 97 Camaro SS and the vert was back on the road and a lot more fun to drive. In 2018 after spending 4 months doing body work, swapping a door, a fender, rear bumper cover and the hood my IROC vert was finally painted in a Lexus tri-coat white color. At this time the Hawks 17” IROC 2 vein wheels were installed and we upgraded the rear gears to 3.73 with a stud girdle cover. So finally after 4 years of numerous upgrades, starts and stops my vert was on the road looking great and fun to drive. So the summer of 2018 and 2019 I put some miles on it attended a few car shows here in the PNW. Then in 2019 the upgrade bug hit me once again when I saw a 1990 ZR1 LT5 engine for sale with only 17K miles on it. I gotta tell you this is one of my favorite engines of all time and I had to have it. After a cross state road trip I had a LT5 sitting in my garage and was ready to tear my vert down again. After almost 2 years my vert is on the road again. Installing a LT5 in a 3rd gen takes some ingenuity and creativity. Originally I was going to use all of the stock sensors, ECM, waste fire coils, engine wiring harness etc. After some deliberation we decided to treat it like an LS engine and installed 8 LS coiIs with custom mounting system under the pleneum, removed the vacuum controlled secondary butterflies, ported the intake housing and plenum, deleted the throttle body coolant, built a custom wiring harness, modified the existing 1997 LT1 bell housing and drilling tapping 1 new bolt hole in the block. Machined a custom billet fuel block for the existing fuel rails.
I used the following major components in this build;
UMI K-member (modified)and control arms
Dirty Dingo adjustable LS engine mounts
MegaSquirt MS3 EVOPro ECM with a flying harness
OBX SS ZR1 headers, JetHot coated modified for the 3rd gen cross member
Holley 2.5” true dual SS header back exhaust system
Custom crank trigger based off the Holley kit
Custom dual 3” intake
4th Gen fuel tank with a Aeromotive 340 LPH pump
New 3/8” SS fuel lines from the tank to engine compartment
BMR remote mount battery tray
Fidanza flywheel
Per Marc Haibeck, based on the engine mods I have done this should be putting out 450+ HP at the crank based on his experience with these changes. On my first outing I can tell you this thing is crazy fast with a 7,500 RPM redline compared to the old TPI engine
For those of you not familiar with the engine or need a refresher as there are many incorrect posts about this engine please see the link below;
https://www.lsxmag.com/features/c4-zr-1-lt5-engine/
Cost wise this came out very close to a high end LS swap and parts are plentiful you just need to know where to look.
A big shout out to my son Cody who was with me all the way, my very good friend Soloc4, Bruce and his crew at Hawks, Mario from the Dub Shop for MegaSquirt tuning, Jerry’s gaskets, and Marc Haibeck ZR1 expert extraodinaar.
Old Jan 2, 2022 | 05:55 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: LT5 IROC Vert
I remember the first time a Chevy rep brought one of these (ZR1) around for us to see...balanced a nickel on edge on the running engine. I thought it was one of the cooler things I had seen in my (then) young life.
Congrats on a very cool build!
Old Jan 3, 2022 | 12:28 PM
Big&BadGTA's Avatar
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
Re: LT5 IROC Vert
Sharp.
Old Jan 4, 2022 | 05:02 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Re: LT5 IROC Vert
OMG! My Holy Grail! That's the only engine I'd swap the for our generational TPI. I've had my eye on one, but it'll take a lot of stimulus checks for that to become a reality lol. Beautiful car, too, btw.
When I saw the title of this thread, I expected to see the new LT5. So when I saw this one, I, well, it was like looking at ****!
Old Jan 4, 2022 | 05:25 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: LT5 IROC Vert
Very very cool! Have any pictures from the bottom?
Something I've always wanted to do to a thirdgen, on my bucket list !
Old Jan 4, 2022 | 08:00 PM
Buddy's Avatar
Car: '87 FIREGOOSE!!!!
Re: LT5 IROC Vert
OBX SS ZR1 headers, modified for the 3rd gen cross member
Fidanza flywheel
Amazing, just amazing! Right there is the next "car of the month". Always loved the LT5, power has surpassed it, but it still remains a star.
Old Jan 4, 2022 | 10:33 PM
BajaDaze's Avatar
Re: LT5 IROC Vert
A couple of pics from below
Modified UMI k-member and modified DirtyDingo engine mounts
LT5 & L98
Old Jan 4, 2022 | 10:40 PM
BajaDaze's Avatar
Re: LT5 IROC Vert
Custom fuel rail feed and return block
Custom air intake
Some custom parts required for this build
Old Jan 4, 2022 | 11:16 PM
BajaDaze's Avatar
Re: LT5 IROC Vert
Modified fiberglass heater box
Bell housing starter ear removed for header clearance. LT5 starter is in the lifter valley area
Modified OBX ZR1 headers. First 2 tubes rerouted to clear the crossmember and the new fiberglass air inlet to the side of the photo
Custom LSX high perf coils and custom mount. Originally was a waste fire engine
More detailed work behind this build
Old Jan 5, 2022 | 07:22 AM
Abubaca's Avatar
Re: LT5 IROC Vert
Wow! Dang! Very nice!
Old Jan 5, 2022 | 02:06 PM
TTOP350's Avatar
Re: LT5 IROC Vert
Very cool, this reeeeeeally warms the heart, I love the detail shots!
Old Jan 5, 2022 | 05:15 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: LT5 IROC Vert
Definitely like the details of the build story. Keep it coming!
Old Jan 9, 2022 | 10:56 AM
BajaDaze's Avatar
Re: LT5 IROC Vert
Trunk mounted BMR battery tray and in-line circuit breaker
Old Jan 9, 2022 | 11:20 PM
LC2 TECH's Avatar
Re: LT5 IROC Vert
I always wanted to do a LT5 since the Moss Camaro in the 90's. Nice work!
Old Jan 10, 2022 | 10:51 PM
dagwood's Avatar
Top Answer: 1
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
Re: LT5 IROC Vert
INCREDIBLE
Old Jan 11, 2022 | 02:34 PM
88IROCvertZ's Avatar
Car: 1988 IROC Z Convertible
Engine: 305 TPI (LB9)
Transmission: 700 R4
Axle/Gears: G80 GU2
Re: LT5 IROC Vert
Every time people would ask “what should I swap in a Thirdgen that’s not another LS?” I always suggest LT5…
This is a dream build! Amazing!
Old Jan 13, 2022 | 02:25 AM
Neil350's Avatar
Car: 93 Trans Am
Transmission: T56 Street Twin
Axle/Gears: 12 Bolt 3.90
Re: LT5 IROC Vert
This is an incredible build, congrats on getting it done
Old Jan 13, 2022 | 09:34 AM
scholtmj's Avatar
Car: 88 Trans Am Hardtop
Engine: 350 L98
Transmission: Stock 700R4
Axle/Gears: 3.27 Aussie 9
Re: LT5 IROC Vert
Very cool! The sound of an LT5 with headers is something. My old 368" LT5 had Jeal intake cams which created a little lope at idle - fun fun car.
Old Jan 16, 2022 | 08:29 AM
BajaDaze's Avatar
Re: LT5 IROC Vert
SS fasterners
Dual 2.5" Hooker SS exhaust
9 bolt BW diff with girdle
Old Jan 16, 2022 | 08:33 AM
BajaDaze's Avatar
Re: LT5 IROC Vert
Dove grey interior
Pioneer 1.5 din stereo with remote
L98 gauge pack
Old Jan 16, 2022 | 08:35 AM
BajaDaze's Avatar
Re: LT5 IROC Vert
Old Jan 24, 2022 | 07:20 PM
Double's Avatar
Car: 1985 Iroc-Z (yellow)
Engine: LB9
Transmission: MXO
Axle/Gears: GU6, G80, J65
Re: LT5 IROC Vert
Man this is awesome!! A lot of ingenuity went into the swap which makes it even better you did it yourself. Appreciate the detailed thread too. What is your profession if you don’t mind me asking?
Edit: The reason I ask is clearly you've got some mechanical skills and access to some cool tools.
Old Jan 24, 2022 | 08:17 PM
ramblingarage's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7 TPI
Re: LT5 IROC Vert
This is awesome and really well done. How does the body/chassis hold up to torque twist?
Old Jan 25, 2022 | 03:09 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: LT5 IROC Vert
Oh man its so beautiful. One of my favorite engines! Do you have a video?
Old Jan 25, 2022 | 11:38 PM
BajaDaze's Avatar
Re: LT5 IROC Vert
Thanks to all for your complements and support
Old Jan 26, 2022 | 11:33 AM
Arctic White 91 RS's Avatar
Car: 91 RS/ 99 T/A/ 72 Vette/ 02 Z28
Engine: LSx/ Dart400
Transmission: M6/ M6/ TH400/ 4L60E
Axle/Gears: 4.10's / 3.08/ 2.73
Re: LT5 IROC Vert
That definitely a cool & unique swap!
Nicely done! A++
Old Jan 26, 2022 | 07:40 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: LT5 IROC Vert
Did you do anything to that 9 bolt internally?
Old Jan 27, 2022 | 08:31 AM
BajaDaze's Avatar
Re: LT5 IROC Vert
Nothing fancy, new bearings, Ratech pinion crush sleeve, Motive 3.7 gear set and a truss cover. I set the gear lash tolerances to the low end of the range with a solid tooth contact pattern. I know I am at the upper end of the torque limit for the 9 bolt but I do not drop the clutch and abuse it, we'll see this summer how it does.
Old Jan 27, 2022 | 07:10 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: LT5 IROC Vert
I worry about my 9 bolt sometimes. I dont abuse it, but id like to get something a bit stronger. Even a dana 44 would be nice.
Old Feb 21, 2022 | 02:42 PM
BajaDaze's Avatar
Re: LT5 IROC Vert
I have finished the last of my major updates under my car. I have installed UMI's subframe connectors. Due to the fact that I am not running the stock exhaust I beefed up the passenger side subframe connector that connects from the UMI bracket across to the front subframe. I replaced the short little 1" cross brace with a 1 1/2" square tube. I have also installed Founders LCA brackets and boxed in my lower control arms since the had new bushings in them.
Turning my attention to the front end I wanted to fine tune my ride height so I installed a pair of UMI weight jacks to provide that ability. So happy to be done with these updates, I can't wait for the weather to break now.
UMI subframe and Founders LCA brackets
Boxed in lower control arm
So easy to install compared to standard springs
Modified pass side with heavier cross brace compared to the kit provided brace
Old May 28, 2022 | 01:34 PM
BajaDaze's Avatar
Re: LT5 IROC Vert
I finally had my car on the Dyno to finish tuning the MegaSquirt EVO PRO. Here is the final pull on the Dyno for my LT5. What blast to drive now.
Old May 29, 2022 | 12:19 PM
BajaDaze's Avatar
Re: LT5 IROC Vert
At Carb Connection in Kirkland. They were awesome to work with and very knowledgeable.
Old May 29, 2022 | 12:45 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: LT5 IROC Vert
Oh sweet I was looking for a local dyno so I can be empirically disappointed by my engine's output.
Old Jan 1, 2023 | 02:38 AM
brians240z's Avatar
Want a title? Post!
Re: LT5 IROC Vert
What did you do to integrate the trans to the engine?
Old Jan 1, 2023 | 07:56 AM
BajaDaze's Avatar
Re: LT5 IROC Vert
Interestingly, GM I their infinite wisdom had Lotus maintain the standard Chevy bell housing, crank to flywheel mating surfaces and pilot bearing the same dimensions as a LT1/L98 smallblock. I was able to reuse the T56 I had in my car from a 97 Camaro. I did need to drill and tap 1 bell housing bolt and cut the starter ear off the bell housing for header clearance. Fidanza had a 8 bolt flywheel the matched my old LT1 flywheel. So fire a lot of measuring and calculating it all worked out.
Old Jan 1, 2023 | 10:57 AM
LAFireboyd's Avatar
Re: LT5 IROC Vert
In 2018 my IROC vert was finally painted in a Lexus tri-coat white color.
Then in 2019 I saw a 1990 ZR1 LT5 engine for sale with only 17K miles on it. I gotta tell you this is one of my favorite engines of all time and I had to have it.
OBX SS ZR1 headers
Those look like the louvers Mr. IROC-Z had on his carbon fiber IROC hood. I like that they're so open and allow a great view of the LT5, sort of an IROC version of a C6 ZR1 hood window. In the category of engines worthy of being on display, the C4 LT5 is definitely one.
I was curious about the paint color. It looks like a soft, pale, cool, grey tone, rather than a bright white, but it could just be the lighting. It works well with your silver and grey accents and interior.
For the dreamer in others of us, there are two LT5 engines for sale on ebay that I've been watching for several months.
Your car should be a poster child for OBX. Somewhat of an "ebay" brand, basically big brand knockoffs, but the products look good, and the prices are very reasonable. Nice to see them on such a major project. New OBX headers and y-pipe are still floating around for TPI engines, like a Hooker 2055 knockoff, for about half the price of the Hookers.
Old Jan 1, 2023 | 05:51 PM
BajaDaze's Avatar
Re: LT5 IROC Vert
Thanks, yes Mr. IROC Z inspired my hood louver cutouts. The color is a 2015 Toyota/Lexus tri-coat white. It is a white metallic base with a pearl on top then clear coated. I just couldn't go back to refrigerator white.
I have started my winter projects. First off was installing an adjustable UMI panhard bar to center my rear axle.
The second update was going with the UMI camber plates and ditching the stock ones. The old plates left some nasty paint lines so I sanded down the strut towers and resprayed them.
I have also pulled my T-56 trans and sent it off to Tick for a rebuild and some upgrades. Pulled the clutch while I was at it and ordered a McLeod Super Street Pro clutch.
Old Jan 1, 2023 | 06:27 PM
Thirdgen89GTA's Avatar
Transmission: M28 T56
Re: LT5 IROC Vert
Oooh, I like this very much.
Old Jan 29, 2023 | 01:57 PM
BajaDaze's Avatar
Re: LT5 IROC Vert
More winter time projects. I have installed a UMI on-car adjustable panhard bar to get my axle back centered. Pulled the T56 and shipped it back to Tick Perf. for a full rebuild with some upgraded goodies. Installed a McLeod Super Street Pro clutch. I also picked up at SEMA this last fall one of Red Roberts Quik Stik shifters. Red was the founder of McLeod clutches, very interesting guy with lots of stories. Also replaced my speedo cable that got fried during my Dyno session .
I can't wait for spring here in the PNW to drive with my new upgrades.
Old Jan 29, 2023 | 02:54 PM
BajaDaze's Avatar
Re: LT5 IROC Vert
To answer a few questions I have received on my build concerning what I started with. Back in April of 2014 I found my car on a local CL add. It had been parked for 6 years and was some kids old high school car. It was amazingly rust free but very moldy and smelly but I just had to have it. Original plan was to restore it but after tearing into it it just wasn't that car, so I went the restomod route and never looked back. Here is what it looked like when it was towed home and washed it for the first time.
Old May 22, 2023 | 10:45 AM
C5rider's Avatar
Re: LT5 IROC Vert
Awesome swap. Nice to see a non-LS-based swap once in a while. Very nicely done!
Old May 27, 2023 | 03:44 PM
BajaDaze's Avatar
Re: LT5 IROC Vert
Since completing my built last year I have gotten some media exposure. An article on my car just dropped this morning in Chevy Hardcore magazine, check it out at;
https://www.chevyhardcore.com/featur...9-iroc-camaro/
Here is an Instagram clip from RADWood PNW last summer by car host Chris Jacobs;
View this post on Instagram
Old May 28, 2023 | 08:43 AM
Buddy's Avatar
Re: LT5 IROC Vert
Congrats on the coverage, well deserved!
Old Aug 3, 2025 | 05:24 PM
???'s Avatar
Re: LT5 IROC Vert
wow.. this is an amazing build. I'm sorry I missed this build. is there a thread somewhere? the into on swap details is pretty hard to find these days
I'd love to do this to mine someday.
that's offset t56 shifter is interesting too. I have a lt1 t56 setting around waiting for this t5 to break. but I guess I just don't drive it enough haha
Old Aug 10, 2025 | 09:07 AM
GearheadSS's Avatar
Car: Yellow Gold 1986 IROC-Z
Engine: LG4 305
Re: LT5 IROC Vert
This is one of my favorite builds. I love the LT5 in there. Great job!
Old Aug 10, 2025 | 06:53 PM
BajaDaze's Avatar
Re: LT5 IROC Vert
Thank you for the comments, much appreciated.
Old Yesterday | 01:26 AM
MaverickTAGTA's Avatar
Want a title? Post!
Re: LT5 IROC Vert
Firstly, incredible build, probably one of if not the coolest IROCs I've ever seen.
Secondly, I was referred to your project by Marc Haibeck of Haibeck Automotive as a reference for my own project. I have a 1992 Pontiac Trans Am GTA (pictured below along with my '05 SSR,) and was able to pick up a 19k mile LT5/ZF6 combo out of a 1992 ZR-1 that I plan to swap in place of the current 5.0 TPI/700R4 motor and drivetrain that's in it, and was looking to Marc for advice on any relative difficulties that I am bound to run into.
That said, would it be too much of a burden for me to look to you as well if I have any questions or run into any difficulties?
Thanks in advance for your considering my request!
BajaDaze
Jan 10, 2022 09:03 PM
91z4me
Jul 31, 2001 07:55 PM
91z4me
Jul 8, 2001 04:55 PM
IROCwrangler
Jun 2, 2001 01:43 AM
avro206
Apr 30, 2001 01:53 PM
