TPI fuel lines
Old Feb 28, 2026 | 04:33 PM
SteveC68's Avatar
Car: 1989 IROC
Engine: 5.7L
TPI fuel lines
I have an 89 5.7 TPI car. It looks to be pretty stock but has been in a field for 25 years. I'm in the process of pulling the motor and have a question about the fuel lines. Under the hood on the drivers side where the hard lines that run from and back to the tank terminate, there is a short section of flexible line that goes to the small hard lines from the fuel rails. Both of these (pressure and return) are covered in that corrugated plastic.
These are the lines I'm talking about. Are those available new?
Old Mar 1, 2026 | 11:10 AM
Vader's Avatar
Re: TPI fuel lines
They used to be, It may be about the time in the life cycle of parts that no one wants to dedicate a storage bin to parts for a 40-ish year old vehicle, and you may need to fabricate hose sets on your own. If the metal lines and fittings are intact, replacing just the fuel hoses and convoluted tubing should be easy enough. If the lines are fittings are corroded, you would at least have a reasonable pattern to match lengths and bends.
Old Mar 1, 2026 | 06:55 PM
SteveC68's Avatar
Car: 1989 IROC
Engine: 5.7L
Re: TPI fuel lines
Is there a fitting that will adapt whatever the stock fuel fitting is to an AN fitting?
Old Mar 1, 2026 | 07:09 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: TPI fuel lines
https://www.thirdgen.org/forums/tech...fuel-need.html
Old Mar 1, 2026 | 07:33 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Re: TPI fuel lines
Take them off. Take them to a hose house/store. Have them make you two new ones. Easy Button.
Old Mar 3, 2026 | 06:19 PM
wmccallum13's Avatar
Car: 1991 Firebird Formula
Engine: LB9
Transmission: Five speed
Re: TPI fuel lines
I did fuel lines pretty recently, local GM dealer was able to get me a new ACDelco return line pretty easy. The GM website told me some dealership in the Carolinas had the feed line, called em and they said there was maybe two new ones in existence that they knew of on their system or whatever. Needless to say, I had to go NOS for the feed, so I wouldn’t say new ones really exist anymore.
Old Mar 4, 2026 | 06:40 PM
Luis1991's Avatar
Car: 1991 Z28
Engine: 5.7
Re: TPI fuel lines
https://www.hawksmotorsports.com/82-...livery/?page=3
Old Mar 5, 2026 | 10:44 PM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Re: TPI fuel lines
When I did my TPI conversion, I used AN fuel hose with AN to saginaw adapters to the hard lines. Russell has the adapters.
Fred
Old Apr 23, 2026 | 05:22 PM
Mikos_89's Avatar
Car: '89 GTA, '15 Camaro LS 6sp.
Engine: L98, LFX.
Transmission: 4L60, AY6.
Axle/Gears: 3.27's.
Re: TPI fuel lines
What company does this?
Old Apr 23, 2026 | 05:54 PM
Engine: LT1, L400
Re: TPI fuel lines
Any hydraulic hose supply shop. In my area, that would be EVCO house of hose, Hose & Rubber, in your area, that'd likely be....
RIGHT HERE
Old Apr 23, 2026 | 07:15 PM
Mikos_89's Avatar
Engine: L98, LFX.
Axle/Gears: 3.27's.
Re: TPI fuel lines
RIGHT HERE
Thanks. I think they have a place called Hose Specialists near me, maybe I’ll check them out.
Zach/90\irocZ
May 21, 2019 10:50 AM
89RESTO
Sep 18, 2008 04:32 PM
pandorafowler
Apr 29, 2005 09:51 PM
RED91Z
Feb 24, 2003 04:01 PM
383 rocket bird
Nov 6, 2002 09:36 PM
