automatic headlights on a 3rd gen?
Old Apr 24, 2026 | 09:16 AM
Stewbawl's Avatar
I have become spoiled by my newer cars and take their automatic headlight shutoff for granted. at least once a year i forget and leave my headlights on and return to a dead battery. has anyone attempted or documented adding this feature or something similar to their 3rd gen? not the dead battery feature, the headlights turning off when the car is turned off feature.
tldr: left my lights on and my battery died, so i had to drive the jeep into work today and I'm whining about it.
Old Apr 24, 2026 | 09:36 AM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: automatic headlights on a 3rd gen?
Fix the buzzer in your convenience center.
Old Apr 24, 2026 | 10:39 AM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
Originally Posted by Stewbawl
has anyone attempted or documented .
i think dakota digital has a thingie that makes it full auto
Old Apr 24, 2026 | 11:34 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Haven't seen it, but knowing how those systems work it'd be a fairly simple (but totally custom) install. You'd need the light sensor for the dash, headlight switch, and the associated pigtails. Then it's just a matter of wiring things up.
You probably wouldn't have a push-pull style switch when it's all said and done though.
Old Apr 24, 2026 | 04:33 PM
It'd be pretty simple to leave the stock switch in there and just add the other in parallel with it... as in, the HLs and TLs are turned on if EITHER the switch is pulled, OR the "module" calls for them to be on.
Old Apr 24, 2026 | 05:40 PM
exiled350's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 427ci Gen 1 Small Block
Axle/Gears: Strange60 4.10 Eaton Truetrac
Pretty simple if you know a little EE and C programming. An ESP32 and a few transistors you're in business. I might actually see about doing this myself once I'm done with my interior lighting control.
Old Apr 24, 2026 | 08:08 PM
vorteciroc's Avatar
Top Answer: 1
Just purchase an inexpensive 12v DC Photocell Switch from anywhere online... something under $20.
...That and a basic Relay, boom, done!
Old Apr 24, 2026 | 08:37 PM
ULTM8Z's Avatar
2nd gen here, but the same basic circuits...
Just wire one of these up in parallel with your existing headlight switch.
https://www.amazon.com/aqxreight-Automatic-Headlight-Universal-Modification/dp/B0C7444WLY/ref=mp_s_a_1_5?crid=33D4RUH4V3D1Q&dib=eyJ2IjoiMSJ9.W_c4GOXrxOgJNe4Hef79tBP9CA2TtvO21cdoF23xsRUS5YKth-_C5Rk61oarIgyGebZr1D8wtTlAz2QBGUQGahHq7MC5u6Ic3xz3G66g5sp3jBNwSwhUx6uZ7_cedePn1RixCguDHR0nkael9DWBo4wOo9fkLjEGZyRxACFIgiG6xQLKqIKFcNm4ia4viIYszv-RVBELh7_bBTI-9hYsUw.2D8wo5PPNE_GYafDDdMTmnXxa8PsdL0_AQdUy-PBYzc&dib_tag=se&keywords=automatic+headlight+sensor+kit&qid=1777080642&sbo=RZvfv%2F%2FHxDF%2BO5021pAnSA%3D%3D&sprefix=automatic+headli%2Caps%2C207&sr=8-5
I took a step further and put in a custom switch from Rocker Switch Pros thst will deactivate the automatic module if I don't want the headlights on. Also put in an indicator light that illumates when the headlights turn on.
Old Yesterday | 05:56 PM
FlyDoc's Avatar
Car: 92 RS
Engine: 94 LT1 383
Transmission: T56-6 Speed
Axle/Gears: posi, 3.26:1,
just put a relay in for the main power for the headlights. the activation for the relay be connected to the "on" position of the ignition switch. then the headlights will be on and off with the ignition
Pr0p13
Apr 13, 2021 11:58 PM
IROC-WS
Jan 30, 2021 05:52 PM
G8T8A
Sep 15, 2006 05:17 PM
Ovrclck350
Nov 1, 2001 04:34 PM
