Rad Fan Not Working After ECM Delete
Old Yesterday | 08:49 AM
surfer_brooo's Avatar
Car: 1986 Trans Am
86 TA originally came with computer controlled carb. I swapped the 305 for a 350 and removed the wiring harness to the computer. Everything is working great except the fan is not kicking on. I have checked and the fan connector is getting 12V with the key on and the engine hot, and no voltage when it is cooled back down. But for some reason, the fan is just not turning on. This is leading me to believe the fan motor is bad, but I just want to make sure that I'm not missing something and that unplugging the ECM shouldn't have an effect on the fan. It is just odd because the fan was working properly before, and I am getting voltage to the connector.
The fan did sit outside for a couple of weeks while I was doing the swap, I can't remember if it rained during that time. Could that have caused the motor to die on me? I did check and the fan itself is not seized up.
Old Yesterday | 09:27 AM
LLCooLM495's Avatar
Car: 1992 Firebird
Engine: 3.1L LHO
Transmission: Tremec TKX
Axle/Gears: 3.23 Torsen
Re: Rad Fan Not Working After ECM Delete
I don't have access to TunerPro or any BINs at the moment since I'm at work, but there's a decent chance that the fan is ECU controlled to some extent, like in a '92. I don't know for sure off the top of my head for an '86 305, but I do know that ECU fan control (on/off at certain temps/ speeds) was present on at least some thirdgens. If your motor has two coolant temp sensors (usually one in the head with a button connector for the gauge, and a 2 wire in the intake for the ECU), then the relay might just not be getting the signal to send power on to the fan. If this is the case, I believe it is possible to set up a separate trigger system for the fan with a switch that turns on/off at a specified temp without going through the ECU.... there oughta be some folks on here who've gone through the same thing before who can provide more details, but reckoned I could at least throw out a possibility as to why the fan won't kick on.
Old Yesterday | 09:29 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
The fan relay is triggered by the ecm. There are 2 coolant temp sending units, one for the gauge, one for the ecm. Since you now don't need to tell the ecm anything, use that port to put in a sending unit to trigger the fan relay at the temperature you need.
Old Yesterday | 10:08 AM
Car: 1986 Trans Am
So, to add a little context here. The car originally had 3 temp sending units. The one on the driver side head for the gauge, the one on the passenger side head for the fan, and the one on the thermostat housing which I assume went to the computer. I now have both the temp sending unit and the fan switch relocated to the intake due to fitment issues in the new heads. The third switch in the thermostat housing has been removed.
If I'm understanding correctly, I need to connect the fan switch directly to the relay? Sorry, I'm very much a noob when it comes to electrical and I am trying to learn.
Old Yesterday | 10:12 AM
Car: 1986 Trans Am
Also, how could the fan connector be getting 12V if the relay is not being triggered, and how could the fan not kick on if it is getting power?
Old Yesterday | 10:41 AM
LLCooLM495's Avatar
Car: 1992 Firebird
Engine: 3.1L LHO
Oh interesting, hadn't heard of the 3 sensor setup... just did some digging and came across a thread from 2009, here. Posts #11 and #15 might help you out, turns out I was indeed barking up the wrong tree with the ECU. If you had the switches out at any point, there might be a chance that you accidentally swapped the two head sensors... they both use a similar blade connector, entirely possible that they just need to be swapped. I'm well into unfamiliar territory now though, so I'll let you check that thread out for yourself, guy was running into the same situation as you
Old Yesterday | 10:43 AM
Car: 1986 Trans Am
Thanks for the link! I will check it out.
Old Yesterday | 12:08 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
I thought curbed cars didn't use the ecm to trigger the fan? I thought that was just TPI cars.
if so, then it would use the fan switch in the passenger head to ground the circuit and activate the fan.
Yu could try grounding the wire to see if the fan comes on. It could be the location doesnt have a good ground, or the switch went bad?
Take the fan out and see if it works with 12v applied
Old Yesterday | 03:50 PM
hmm, you may be right. The ecm may not have had the relay trigger in the earlier cars. My brain automatically thought of the efi ecms.
Old Yesterday | 03:51 PM
Yeah I'm pretty sure also that the carb ECM doesn't work the fan. Only the fan switch.
The fan connector "is getting 12V", if measured with a multimeter or the like, because the meter is looking at 12V through the relay coil, which is only a few k ohms. That's exactly what you should be seeing.
As said, ground the fan switch wire with the key on, and the relay should click, and the fan start running.
The 2 [mr_spock] sen-sores [/mr_spock] in the heads, neither of which is actually a "sen-sore", are the temp gauge sending unit, and the fan switch. The only "sen-sore" is the 2-pin one with a yellow and a black wire, that was originally in the water outlet. The other 2 have very different connectors from each other. The temp gauge one has the old-style "nail head" thing if it's still original, or maybe a blade if it's a replacement; the fan switch is a single-pin round Weatherpak.
screeminchicken
Jun 18, 2021 12:31 PM
fubar_1179
Aug 4, 2009 10:42 PM
ReverendZ28
Jun 27, 2007 03:33 PM
Zokal
Nov 14, 2005 08:55 AM
lighthorseozzy1
Nov 17, 2003 05:54 AM
