If you can figure out my pictures... Here is the OEM N10 collector Y. 4 pictures of the inside of the pipe. You can clearly see how the outer (passenger side) pipe goes into the collector too far. I ordered an extended length die grinder, and I'm going to cut back the inside pipe, so it matches the contour of the collector. When people talk about this setup losing 10 HP. This is the only reason, besides the crushed outer pipe.
I should have been more clear. That is only 1 N10. I took pictures of various angles. Too many pictures I guess. But it was hard to get lighting in there. The driver's side is not restricted at all; it flows straight into the collector. The passenger side where it comes too far into the collector definitely needs a trimming. Also, the passenger side pipe is concave along the fender. It the passenger side pipe can be cleaned up, and replaced with a not crushed pipe, I bet it would flow as good as a magnaflow.
N10 is mass production, Mass production is just that, produced for the masses. GM set tolerances, and 100's of them got welded up.
I just checked mine, all original, and it’s the same way.
I'll say it again: N10 is mass production, Mass production is just that, produced for the masses. GM set tolerances, and 100's of them got welded up.
Aftermarket will tweak every little oz out of it, but mass production has it's limitations. It's a manufacturing process that is setup for 1000's of cars.
Yes, and mass production has variances. Hence my question a few posts up.
I don’t think there were any variances. I think they were all made like that with the outside pipe sticking out into the exhaust stream at the Y merger. Still, it provided a nice 10hp gain over the single cat cars.
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Re: N10 Collector Y
Originally Posted by 86blackiroc
Was the connection that bad on all of them? Or is this one worse than others?
All of them I have seen are like that. I haven't peeked up the 1991.5 to 1992 N10 Y-merge pipe though but I think all they changed was the connection to the intermediate pipe from the "Hog" clamp to a slip fit connection.
This is after an hour with a die grinder. I brought at extended length die grinder off Amazon. Please compare these with post #1. All I need to do now is hollow out the CATs.
