Cooling Fan back to stock?
Old May 30, 2026 | 03:31 PM
cotto1122's Avatar
Trying to get my fan back to the stock setup. It appears someone at some point wired a single fan to the fuse box, which I don’t like. As soon as accessory is turned on the fan kicks on. I have the wiring still in the car which I believe is these two plugs pictured below coming from a relay by the battery( guessing the car was stock 2 fans?). Where does the wiring come off to go to a temp switch?
Obviously previous owner switched it around for some reason, am I chasing an issue trying to revert back to the stock wiring. Or is there a better safer way than having it directly wired to fuse panel under the dash.
foxnotgrey
Sep 14, 2014 12:16 AM
JohnnyCamaro91
May 17, 2011 12:59 PM
maks10
Oct 9, 2009 11:22 PM
wdigitog
Sep 21, 2007 07:43 PM
CaptPicardsZ28
Mar 4, 2004 05:14 AM
