Seat Belt Retractor
Old Jun 4, 2026 | 10:01 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
Seat Belt Retractor
My problem is not that the seat belt will not retract, I have to help it retract on the driver's side by pushing it back.
Any of you fellows have that problem?
I am familiar with the repair where the seat belt is locked, fully extended, so that it will not retract at all.
i have viewed a youtube video repairing/rewinding the spring. Not sure that I want to try that. Like rewinding the spring in an old school alarm clock.
If the spring broke or unwound, I would assume that it would not rewind at all. Also there is a " pretensioner" that locks the belt in a collision or sudden stop.
I believe that it could also block the retracting of the belt.
Comments?
Old Jun 4, 2026 | 11:05 AM
Beeman's Avatar
Re: Seat Belt Retractor
I struggled with slow or non retracting seat belts on a few vehicles and then learned a trick. You can laugh all you want but it works. Pull the seat belt out all of the way and put a spring loaded clip on it to prevent it retracting. Get a bucket of warm water with laundry soap and soak the belt and keep swishing it around. You'll probably be disgusted with the amount of dirt you get from it and will have to change the water a few times. Last bucket should be clear water to rinse it, then leave it out overnight to dry.
Old Jun 4, 2026 | 10:37 PM
dannyual320's Avatar
I have actually read on a different forum that this is the way to fix seat belts that won't retract. My 2001 Ford F250SD diesel's driver's side seat belt doesn't retract. I need to wash it good and get it retracting again.
Old Jun 5, 2026 | 08:45 AM
72buickgs's Avatar
Car: 1984 Trans AM
I found a company name SafetyRestore.com who can repair the seatbelt retractor problem that I have.
My car's seatbealts are clean as a whistle. Car only had 23000 kilometers when I got is in 2021.
I intend to check the "pin" problem to see if modifying it will rectify the problem
Old Jun 5, 2026 | 08:14 PM
Drgnbld's Avatar
Car: 89 GTA
Transmission: auto
Axle/Gears: 3.23 BW 9 bolt
My sons car, 2010 Acura TSX seatbelt did the same thing, I took a bucket of hot soapy water and let the belt portion soak for 30 min. Once it was dry it worked correctly again. The water was brown afterwards.
Old Jun 5, 2026 | 10:56 PM
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Wow TY all. I did see that some people had help in just cleaning the seat belts with a quick wipe down, which also slightly helped me. But this sounds like a 'nuke it' solution. I'm going for it in the AM! I'll post results.
Old Jun 6, 2026 | 08:49 AM
Good luck and let us know how it goes.
I really need to do this to my truck's seat belt. I'm going to clean it in a bucket of soapy water and let it air out.
Old Jun 8, 2026 | 09:06 AM
72buickgs's Avatar
Car: 1984 Trans AM
In order to wash the Firebird seatbelts, one would have to remove the seatbelt assembly completely from the car. Correct?
Old Jun 8, 2026 | 09:19 AM
According to Beeman in post #2, it appears that you can do this with the seatbelt assembly still in the car.
Old Jun 8, 2026 | 09:51 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Check out this thread, common issue: https://www.thirdgen.org/forums/faq-...ro-z-28-a.html
Old Yesterday | 08:35 AM
72buickgs's Avatar
Car: 1984 Trans AM
In the video, what is the purpose of the spring loaded arm?
Old Yesterday | 09:44 AM
Car: 1983 Z28
Not sure what video, but if it's the little on the outside of the retractor, that is for the "comfort fit" adjuster. They typically fail and cause the seat belt to stop retracting.
HeavyChevy383
Oct 16, 2022 01:23 PM
kitt23
Sep 26, 2015 07:48 PM
10secondhopeful
Oct 16, 2008 11:09 AM
