DFI and ECM Discuss all aspects of DFI (Digital Fuel Injection), ECMs (Electronic Control Module), scanners, and diagnostic equipment. Fine tune your Third Gen computer system for top performance.
How do you read fault codes?
Old Oct 1, 2005 | 07:56 PM
Welsty2003's Avatar
Car: '91 Firebird
Engine: 3.1 V6
Hi all,
My girlfriend's V6 '91 Firebird is only managing about 20 MPG and the engine stops whenever you pull up to a junction or roundabout (It's an auto box by the way). I was thinking it might be helpful to be able to read the fault codes. How do i go about doing this? Any help much appreciated.
Old Oct 2, 2005 | 06:50 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
This will be one of the only times that a haynes manual will come in handy. Go to the parts store and look up the engine error codes or check engine light section. It tells you which wires to connect to get the engine codes and has a list of codes with tips on how to fix them. First things first, get a 15.00 book from the parts store.
Old Oct 2, 2005 | 07:25 AM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Axle/Gears: 9" ford 35 spline axles
Turn the ignition to the "ON" or "RUN" position (engine off). Make a note of the "SERVICE ENGINE SOON" light. Light should come on steady. If there is no light or the light flashes, do not proceed with remainder of test. Results of test will be invalid.
Turn the key on to the "RUN" position (engine off). Ground the diagnostic terminal (ALDL terminal A to B). The "SERVICE ENGINE SOON" ("CHECK ENGINE") light should flash a code 12. This is displayed, on the Check Engine light, by 1 flash followed by a short pause then 2 flashes. This should repeat 3 times. A code 12 should always flash when an on-board diagnostic check is performed. Any other codes, stored in the computer (ECM/PCM), will follow a code 12. If any other codes are stored, or code 12 does not flash, or the CHECK ENGINE light is on steady, or not at all, refer to DIAGNOSING AND TESTING PROCEDURES/DIAGNOSTIC CHARTS.
hope this helps...
Old Oct 2, 2005 | 08:17 AM
Welsty2003's Avatar
Car: '91 Firebird
Engine: 3.1 V6
Thanks, i'll not be able to get near the car till about thursday but i'll let you know how i get on.
Old Oct 2, 2005 | 11:58 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Just out of curiosity would this all be the same on an 1990 V6 tempest??
My sisters having some problems with her car and ill be down there to see her at the end of the month and would like to be able to figure it out.
Old Oct 3, 2005 | 06:46 AM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
should be same for all pre obdII gm cars....
Toolsin
Feb 2, 2016 06:55 AM
GTAman
Sep 21, 2015 09:57 AM
ZZ42Fast
Aug 30, 2015 02:39 PM
mdtoren
Aug 23, 2015 12:52 PM
GouldyGTR
Aug 21, 2015 10:43 PM
