South Central Region Board for the states of Texas, Oklahoma, and Louisana.
Electric water pump?
Old Jan 14, 2005 | 12:14 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
Anybody in the Hou. area using an electric water pump on a "traditional" thirdgen SBC (Non LT-1 or LS-1).
If so, I would like to look at your car and discuss any difficulties encountered with installation.
Craig
Old Jan 14, 2005 | 01:11 PM
xtremeirocz's Avatar
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
i am not using one now but i did have one on my 383 in my other iroc and had nothing but trouble, infact i dont think for the little bit of power you get it is worth it. a race only car the electric waterpump is a good idea but for a street driven car i had nothing but issues especially since it flowed the same amount of water at idle as it did cruising so mine would act fine at idle , infact it would act great then you start driving anywhere and you would start overheating. i even invested in dual lt1 cooling fans and a be-cool radiator and still the same prob. motor was only 10 to 1 so i dont think it was the compression or the gear 3:42 that drove mine to overheat because as soon as i put my stock pump back on it started working great like before that stupid electric water pump. i have also had a friend with the lt1 version of the electric and his was even worse. these were not cheap pumps either , 370$ meziere pump on mine , i punted that thing off my car , i thin ki sold it to some guy on ebay for 140 bux. but atleast i learned my lesson. some people might have had different experiences but mine and my friends were pretty bad
Old Jan 14, 2005 | 01:13 PM
also i installed it mezieres instruction and had a seperate relay feeding it from the alternator so it got plenty of power, just couldnt flow enough to keep up while driving
Old Jan 14, 2005 | 02:03 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
remember what the flow rate was ?
Old Jan 14, 2005 | 03:14 PM
mine was 300 series (55 gpm)
Old Jan 14, 2005 | 03:38 PM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
I agree. Too risky to run on the street. If it's a trailer car, OK.
Old Jan 14, 2005 | 03:39 PM
yeah i mean it would be great for a trailer car or a show car but if you go driving 25-50 miles away from home on a 100 degree houston day .........good luck
Old Jan 14, 2005 | 03:47 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Mine keeps mine cooler than the stock waterpump did. But then again, I have a LT1. Mine is a CVR.
Old Jan 14, 2005 | 03:50 PM
plus its a t-56 and i remember my t-56 ls1 running like 1600 rpm in 6th gear. so it might be easier to catch up then a 4l60 /700/th350. i know my friends lt1 was a th-350 car and he hated it, so i dont know, like i said some people have had great luck with them, some havent.
Old Jan 14, 2005 | 03:52 PM
pasky's Avatar
That may be true, I never go above 2200 rpm when driving normally. I keep them as low as possible and under load.
Old Jan 14, 2005 | 03:53 PM
yeah , i dont know, but in zaps case if he already has it then he might as well try it, he might have good luck with it.
Old Jan 14, 2005 | 03:59 PM
pasky's Avatar
I would, im working on keeping a spare in my trunk. It seems to work really well, the best part is I can turn the key with the car off and its cooling the engine. I need to wire a switch so I can also turn the fans on too while its doing it and just watch the temperatures drop. I say go for it, I know on lt1's its a good gain for up to 10rwhp since the waterpump is run off the crank itself.
Old Jan 14, 2005 | 06:39 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
No, don't have one--YET--was just considering it. Since I still don't have it back together yet from the head job (Hey Beavis--he said head job!)--uh valve job, I was thinking about it. I don't drive it that much on a daily basis, more on the weekends to car shows or a cruise or the track.
I was looking at the Proform 35 gallon one for about 150.00 and if it is a straight bolt-on and just get a shorter belt, I'm still thinking about it. After all 10 HP + or -- for 150 bucks is not a bad deal. I fully realize that it puts more of a load on the electrical, but 5 amps is not that much and with the toggle switch on the alternator for when I get serious about making a pass, I don't see that it is anything but a plus.
http://store.summitracing.com/defaul...ric+water+pump
PRO-66225R
Overheating soes not seem to be a problem with my car since i did the aluminum rad and the dual 14" fans with shroud--the hottest it's gotten in anycondition in the middle of the summer is 210.
Am I wrong?
Old Jan 14, 2005 | 06:46 PM
pasky's Avatar
Like I said earlier, i'd go for it, I got mine on my daily driver and im not worried.
Old Jan 14, 2005 | 06:52 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Anyone know what an OEM pump is rated at? GPH?
Old Jan 14, 2005 | 07:08 PM
dont have any idea on the oem pump. i would just try it and if you dont have any probs then your good to go, i know with my stock water pump , be cool radiator and lt1 fans i never ran over 180 in the summer and that was after 4:10's and a th-350 with 3500 stall so i guess what i had was a little much for the electric
evilstuie
Jan 9, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
