South Central Region Board for the states of Texas, Oklahoma, and Louisana.
Camaro at ARD
Old Dec 17, 2005 | 06:13 PM
Red92RS's Avatar
Car: 1992 Camaro RS
Camaro at ARD
After sitting for three years, I have dropped my car off at Owen's shop for my engine swap. Hopefully it should be ready by the beginning of february
Old Dec 17, 2005 | 07:23 PM
xtremeirocz's Avatar
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
Old Dec 18, 2005 | 10:55 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
Way COOL!!!!!!!!!!!!!!!!!!
What all is he gonna do? straight swap? build up the motor?--tranny? any suspension stuff? NOZ?
Did U figure out what U ae going to do with all the old leftover parts and pieces? What all kind of stuff do U have to get rid of anyway?
Pretty soon U will be :
Old Dec 19, 2005 | 12:04 AM
Red92RS's Avatar
Car: 1992 Camaro RS
LS1 swap, Stage 2 heads, 228-230 cam, F.A.S.T. intake. I am also trading the 700R4 for a turbo350. No nitrous for now, I may do the suspension at the same time since I will hold off on the body work for a while.
As far as leftovers I believe it is ESC with the 82 camaro who showed interest in the engine and serpentine setup.
Old Dec 19, 2005 | 01:07 AM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
Sounds good. I'm doing almost the same thing on mine....except I'm doing the work.
Old Dec 19, 2005 | 07:43 AM
yours still isnt up and going? we were talking about this back in august when i dropped mine off to get it done. Damn boy , get a move on! j/k
Old Dec 19, 2005 | 08:29 AM
esc's Avatar
esc
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
Yep, that was me, and I'm still interested.
Old Dec 19, 2005 | 08:45 AM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Re: Camaro at ARD
Wow, sounds pretty sweet and expensive. If we have a spring meet maybe that will be the debut of your car.
Old Dec 20, 2005 | 12:36 AM
Red92RS's Avatar
Car: 1992 Camaro RS
I can tell you that it is no where near the price other shops were quoting me. I can actually use the extra money to do my suspension at the same time. I plan to hold off on the needed body work until I get a house probably in a year. I would suggest to anyone that if you plan on an LS1 swap talk to Owen at ARD, he is a very nice guy and gave me a very reasonable quote for my swap.
Old Dec 20, 2005 | 08:10 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
4.8 or 5.3 heads and 5.7 or 6.0 liter ?
Old Dec 20, 2005 | 04:40 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
OK I know I'm showing my ignorance here. I know from talking to Daniel at the last monthly, that he is going with the aluminum 5.7--350CI, but I am not familiar with the different heads--does that refer to combustion chamber/runner size?
Old Dec 20, 2005 | 04:54 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
4.8 and 5.3 refers to heads that have come off of a 4.8 liter chevy truck v8 engine or the 5.3 liter chevy truck head.
LS-X intakes will bolt upto the chevy truck heads.
Hope that helps.
Old Dec 20, 2005 | 10:47 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Hope that helps.
Are they a better head choice than the stock LS-1 heads?
Smaller combustion chamber/higher compression maybe?
Old Dec 21, 2005 | 06:11 AM
the aluminum 5.7 is a 346ci, the 6 litre is a iron block but a 364 ci. 4.8 and 5.3 heads have smaller combustion chambers but also have smaller valves and runners. stock size in a 5.7 or 6.0 is a 2 inch valve where in the 5.3 or 4.8 is a 1.88 valve
Old Dec 21, 2005 | 09:14 AM
Larry Dunlap's Avatar
Car: '91 Formula
Transmission: TH350 built
Wow cool, I guess times are good. I cant wait to see what it runs.
Old Dec 21, 2005 | 09:23 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Other differences in the heads are open chambers vs. closed chambers and combustion chamber size.
I prefer the LS-6 heads or if money is no object, C5-R heads.
Old Dec 21, 2005 | 10:07 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
OK--another stupid question--what is a open chamber--closed chamber head?
Old Dec 27, 2005 | 02:01 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
the only stupid questions are the ones don't know & you don't ask about,.. you don't know this one & you asked, so its not a stupid question
you probably do know it,.. but you just don't realize it
with everything else being even, a motor can breath better with open chamber heads than it can with closed chamber heads because the valves are unshrouded on the open chamber heads.
a lot of people will put on a set of closed chamber heads to bump up compression when they have either dish or flat top pistons.
as far as i know, you can't put a set of closed chambers heads on a motor than has domed pistons designed for open chamber heads. if you have too much compression, you can put open chamber heads on closed chamber designed domed pistons, but that can sometimes cause other problems such as detonation.
if you can view them, here are some pics of BBC open & closed heads.
http://www.anycities.com/user1/jakeshoe/
a side by side view of open vs closed f*rd heads.
http://www.boss351.org/cylhead.htm
Old Dec 27, 2005 | 02:57 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Ahhh......I see said the blind man!
Thanks for the explanation!
Old Dec 27, 2005 | 03:22 PM
NoItsNotForSale's Avatar
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Transmission: 700R's
Axle/Gears: 2.77 - 3.70
Where are yall getting your engines?
Old Dec 27, 2005 | 04:24 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
No one particular place. In Daniels case, Owen @ARD is building up his LS-1, and doing the swap/install and the tranny rebuild and anything else getting done at the same time. Owen is pretty sharp all the way across the board.
I myself use a local machine shop called Westside Performance--one of the better shops in Houston. They build a lot of drag and roundy round engines.
Old Dec 27, 2005 | 05:16 PM
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
These places have LS_ engines in stock?
Old Dec 27, 2005 | 11:25 PM
Red92RS's Avatar
Car: 1992 Camaro RS
If Owen doesn't have any in stock I am sure he could locate one for you at a good price.
Old Dec 28, 2005 | 08:05 AM
StevenK's Avatar
Car: 91 Z28
I just waited for a 4th gen owner on a local board to wreck. It happens all the time.
They buy back their totaled car and part it out. I got my LS1/t-56 harness for 3k.
Old Dec 28, 2005 | 06:09 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
No--built to order. If U are still looking for a "crate engine" source, this is not it, but I'm sure he could hook U up, if U are willing to come down here.
Old Dec 29, 2005 | 02:54 AM
he can have are re-mqn shortblock or longblock for you ready assembled for pickup ansd with a 1 year 12k warranty that will knock your socks off. and it will beat any price of anything you will find. honed , cleaned with new rings and bearings. honestly anythingyou want and you will save a buttload of cash
Old Jan 3, 2006 | 10:00 PM
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Can I get a phone number?
Old Jan 4, 2006 | 06:10 AM
8325939140
Old Jan 4, 2006 | 07:26 AM
esc's Avatar
esc
Engine: 377
Transmission: 400
Re: Camaro at ARD
So how is it going, any progress? Have you been over to check on it?
Old Jan 6, 2006 | 02:03 AM
Red92RS's Avatar
Car: 1992 Camaro RS
we still have some parts to order but i will let everybody know of the progress as it happens. I went up to his shop today to clean out the rest of the junk sitting in my car and Owen is building some sweet cars, I haven't always been a mustang fan but he is building a CRAZY one in his shop.
Old Jan 6, 2006 | 09:18 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
A Mustang...traitor....LOL......Oh well he's gotta make a living!.... How crazy is it!
Old Jan 12, 2006 | 10:32 PM
Red92RS's Avatar
Car: 1992 Camaro RS
they began taking the motor out last night bye bye 305
Old Jan 13, 2006 | 12:18 AM
Red92RS's Avatar
Car: 1992 Camaro RS
Anybody needing performance parts check Thunder Racing by this Friday, they are running a special 10% discount on select items. I just ordered my Tokico illumina shocks and struts, Eibach Prokit, and BMR 3 pt Strut tower brace and saved some money
Old Jan 18, 2006 | 11:36 PM
net_coma's Avatar
Estimate on the cost excluding the engine and electronics purchase price?
Old Jan 19, 2006 | 08:15 AM
Car: '91 Formula
I got an email from thunder racing where they are offereing a 350 crate motor with 400 hp for $2995 with a one year 10,000 mile warranty!! Sounds like a heluva deal. Maybe Ill get me one of those and put it it Maxs car, I know he would like that.
Old Jan 19, 2006 | 10:24 AM
Car: '91 Formula
The YearOne Power Crate 350 has the power you need for the car you love.
The four-bolt main seasoned 350 block has been bored 0.030 over. It uses a nodular iron crankshaft with hypereutectic pistons connected with powdered metal connecting rods.
A dual plane aluminum intake allows good idle quality and excellent street driveability while providing plenty of low-end torque. Ported Vortec cylinder heads, 1.6:1 ratio rocker arms and a hydraulic roller camshaft round out this excellent engine.
The fully balanced and blueprinted PowerCrate 350 has been dyno tested to produce 400-plus horsepower* and 440-plus ft./lbs. of torque* with a pump-gas friendly 9.5:1 compression ratio. The engine comes with a 12-month/12,000 mile warranty.
You will find more features and specifications on this engine, along with an engine test graph, by scrolling down to the bottom of this e-mail.
You can have this YearOne exclusive engine for only $2990.00 (plus shipping).
To take advantage of this offer click Part # CT350PC1, add it to your shopping cart and enter the code EM611 during checkout.
But hurry, this offer ends midnight EST on Wednesday, February 15, 2006.
Whaddya think about this
Old Jan 19, 2006 | 04:38 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Any progress from ARD yet?
Old Jan 19, 2006 | 07:04 PM
net_coma's Avatar
Quote
"The YearOne Power Crate 350 has the power you need for the car you love."
Not worth much in a thirdgen if you live in the metropolitan areas of Texas. No chance at being emissions leagle.
Old Jan 20, 2006 | 08:10 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Originally posted by net_coma
Quote
There are ways around that!
Old Jan 20, 2006 | 11:25 AM
net_coma's Avatar
Yes there are ways around "that" but I have no desire to rip the car apart to run a carburator and toss all of the emissioins in the trash can. I can take it locally and get it inspected (in the family thing) but that is not what I want. Trick Flow heads, LT4 hot cam and headers should get the car to where I want it with the problem being the intake system. The LT1 intake seems to be the best option for performance vs bucks. The only real problem is the egr, I think it was killjoy on here that fabricated a functioning egr connection to the back of the intake. I work with some tube benders that maybe able to fabricate something from stainless for me but I am not far enough along to persue that option. The TPI will have to stay as is until I decide on the best undesirable option.
Old Jan 20, 2006 | 11:33 AM
StevenK's Avatar
Car: 91 Z28
Stealth Ram
Old Jan 20, 2006 | 12:00 PM
  #42
net_coma's Avatar
StevenK...your LS1 is actually the best answer to it all.
Old Jan 21, 2006 | 06:14 PM
  #43
StevenK's Avatar
Car: 91 Z28
Yeah, until you see how much money I've wasted
Old Jan 21, 2006 | 06:37 PM
  #44
net_coma's Avatar
Yeah the ls1 engines are still up in price. The lt1 seems to be lower lately, there is one on ebay with t56 at a reasonable price and it is killing me, spring bonus check has not arrived. Just have to decide on lt1 or build what I have and the lt1 keeps looking better and better.
Old Jan 23, 2006 | 04:15 PM
  #45
vortecbird's Avatar
Car: 91 Firebird
Engine: 350 Vortec TBI
Axle/Gears: 2.73 single tire fire
ARD?
been reading about ARD in several posts, is this their real shop name or abbreviation. Do they have a web site ??
Old Jan 23, 2006 | 05:27 PM
  #46
net_coma's Avatar
I had the same question and looked it up. I think someone here used the name. Here is a link. I was looking into there general pricing info for a swap less the drive train hardware but found no info other than a phone number.
http://www.advancedracingdynamics.com/main.shtml
Old Jan 23, 2006 | 06:55 PM
  #47
Zap Racing's Avatar
Car: 1989 IROC Z-28
U need to call and talk to OWEN!
Old Jan 24, 2006 | 11:54 AM
  #48
Red92RS's Avatar
Car: 1992 Camaro RS
That is their old website and they have a different location than listed on there also. Like Zap said give Owen a call.
Old Jan 25, 2006 | 07:05 AM
  #49
net_coma's Avatar
Is the place located in Houston so I can find a number....I am near Fort Worth.
Old Jan 25, 2006 | 08:11 AM
  #50
8325939140
