South Central Region Board for the states of Texas, Oklahoma, and Louisana.
ARD now has dyno with wideban-- sign-up list for "DYNO DAY" Sunday May 21 10am
Old May 11, 2006 | 08:55 AM
  #51
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
Originally Posted by FbodTrek
Ok, I wanna run with wideband, but my setup wouldn't allow for an o2 bung to be welded in. Do you guys have a probe the way most dynos do (the magic wand thingy)? I also need to know if you fellas have the boost monitoring option as well. My new setup will be in by then, and I'lll have to play with the engine load and boost timing retard a bit.
Suggest U PM Owen about this
ARDLS1
Or call in the evening
Owen
ARD--Advanced Racing Dynamics
5023 Addicks Satsuma rd, Suite b,
Houston, Texas, 77084
832-593-9140
Old May 11, 2006 | 09:14 AM
  #52
Zap Racing's Avatar
Car: 1989 IROC Z-28
If any of U TPI guys that are going to Dyno, have been thinking about getting Mike to do some chip tuning, now is the time, especially if we can get Mike out there to actually tune and Dyno at the same time.
If U need to contact Mike-- 1bad91Z --PM him!
Old May 11, 2006 | 12:06 PM
  #53
z28evans's Avatar
Car: 89 iroc
There's a pretty good chance that i'll be going to get some dyno runs in.
James
Old May 11, 2006 | 12:35 PM
  #54
Zap Racing's Avatar
Car: 1989 IROC Z-28
James
name added to list
Old May 16, 2006 | 08:44 AM
  #55
TexasLT1's Avatar
Car: '92 RS
nevermind, reading helps. so the wide-band takes an extra O2 bung? its not one of the slip-in styles?
Old May 16, 2006 | 08:58 AM
  #56
TexasLT1's Avatar
Car: '92 RS
Originally Posted by Wheel Spin
Yeah, I want the wide-band option, with the bung-hole welded in. I've not dyno'd before, so somebody clue me in here. The typical dyno sheets I've seen show HP and Torque graphed out against RPM. The wide-band measures Air/Fuel ratio ( or residual O2?) , and this would be a third plot across RPM?
The way I've seen most Dynojet graphs is you have HP and TQ on the main graph plotted by RPM, below that is a secondary graph that just shows AFR against RPM.
Old May 16, 2006 | 11:52 AM
  #57
plndtx's Avatar
Car: '92 Heritage Z28 Convertible
Would it be benificial to monitor the fuel pressure when doing a run? I've been thinking about buying an adjustable fuel pressue regulator. If the pressure dipped during a run, would that mean you would want to bump it up a little?
Old May 16, 2006 | 12:59 PM
  #58
TexasLT1's Avatar
Car: '92 RS
only if you get tuning to go along with it. If the pressure drops the ECM is going to see a lean condition and open up the pulse width of the injectors to compensate.
so in other words, its not really that beneficial
Old May 16, 2006 | 05:23 PM
  #59
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Ok, new motor is in. Guess I will be making it afterall... And I found a place for a Bung to be welded.
Old May 18, 2006 | 11:40 PM
  #60
Red92RS's Avatar
Car: 1992 Camaro RS
I just found out that i have to work all day sunday since a coworker is going to a wedding
Old May 19, 2006 | 08:16 AM
  #61
Zap Racing's Avatar
Car: 1989 IROC Z-28
That sucks!
Old May 19, 2006 | 11:02 PM
  #62
Red92RS's Avatar
Car: 1992 Camaro RS
sure does, and I get to go in tomorrow on my day off, luckily only half a day
Old May 20, 2006 | 10:37 AM
  #63
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
I am planning on making it, however I will have to show up about mid way through.
I get off at 4:00, so I should be down there around 5:00.
Hopefully you guys are still running, but considering the amount of cars that will be there, I am fairly positive we will be there all night.. lol.
Old May 20, 2006 | 06:17 PM
  #64
Red92RS's Avatar
Car: 1992 Camaro RS
well i worked all day today so that i could be there tomorrow morning from 10-11:30 and go in at noon
Old May 20, 2006 | 08:49 PM
  #65
Zap Racing's Avatar
Car: 1989 IROC Z-28
Hey Dude,
Callme when U head out for ARD--I'll let U know what's up!
713-823-7019 C
Old May 20, 2006 | 08:59 PM
  #66
z28evans's Avatar
Car: 89 iroc
see you guys tomorrow
Old May 22, 2006 | 08:46 AM
  #67
Zap Racing's Avatar
Car: 1989 IROC Z-28
Owen,
On behalf of all the thirdgenners, (I think I can speak for all of them in this case)
THANKS FOR HOSTING THIRDGEN DYNO DAY @ ARD!!!
AND A BIG THANKS JAY/JORDAN AND I CAN'T REMEMBER HIS NAME--THE VOLVO MACHANIC GUY--FOR WORKING THEIR BUTTS OFF ALL DAY DOING ALL THE CARS!
Appreciate your hospitality and the great price break for Dyno Day!
I think everybody enjoyed themselves. I know I did!
Old May 23, 2006 | 08:07 AM
  #68
xtremeirocz's Avatar
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
craig that was little jeff, the whole thing seemed to go well and everyone enjoyed themselves
Old May 23, 2006 | 12:26 PM
  #69
esc's Avatar
esc
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
Yep, I had fun. Thanks again for letting me mess around with the y-pipe.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
okfoz
Oct 13, 2015 02:19 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
Dragonsys
Sep 25, 2015 03:51 PM
