South Central Region Board for the states of Texas, Oklahoma, and Louisana.
9bolt
Old May 2, 2006 | 09:21 PM
net_coma's Avatar
9bolt
Needs a good home or otherwise. Posi/limited slip carrier. From factory with 3.27 gears. Posi unit is good but bearing(s) make a lot of noise. Driver side axle possibly bent. Gears have a wear ridge, unless you want to run 3.73 good luck on finding ring and pinion at a decent price. I did not take the axle to work and do a shaft runout. I had a hard time removing the brake rotor and axle. BFH to remove rotor and car jack to pop the axle out. 160k miles is the reason for the price. I don't want to try and make a buck when it may give another a problem.
Price is the cost of your gas to Fort Worth.
Old May 2, 2006 | 10:14 PM
NoItsNotForSale's Avatar
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Transmission: 700R's
Axle/Gears: 2.77 - 3.70
Would Saturday be OK? What year? Calipers included?
Old May 3, 2006 | 06:47 AM
net_coma's Avatar
I had to use the calipers and backing plates on the 10bolt I am installing. It is the original equipment that came in my 1988 IROC.
Old May 3, 2006 | 09:05 PM
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
I'll call you tomorrow.
Old May 4, 2006 | 03:06 PM
blackbeast's Avatar
Car: 87 IROC
Engine: 305 :(
If NoltsNotFor Sale doesn't take it, let me know (wilsonjs0311@yahoo.com) and I will come and pick it up. I live in Lewisville and have a truck so we would just have to arrange a time and place
Old May 4, 2006 | 05:38 PM
net_coma's Avatar
Will let you know blackbeast, no word from NotForSale yet but the day is still young.
Old May 4, 2006 | 11:04 PM
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Sorry man just got off work late as hell. I want it and I am off Sat. I have have your number and I will call you Friday. Thanks
Old May 5, 2006 | 07:22 PM
net_coma's Avatar
I am here all weekend with exception of taking sidekick to karate @ 9:00 and maybe a trip to the salvage yard for 4th gen pedals, if they have them I forgot to call today and see. Otherwise I will be in the garage under the car.
Old May 5, 2006 | 09:50 PM
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Just called and left a message. I will call you Sat when I get ready to leave.
THANKS
Old May 5, 2006 | 10:51 PM
net_coma's Avatar
got msg and sonds good.
Old May 7, 2006 | 11:29 PM
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
8T8IROC
Dec 11, 2001 06:10 PM
STUB25
Nov 13, 2001 10:57 PM
PETE
Jul 19, 2001 07:22 PM
ANDYZ28
Nov 14, 2000 05:14 PM
