Dyno Day -- Sunday! 5/21/06 TODAY!!!
#51
Car: '91 Formula
Transmission: TH350 built
Ill ask him but Im not sure it will provide much more useful information. I guess it would be best to use as a baseline for the tuning session, however the other one was pretty close and the curves were real consistent. I know it said 244hp which sounds better than 240 hp when we are trying to compare our cars around the beer cooler
When Barry gets his car going us three need to meet up for a little round robin tournament, winner takes all (of what I don't know, except for bragging rights). This will be after my cutout is installed and Ive done my tuning session and found that extra 20hp that Owen says is in there.
![Wink](https://www.thirdgen.org/forums/images/smilies/wink.gif)
#52
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
Originally Posted by Larry Dunlap
I was basically surprised at the level of all the cars HP as being low. Someone was speculating that the dyno is measuing low values. I have no idea and nothing to compare it to. It seems like a great tool.
#53
1 Post
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
IF Barry gets his up and running, we will determine it on the track not the dyno! At least for me--the numbers on the dyno are nice but the bottom line is track et's.
Give U a good example--Z28 Evans--by the Dyno was in the 317 range, where I was in the 260 range, but his best time at HMP was 8.70's-- my best time was 8.40's. So Dyno numbers can be deceiving--just cause U can crank out more on the dyno than someone else, does not necessarily mean U are faster!!!
#54
Car: 89 Formula 350 (x 2)
Axle/Gears: BW 3.27
![good idea](https://www.thirdgen.org/forums/images/smilies/goodidea.gif)
#55
1 Post
Car: 1989 IROC Z-28
Originally Posted by Wheel Spin
That would make a PRETTY GOOD central theme for the Summer Bash![good idea](https://www.thirdgen.org/forums/images/smilies/goodidea.gif)
However as far as Barry--our grudge match is on as soon as The boy can get it together. I'm sure Larry will be involved in it somehow, since He and I run ET's so close, it's almost scary sometimes.
To borrow a phrse from the sports or PRO wrestling world, we can call it:
"THE TRIPLE THREAT MATCH!"
![driving](https://www.thirdgen.org/forums/images/smilies/driving.gif)
#56
1 Post
Car: 1989 IROC Z-28
One thing the impressed me is Zaps increase of approximately 11hp just by opening his cutout. Ive been driving around with my cutout in my back seat for a couple of months. Im going to try and have it installed at ARD next weekend if they can do it.
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
![waveman](https://www.thirdgen.org/forums/images/smilies/waveguy.gif)
#57
Car: 87 Z28
Engine: uh does the name give u a hint
well guys i made it home alright, thing is i really don't know how to tell what a slip feels like when its does, can some one elaborate pls. thanks owen for the input and i will definently be having you do the tranny.
#58
Axle/Gears: BW 3.27
Anyone considering changing shift points after seeing your dyno results? I have my light set @ 5k, but am now considering dropping back to 4600 or so after seeing my graphs. "Flat" hp across the board, but tq was highest at the start of the run (277@3600), held well to 4200, then dropped on a smooth curve to 180@5300. I think I'm giving away time by pulling beyond 4800.
Comments?
Comments?
#59
Car: 1985 IROC
Engine: 355 4-bolt
Transmission: Specially-Built Exner TH350
Comments?
Comments?
![good job!](https://www.thirdgen.org/forums/images/smilies/goodjob.gif)
[QUOTE=Zap Racing]However as far as Barry--our grudge match is on as soon as The boy can get it together. I'm sure Larry will be involved in it somehow, since He and I run ET's so close, it's almost scary sometimes.
QUOTE]
How are you going to feel getting beat by a BOY? HMMMMMMMMMMMMMMMM?
Last edited by Barry 85IROC; 05-22-2006 at 07:27 PM. Reason: Automerged Doublepost
#60
1 Post
Car: 1989 IROC Z-28
Comments?
Comments?
After I did the first run, I asked Owen if he could tell where mine starts to "nose over" by looking at the graph of the first run--he said at 5800--which is pretty much where I had determined over time, from making a bunch of passes, and my butt dyno, told me it was starting to drop off.
I guess I did a pretty good job of figuring that out over time, cause I have my shift light set at 5800. Yesterday, I bumped it up tp 6000 and told Jay to let out of it when the light came on. I wanted to hold it open a little longer than normal, to see if I was shifting too early.
I normally let the light come on in the 1/2 shift and wait hals a second to shift. For the 2/3 shift, I normally watch the needle and shift when it is about to hit 5800, sometimes the shift light comes, sometimes not.
If the numbers had started falling off any earlier, I would be considering shifting at a lower rpm. If they were not falling off by 6000, I was going to tell him to take it up to 6200 next pass, and of course adjust my shift points to wherever the numbers start to drop, next time I went to the drag strip
#61
1 Post
Car: 1989 IROC Z-28
Comments?
Comments?
#62
Axle/Gears: BW 3.27
Suprisingly flat, 200hp from 3950 to 4700, then a smooth curve down to 180hp at 5400.
Those numbers looked odd when re-reading my previous posts, thought I had tq and hp mixed, but no they are correct. HP & TQ merged at about 190/5075, then followed the same curve.
#63
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
craigs pulls that high of rpm mainly because of the mini ram he has on the car, between wheel spin, zap and larry there are three totally different setups with three different intakes so your power band will always be different, i think larry's was the most impressive since it was done with a th-350 instead of a 700 r4
#64
Axle/Gears: BW 3.27
Yeah, Zap and Larry are both different, and impressive nonetheless. I'm stock TPI limited, so not surprised or unhappy with what I ran, quite the contrary. I did as well or better than expected. After getting the dyno run (my first), I'm happy with the state of tune and see where I can maybe improve track times by changing shift points.
Jay, I know it was a long day for you, and I appreciate your hard work out there. And just for reference you had the BIGGEST grin on your face on every pull
#65
i saw a lot of people taking pictures, i m surprised i havent seen any posted yet, someone should make a picture thread
#67
1 Post
Car: 1989 IROC Z-28
Try to post plot of my best run.
Well, I'll be............ it worked!
#69
Car: 89 iroc
Howdy,
I've attached my dyno chart, Blue is with the TPI intake and Red is a 'Cold Air Intake' run (removed the tpi intake). 1998 LS1 stock, with 2001 Exhaust manifolds, M6 trans.
![](http://www.bubbadrift.com/CamaroDynoLS1.jpg)
James
James
#70
1 Post
Car: 1989 IROC Z-28
Originally Posted by z28evans
Howdy,
James
James
#72
Car: '91 Formula
Can someone explain to me why my power band is so much different that Zaps. His is like 5500 to 5700 rpm and mine is like 3800, then flat to 4400. That's a huge difference. Also why am I making a lot more torque, his is like 250 something and mine is 283. I thought the superram was supposed to make better high end torque without a sacrificing low end torque. The max torque is at like 4800 rpm
#73
Axle/Gears: BW 3.27
Don't the SR and MR use different bases? The SR base must be closer to the stock design, meaning a longer runner length? Higher TQ, lower rpm.
Have you scanned a graph Larry? I missed it if you did.
#74
Car: '91 Formula
I am attaching my scan here. Well Im sure the bases are diffferent. I know the superram setup has a large plenum and short runner. I think the Miniram setup has a small plenum and short runners.
Its weird, Its like Owen said, Zaps and my graphs are exact opposites. Craig makes more HP high and me low. Craig is lean coming down to ok, and Im rich coming up to ok, then rich again.
I believe according to this that I should be shifting about 4500 rpm before the HP starts to drop off. . Is that right ? I don't use a shift light, just seat of pants feeling.
I didn't get a copy of the first run, the hp was higher, 244 on that one and the torque was similar
#75
Axle/Gears: BW 3.27
Well, your tq is good throuh 5k, and that is the actual work that is being measured by the dyno. I'd suggest a 5-5200 shift, and I highly recommend the shift light. The dyno gave you real numbers to work with vs SOTP. With my setup the components can be hidden pretty well if that is what you want.
I think the SR base runners must be a little longer than the MR to explain the diff between you and Zap.
#76
Engine: 377
Transmission: 400
You want to spend as much time as possible in the lower gears because of the mechanical advantage. You also want your after-shift HP to be higher than your pre-shift HP.
If you shift from first to second at 4500 your rpm will drop WAY too low. I would probably shift around 5500 to 5800 if I were you.
#77
1 Post
Car: 1989 IROC Z-28
Also, do a search for "mini ram VS. the super ram" on the TPI board--it's a subject that has been beat to death--I'm sure U will find out som good info--let us know wht U find out when U are finished.
#78
Car: '91 Formula
OK, interesting. Ive got the LPE 219 cam sitting here in a box that is supposed to be made to go with the Superram intake. Ive been waiting to do a whole engine rebuild instead of just heads and cam. Maybe I should just do heads and cam anyway. I wonder what AFR 190 heads and that cam would do for me.
#80
Car: '92 Heritage Z28 Convertible
I was reading in my latest issue of car crapt mag and they were doing more work on their 5.7 firebird. On the dyno they were seeing a lean condition so they bumped up the pressure on the adjustable fuel pressure regulator. They claimed it fixed the problem.
I pulled this thread up and looked at the dyno graphs that were posted. Does anyone think that a bump up in pressure would help wheelspins A/F ratio? It looks like he is consistantly lean, would more pressure get more fuel into the engine?
One other question, for everyone who posted dyno runs, how old are your O2 sensors? Could your engine think that the a/f is correct because of faulty o2 feedback? I read in another mag the sensors need to be replaced about every 70k. Mine was only about $23.
#81
Axle/Gears: BW 3.27
My O2 is new, installed last fall with the new headers.
I am actually running a bit rich. I have an AFPR, pressure currently set at about 44psi. Owen felt a pressure change would soon be compensated for by the computer. Based on the O2 sensor input, the computer "thinks" the A/F ratio is correct.
#83
Engine: 377
Transmission: 400
I THINK that if your FPR uses a vacuum signal, so that it only increases pressure during full throttle(open loop), the computer will not compensate.
#84
Axle/Gears: BW 3.27
Hmmmmm. Good point. I have the Holley AFPR, and it is vacuum referenced. Not sure how works, but it is "set" with the vacuum removed, then drops around 5psi at idle when the vacuum is applied. Anyone?
#85
1 Post
Car: 1989 IROC Z-28
#86
Engine: 377
Transmission: 400
It should have adjustments for how much vacuum is required to go to the lower pressure and also for the difference between low (normal) and high (full throttle) pressure.
Disclaimer: I've never used one, so I'm no expert.
#87
Car: Faster
Engine: Than
Transmission: You!
Just thought I'd throw my $ .02 in........
The reason why your runs show a little rich is due to the ethynol we now have in our gas. The o2 picks it up as a slightly lean condition and the ECM then adds fuel causing the WBo2 to show a richer reading.
Anything leaner than a true 13.0:1 AFR at WOT is dangerous to your motor.
LArry - leaning out your motor to 13.0:1 from where you are at now will not gain you 20HP. I predict 3 - 8 RWHP (I could be wrong, but this is my estimate). If you think the above prediction is worth the money, I'll still be more than happy to tune it.
ZAP - your AFR graph looks pretty damn good!
Also remember that a tad rich is WAY better for your motor than a tad too lean.
But then again, what do I know....
![my 2 cents](https://www.thirdgen.org/forums/images/smilies/twocents.gif)
#91
Engine: 377
Transmission: 400
Peak Volumetric Efficiency: The RPM range at which your engine pumps air/fuel through it's self most efficiently.
Generally stated as a percentage. So a 350 CID engine at 90% VE would pump 332.5 CI of air/fuel per cycle (2 revolutions).
#92
1 Post
Car: 1989 IROC Z-28
https://www.thirdgen.org/forums/atta...untitled-0.jpg
The highest I see is a shade over 15, and that's when U first punch it after holding it steady at 3000 for a while--once it settles down and computer has time to take control and adjust, it looks like it's between 13 and 14 and finally settles at about as flat a 13 as U can get in the real world--unless I am reading the graph wrong?
Mike had always said he thought he could get a little more out of it, but I don't know if he could or not!
#93
Car: Faster
Engine: Than
Transmission: You!
Yep, thats the one I'm talking about. Fbod just needs reading glasses... ![Wink](https://www.thirdgen.org/forums/images/smilies/wink.gif)
The part where it's a hair close to 15 is the brief second where the ECM is making changes (switching tables). Tuning a modded motor w/ MAF setup close to 13.0:1 while NOT using a WB to tune from is pretty hard to do. ZAP's car is tuned well. If I were to lean it out anymore or get ANY more aggressive with his timing, his motor starts to detonate which trips the knock sensor which in turn retards timing which kills HP. I don't think I could squeeze anymore power out of his setup with-out a good set of heads.
You do NOT want to lean your motor out anymore than 13.0:1 at WOT.
Larry - you figure out what you want to do? Sunday is coming up fast and I need to know if want go with it or not.
