Looking for a cheap third gen Camaro in OK!
Car: 2011 Cummins HO
Engine: 350 HSR
Axle/Gears: 3.43
I want to buy a third gen Camaro as a fixer upper so it needs to be cheap - like $1000 cheap... I dont mind it being untidy or have broken parts but i'm not looking for something that is being held together by rust.
Ideally it will be a 87 up IROC or a 92 Z28 with either a 305/stick or a 350/auto - i want to build it into a 383 stroker with a T56.
I am in Bartlesville, North East OK and the nearer the better.... So have a look in the shed at the end of the field and let me know if you have one hiding in there.
Contact me @ rm38@hotmail.com or PM
Car: 85 Pontiac Trans Am
Engine: wouldnt you lilke to know??
Transmission: TH350 Built to the hilt
Axle/Gears: 4:10 Gears Moser Axle Auburn Posi
i doubht i have what your looking for but i have an 85 berlinetta sitting in my yard, its a buddy of mines' it has no motor or trannybut he wants like four hundred and there is ajunkyard bout a mile from where i work will sell you a t 350 for 150 bucks and a motor for like 50 pm me lemme know what you think even if your not interested .... just lemme know plz thx......
Engine: 350 HSR
Axle/Gears: 3.43
Hey, thanks for the offer but i don't think it is really what i am looking for.. And if NJ is New Jersey? then it might be a bit far away too..
Cheers,
Richard.
Cheers,
Richard.
Car: 1991 Pontiac Trans Am
Engine: 350 HSR, Cam, ignition, headers
i live here in tulsa and i have a real clean 91 trans am but it is alot more than a thousand.
i saw a thirdgen camaro in tulsa yesterday for 900 on sheridan between pine and admiral. don't know if it runs or what but the body didn't look to bad. just a heads up
Engine: 350 HSR
Axle/Gears: 3.43
Thanks everyone but i have finally got one! It is a bit worse condition than i wanted and was like 600 miles away but the good new is it is a 92 Z28 with T-Tops - result!
Just have to get it running now - it has the 305 TPI and i dont here any fuel pump activity when i turn the key, heading to the Zone now for a new Fuel pump relay, already checked all the fuses including the one near the battery
Hope i don't have to replace the pump, dont fancy dropping the tank just yet
Wish me luck everybody peeps!
I'llrocya
Feb 2, 2016 11:43 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
