South Central Region Board for the states of Texas, Oklahoma, and Louisana.
Installing megashifter in '91 Formula
Old Jun 21, 2007 | 03:55 PM
Larry Dunlap's Avatar
Car: '91 Formula
Transmission: TH350 built
My shift linkage on the stock shifter broke last night so Im thinking this would be a good time to go to the B&M Megashifter. I believe it was Wheelspin who installed one on his Formula. The ads for them always say that it is not for 91-92 Formula. Can whoever that was that installed one on their Formula please contact me for some advice.
Old Jun 21, 2007 | 05:53 PM
esc's Avatar
esc
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
Re: Installing megashifter in '91 Formula
I don't know what is different with the '91 and 92...but since you have a TH350 it probably doesn't apply to you.
I really don't like the adapter bracket that allows it to work with the factory shifter cable, like my first Megashifter came with . I would recommend getting the B&M cable instead.
BTW, I would caution you against buying a used one. They do wear out eventually and then don't shift properly. My first one lasted about 10 years.
Old Jun 21, 2007 | 10:35 PM
Car: '91 Formula
My understanding is that the problem is not the transmission, but the console setup, or clearance of something therein. Im not sure what broke, the stock cable or connection to the shift lever or what. I guess I will order the B&M cable with the shifter so I can have a nice strong setup.
I plan on buying a new one from Jegs.
Old Jun 22, 2007 | 05:32 PM
Wheel Spin's Avatar
Car: 89 Formula 350 (x 2)
Axle/Gears: BW 3.27
Hi Larry, I installed one my '89. I used the stock mounting points on the trans tunnel. The stock console plate has to be cut to fit over/around the megashifter. the plate can become quite fragile. the included console plate mounts on top of the stock one, and clearance between the side mirror/window switches and the ashtray release is tight. I plan on removing the ms plate and making some clearance with a dremel or grinder, does'nt need much. I also bought the 3' hd cable from b&m, wasn't happy coiling the 5' over the tranny. Had to elongate the hole in the tranny tunnel to fit the angle of the 3' though. Having the cable straight with no bind at the shifter is critical, probably have to bend the mounting tang for the cable, but that's no problem.
offshore now, so no pics.
Old Jun 23, 2007 | 09:06 AM
esc's Avatar
esc
Engine: 377
Transmission: 400
I like the long cable, it fit better on my Camaro...but then again, nothing on my car is original so what worked for me might not be best for your setup.
My factory cable was WAY to short and BARELY fit. That is one of the reasons why I went with the long cable. I think B&M also has a standard cable and a heavy duty cable. My recollection is that the standard cable was a lot stronger than the factory cable and easier to bend than the HD.
If I were doing it again I would probably buy the B&M long, standard duty cable.
Old Jun 23, 2007 | 05:24 PM
Wheel Spin's Avatar
Axle/Gears: BW 3.27
The kit comes with the standard duty, 5' cable. It requires a loop over the tranny. It is a lighter gauge, and much easier to bend. It comes with the kit, so try it out first.
Old Aug 1, 2007 | 12:50 PM
Wheel Spin's Avatar
Axle/Gears: BW 3.27
Hi Larry, any update on this? Get it installed? Am home now, can provide pics if desired.
Old Aug 3, 2007 | 01:58 PM
Car: '91 Formula
HIya, no I have not got it in yet. Ive been traveling really a lot on business. Ive got the old one out and it looks a bit complicated with the different things to connect and make sure the car will start in park and not other gears and all that. Are you going to be arround this weekend? Could I call you with a question or two if they come up?
Old Aug 3, 2007 | 02:56 PM
Wheel Spin's Avatar
Axle/Gears: BW 3.27
Yes, I'll be home this weekend. You're welcome to call. Probably have my console off doing some tidy up work (Gear Indicator keeps jumping off track, will put a drop of blue loctite on for that).
PM Sent with numbers.
Old Aug 14, 2007 | 02:54 PM
Wheel Spin's Avatar
Axle/Gears: BW 3.27
Out of town (again). Had another board member write today asking on the install. Definitely home by weekend of 25th, will glady provide info. You are welcome to come by and check out my install. Write sooner if you can't wait. May do a full write-up on the Formula / Megashifter issue for the board. Cable angle is critical.
Old Aug 15, 2007 | 03:19 PM
Car: '91 Formula
STILL havent put it in yet. This heat has been brutal. My garage is like an oven. Ive got to do it soon though, I havenet even started my car in more than a month
Jorlain
Aug 24, 2022 05:11 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
okfoz
Mar 9, 2017 02:35 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
Randomtask2
Aug 13, 2015 01:57 AM
