South Central Region Board for the states of Texas, Oklahoma, and Louisana.
E-Brake Cable Guides
Old Oct 14, 2008 | 01:40 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Anyone got a set of these? They are the wire guides for e-brake cables.
Old Oct 14, 2008 | 03:51 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: E-Brake Cable Guides
Hey, Bad,
GMpartsdirect shows that both guides are still available.
JamesC
Old Oct 14, 2008 | 04:08 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Yea, just ordered them from GM. Also, sent you a PM. Thanks for the good sticky on the PBR conversion. Also ordered new front to rear brake line from Finelines. When I get these few parts my conversion will be complete. Thanks again for the help.
Old Oct 15, 2008 | 02:47 PM
aldixie's Avatar
Car: 1991 RS Camaro Convertible
I had a set on an old rear end in my backyard that I'm about to dump. Just saw your post.
Alex
Old Oct 15, 2008 | 03:40 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Oh well,thanks but I ordered some from GM PartsDirect. Suggest you save them as more people are switching from Delco Moraine disc to PBR disc and will need them.If you don't want to keep them I'll take them as I may do an upgrade on the 86 I just sold to a friend.
Old Oct 17, 2008 | 06:45 AM
FNFAL308's Avatar
Car: 91 Bird
Engine: TPI 350
Transmission: 5-Speed
Axle/Gears: 2.77 posi
Are those on disc e-brake, drum e-brake, or both? I just hooked mine back up after dropping in the new motor and rear end a few months ago and neither rearend I had, had those loops.
I was scratching my head on routing. Take out was 91 Firebird drum, and install has 89 IROC disc.
Any info on this?
Old Oct 17, 2008 | 06:51 AM
JamesC's Avatar
Any info on this?
Most have the "S" hook farther up the tunnel. A search should find you a pic.
JamesC
Old Oct 17, 2008 | 09:20 AM
FNFAL308's Avatar
Car: 91 Bird
Engine: TPI 350
gotcha - I have the s hooks
Old Oct 17, 2008 | 01:04 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
I,m using both. It will insure the cables stay away from the exhaust.
Old Oct 19, 2008 | 01:31 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
These are the ones you need for your 3rd gen. The issue is that the e-brake cables will (may) be pulled too tight if you use the differential mounted guides due to a difference in the cable lengths. This may or may not happen but I think it will.
This is how the 3rd gens need to be run:
HTH...
Ed
Old Oct 19, 2008 | 01:40 PM
JamesC's Avatar
Originally Posted by ebmiller88
[IMG]The issue is that the e-brake cables will (may) be pulled too tight if you use the differential mounted guides due to a difference in the cable lengths. This may or may not happen but I think it will.
No problem with mine.
JamesC
Old Oct 19, 2008 | 03:38 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Ed, do you have any of those s-hooks? Just discovered I only have one. If not maybe I can refigure a conventional s-hook from the local hardware store.
Old Oct 19, 2008 | 05:12 PM
JamesC's Avatar
The p/n for Guide, cbl is 14077776; however, the number, on GMPartsDirect, doesn't come up. Maybe the dealership....
JamesC
Old Oct 20, 2008 | 08:46 PM
ebmiller88's Avatar
I have a couple in the shop. Need one or two? I plan on hitting the U-pull it later this week and I usually pull them off cars when I think of it. LMK.
Ed
Old Oct 20, 2008 | 11:53 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Need only one of those s-hooks. The OEM setup only had one on the passenger side of the car. The drivers side cable went through a welded loop on the diff. housing only. So if you could spare one I would appreciate it. LHG
Bubbajones_ya
Oct 25, 2015 08:01 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
