South Central Region Board for the states of Texas, Oklahoma, and Louisana.
Rear Main Seal Question
Old Mar 9, 2009 | 08:05 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Any advantage of using a silicone or Fluoroelastomer rear main seal versus a OEM style rubber one?
Old Mar 9, 2009 | 11:31 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: Rear Main Seal Question
I think longevity is the answer, the OEM rubber is more prone to cracking and what not as the seal gets older. All i can think of anyway.
Old Mar 10, 2009 | 08:21 PM
epsmotorsports's Avatar
I would hope that the flouro-elastomer, silicone and other high-grade seals would be less likely to leak since they are a higher grade material than the OEM seal. Maybe check the fel-pro website and see if they have info or tests on it.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reborn756
Sep 4, 2015 03:42 AM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
