South Central Region Board for the states of Texas, Oklahoma, and Louisana.
i need 2" spacers or 2 wheels by saturday!
Old Jul 21, 2009 | 09:37 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
title says it all, my car cont make it out to the meet unless i can locate some 2" spacers or a set of rear wheels that are 3rd gen offset and clear 4th gen ls1 rear brakes. i have a couple possible options but nothing set in stone yet so if anyone could help me out i would really appreciate it
Old Jul 21, 2009 | 10:40 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Re: i need 2" spacers or 2 wheels by saturday!
I may have you covered. A friend of mine may have a set or two.... I'll call him tomorrow.
Old Jul 22, 2009 | 07:22 AM
esc's Avatar
esc
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
I have a set of '92 Z-28 wheels you can borrow if that will help.
Old Jul 22, 2009 | 09:07 AM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
if i can't get some spacers then i'll probably take you up on that
Old Jul 22, 2009 | 10:26 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Yea, the 91/92 wheels are great for what you got.
Old Jul 22, 2009 | 05:11 PM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
i got a buddy who will be at the meet that may sell you a set of 91 rims if that helps. ill ask him but he just got an 88 so he may not
Old Jul 22, 2009 | 07:03 PM
jrs84ta's Avatar
Car: 1984 firebird
Engine: swapping lt1
Hey I have some 2 in spacers that you can borrow if you want! they are on my car and it isn't running anymore the ecm went out 2 weeks ago so it won't be going to the meet in it
Old Jul 22, 2009 | 08:40 PM
one92rs's Avatar
Car: SOLD!!!!!
i thought i read a thread that you were going to stick with 3.73's. aren't you going turbo? why not go with 3.42's or lower in order to keep the turbo under load sooner?
Old Jul 23, 2009 | 12:33 AM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
im swapping to 3.73's.... i had 3.42' and they are just to high with the t56. as far as the turbo goes, i built a cross over and two manifolds, and they are sitting on the shelf, i ended up taking physics 2 E&M this summer along with working full time, so i haven't had much time . also a procharger is looking like it will be easyer and cost the sme so i may cut my losses (not much) and go that route, i've got the money saved up to do it i just need to DO it lol
Old Jul 23, 2009 | 12:35 AM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
i think i have some lined up already but thanks! in case those fall through where are you located?
Old Jul 23, 2009 | 11:35 PM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
AHHH pyle brothers "though" they knew better than me, disregarded my instructions to press the bearings on AFTER the backing plates and retaining plates, so now i'm going back at 730am to get them to fix it.
Old Jul 24, 2009 | 07:10 AM
esc's Avatar
esc
Engine: 377
Transmission: 400
They have probably not seen and EARLY model (pre-'89) Dana 44 before.
But if they had bothered to look at the parts it would be obvious how they need to go together. I can imageing just how it went...
Counter guy says, "The customer said it goes this way."
Shop guy says, "Ya Ya, Ive done this before, I know what to do,
just throw the box of parts in the corner and I'll take care of it."
This is probably the first botched job I have heard of coming out of Pyle Bros. shop.
I'll be interested in finding out how they treat you.
Old Jul 24, 2009 | 10:17 PM
jrs84ta's Avatar
Car: 1984 firebird
Sorry so late sail I'm actually on the west side of town on clay road 10 min from the bearcreek inside the beltway
Old Jul 26, 2009 | 08:40 AM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
I'm interested as well. I've had nothing but good experiences with them.
Old Jul 26, 2009 | 12:53 PM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
a little more back ground on the pyle brothers deal:
I dropped the rear end off last monday, they measured the axles and ordered custom ones from moser, told me they could have it ready by friday the 24th. thursday they call me in the morning (930am) and tell me i forgot to give them the retaining plates, which i did -my fault-, and that if i brought them they would put them on and press the bearings while i waited, and i could put the axles in when i got home so i could put the rear in that night (fine with me, it's easy to bolt in axles). i was at work so i had my dad run over there with the plates and the truck to pick up the rear.
Before i got off the phone with the pyle bro's guy i told him you have to press the bearings on after you put the backing plates AND retaining plates on, he told me i was wrong, but i explained to him it was an older axle pre '87 or whatever it is, and he said "we are gonna use "A-9" bearings that stick out far enough that you dont need to press on the backing plate. i was sceptical and told him to make sure it was right before they pressed the bearings on
i get off work, come home and start assembling the rear. the backing plates weren't pressed on and the bearing didn't work like they guy said. i call them (5pm) and tell them the situation. they say i dont think we are wrong but bring it all in tomorrow and we'll take a look.
i get to their place at 8am froday morning, the guys working in the shop couldn't really undersatnd what needed to be done, so the owner (one of the pyle brothers? lol) looked at my rear and understood what needed to be done to make it work. they cut off the old bearings, put the plates on and pressed new bearings on for free and i was on my way at 9am
i cant complain about the place at all, they do great work, like you said eric i've never heard anything bad about them, and there was just a "we do this all the time we know how" like you said, that turned into a "you should of listened" lol. they were super nice about it, their work is great it was just a little oops that they took care of asap with no complaints
and to everone who offered wheels/spacers, i ended up gettign some from a guy in college station
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
BlackFormula
South East Region
Sep 8, 2015 09:59 AM
Stryker412
Sep 7, 2015 09:11 AM
