Need vats bypass in houston
Car: 91 Bird
Engine: TPI 350
Transmission: 5-Speed
Axle/Gears: 2.77 posi
Need the one that bypasses vat module - mine is bad and don't want to pull dash
1 Post
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
Re: Need vats bypass in houston
you still have the original key? if so send me a pm with your phone number and i'll walk you through what you need to do to bypass the VATS
Car: 91 Bird
Engine: TPI 350
Thanks but I went ahead and pulled the dash. Not near as bad as I imagined. Plugged the spare vats in and it fired right up. I changed the ign lock out yesterday to one that matched the spare vat. I did not put the vats back where it was - gonna remount it somewhere more accessable.
