South Central Region Board for the states of Texas, Oklahoma, and Louisana.
In need of some help in the Houston Area
Old Nov 28, 2010 | 02:46 PM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
I thought about going to a local shop here is pasadena but most of them here always add on things that arn't even bad on the car. I just dont trust them.
My predicament is my transmission isn't sitting on the mount fully and my enging ( well to me ) seems to be tilted upward on the driver side. my pully belt was rubbing on the radiator hose.
I just need some expertiece to look at it for me to figure out the problem.
Old Nov 28, 2010 | 02:53 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: In need of some help in the Houston Area
well just a tranny mount being broke wont let the engine move across that far. i think the tranny mount has been broke and now an engine mount is as well.
Old Nov 28, 2010 | 03:50 PM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
I'v had both motor and tranny mounts replaced within the last coupel months but i got them replaced at my school's auto tech class. maybe they did something wrong.
The mount's that were on it before were all bad.
Could I have ran the enging too long on bad mounts causing something to bend?
Old Nov 28, 2010 | 04:00 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
hmmm, i'm agreeing with lance that it's your mounts, the transmission mount isn't hard to destroy in these cars, so that probly went first then your engine mount was the next to go.
there's nothing to really bend that would cause what your describing, take a look at your mounts and tell us what they look like then we can go from there
Old Nov 28, 2010 | 04:19 PM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
I just did a visual check and they look the same as from the day i got them put on besides some dust. Ill take a closer look at them tomorrow when it's light out.
Old Nov 30, 2010 | 05:42 PM
one92rs's Avatar
Car: SOLD!!!!!
the tranny mount is usually easy to tell. get in it and drive down the road slowly and floor it. if you hear a clunking noise then the tranny mount is bad. but if the tranny mount is bad enough to cause the engine to move over that far then something else is most likely wrong as well.
Old Dec 2, 2010 | 09:27 PM
one92rs's Avatar
Car: SOLD!!!!!
was this ever figured out or no.
Old Dec 3, 2010 | 09:20 AM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
my tail housing does pop when i floor it from a stop, but thats all iv had time to do. but that be because the transmission isn't sitting on the mount fully
Old Dec 3, 2010 | 02:16 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Swap out to a energy suspension piece.
Old Dec 3, 2010 | 05:05 PM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
totally a broken tranny mount...
Old Dec 4, 2010 | 01:31 PM
Jupiter's Avatar
Car: 82 Trans Am
Engine: 383
Axle/Gears: Built 4th gen 3.42 posi/disc
Indeed tranny mount sounds broken although it may not appear as such.
I've broken EVERY factory tranny type mount i ever had in a f-body while
my energy suspension tranny mount has NEVER been broken with all the
slamming i have done on my T-10.
As far as the motor 'appearing' to be sitting high on driver side. It sounds
like a motor mount may be broken and/or it is not seated properly. I have
run into this myself on a friends Elky. You need to look closely at the motor
mounts and make sure the 'TABS' are seated properly.
Here is a pic showing the tabs i speak of.
'not an f-body mount, just an example'
Old Dec 5, 2010 | 01:38 AM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
I'll take a cracknat it in the morning. I'll let yal know if I have any luck
Old Dec 5, 2010 | 04:18 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Same here, my new truck has a jolt from a dead stop, i have to look a it when i get up.
Old Dec 5, 2010 | 04:00 PM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
So i checked it out today and all 3 mounts are trashed.
My engine mounts arn't even seated properly.
this time ill get me poly mounts and take it to a shop and not my schools auto tec
Attached Thumbnails In need of some help in the Houston Area-dsc01492.jpg   In need of some help in the Houston Area-dsc01493.jpg
Old Dec 5, 2010 | 06:04 PM
Jupiter's Avatar
Car: 82 Trans Am
Engine: 383
Good to hear you got that all figured out.
Old Dec 5, 2010 | 09:19 PM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
No better way then to do it yourself... i know the motor mounts are a pain but the tranny mount is too easy to do by yourself and not pay the extra money to have it done...
Fireslash
Apr 11, 2016 06:43 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
KCG
Mid-Atlantic Region
Oct 25, 2015 06:57 AM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
