Need engine hoist - League City
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
hey fellas, my engine hoist is too short to pull the motor from the front without taking off the bumper, anybody have one I can borrow tomorrow that will get the job done?
- Alex
- Alex
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: Need engine hoist - League City
thanks for the offer lance but didnt end up making it to he garage today LOL, I'm going to go to SSS steel tomorrow to get some 2.25x2.25 stock to extend the arm on my lift, it that doesn't work I'll see if yours will reach
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
I have the cheap harbor freight one and with the hydraulic ram touching the front bumper its still 18" short of being over the center of the motor
man dude. mine will lift 89" up. but the reach at that point is only 36"
i suppose at some point tomorrow you will be at the shop right? pm me the time and addy.
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
I drilled a new set of holes in the arm on mine to give me a few inches more length. If I get it right up against the bumper and lift from a little in front of the center of the engine it works.
Most often I pull the engine and trans together. If you are pulling just the motor it should be easier.
Engine: 377
Transmission: 400
I've got six of the 85 lbs/hour TBI injectors getting cleaned right now. I expect to pick them up tomorrow.
I also just got eight 60lbs/hour port injectors that I will be adding to my setup as soon as the new manifold (Victor EFI) is ready. I'll still need to work out the new ECU to control both sets, but it should be nice when it is finished.
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Engine hoists are for sissies.
Man-up & build an A-frame, that will lift the eng-tranny
up over the roof.
up over the roof.
Engine: 377
Transmission: 400
A frames are for wimps, all a real man needs is a come-along and a tree.
I've done it that way before.
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
pshhhh real men just stand on the strut towers and lift the sombich out!
this is what I ended up doing, I need to extend the lower arms so It wont want to tip over but it works pretty well
God I luv this place!!!
I bow to the BS masters.
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
im liking the mod of the engine hoist. i have the same one, but i got it from jegs a few years ago. i might have to do the same thing with mine. i wanna steal my dads aframe he built. its a good 16 feet tall and has been used to lift a honda completely off the ground once before.
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
a word of caution if you mod the hoist; The long base legs with the casters need to be extended to be just a little bit longer (well really just to the same length but a little factor of safety never hurts) than the lift point on the arm (where the chain attaches) when looking at the lift from the side, so the moment from lifting something will never be able to flip the hoist (assuming your on a stable surface).
It was only $74 for 24' of 2.5'" @ 1/8" wall square tubing at SSS steel wich leaves PLENTY to make the long arm and legs.
BTW if anyone local wants to borrow it just lemme know
colton_carlson
Mar 8, 2019 12:21 PM
