SUSPENSION UPGRADES
Car: 1989 GTA, 2004 Z06, 2008 Expedition
Engine: L98, LS3, 5.4L
Transmission: 700R4, MN6, Auto
Axle/Gears: 3.23, 3.42, ?
Re: SUSPENSION UPGRADES
Pretty much done everything bolt on and weld on underneath the vehicle.
Car: 86 IROC
Transmission: Automatic
Axle/Gears: Stock GM
THATS COOL. AT THE SHOP WHERE I WORK WE INSTALL PERFORMANCE SUSPENSION SO IF YOU OR ANYONE YOU MAY KNOW NEEDS ANY ADVISE OR REPAIRS LET ME KNOW.
Car: 86 IROC
YES WE DO. WE HAVE TWO DIFFERENT KITS WE OFFER. ONE IS OUR BASIC SUBFRAME CONNECTOR KIT WHICH JUST BOLTS THE FRONT FRAME TO THE REAR BODY OF THE CAR. OUR OTHER KIT IS A TRUE 100% SUBFRAME CONNECTOR KIT WHICH BOLTS THE ENTIRE FRAME AND BODY TOGETHER. IT ALSO HAS A SECTION THATS GOES AROUND THE DRIVESHAFT SO IF SHAFT WERE TO COME APART FOR ANY REASON IT WOULDNT DAMAGE THE BODY OF YOUR CAR OR HARM ANYONE.
I HIGHLY RECOMMEND THIS KIT.
THE BASIC KIT IS 320.00 PLUS TAX INSTALLED
THE 100% SUBFRAME KIT IS 460.00 PLUS TAX INSTALLED.
Car: 1986 IROC-Z28 & 1987 GTA
Engine: 305 TPI & 350 TPI
I plan on buying the UMI subframe connectors. how much will you guys charge me for the install? & whats the shop called?
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Or let me know when my schedule lines up for you and I have no problem helping you install for free. I can even weld them in of you desire. Or make a set from mild steel that can save some bucks. I don't mind helping forks with little stuff to save cash. I'm a poor boy.
Thanks.
Car: 86 IROC
It's only 112.00 for installation. The name of the shop is fast sticker and lube. The address is 2621 n. Shepard dr. 77008. Where right off n Shepard and 610.
84 TA NV
Sep 6, 2015 08:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
