South Central Classifieds for the South Central Region
FS $2000 '88 Camaro 327 Auto w/ shift kit [W Houston]
Old Feb 11, 2011 | 08:49 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Axle/Gears: 3.42 T2R
88 Camaro sport coupe (they didn't have RS that year), faded red with gold ground effects was a TBI car
clear tx title
has iroc hood with louvers, also red but peeling
has "low rise" iroc-ish factory spoiler.
has gold 16" iroc wheels no center caps, bald tires
new u-joints
new rear shocks
good "nose"
TBI single electric fan setup.
adjustable fan temperature control.
TPI fuel pump
Good dash pad (one crack)
cracked windshield
peeling tint on rear window
small dent in driver door (will include a spare red door)
smaller dent in passenger front fender
roof is oxidized / true surface rust only. no rust holes anywhere on car
both power window motors need replacing (windows go up only with help)
interior all there except headliner fabric and radio
carpet and seats dirty & stains. tear in driver seat lumbar bolster.
no freon
not registered/inspected since '07
new pads & shoes on drum brake rear end, has 3.08 gears, added a used factory posi.
resealed 700 r4 (from 87 iroc) with new transgo shift kit, new 2400 stall roadrunner (ebay company) lockup converter, transgo 3-4 shift allows you to hold OD at high speeds,
ENGINE IN THE CAR
1967 327 engine. was originally 275 HP 2 barrel. was previously rebuilt .060 over, disassembled, bores met specs no need for additional overbore. had block cleaned, new cam bearings, new freeze plugs and cylinders bottle brush honed at machine shop to accept. new .060 over speed pro hypereutectic flat tops 2 valve reliefs (9.7 CR in this engine), new summit high volume oil pump & pickup, new gaskets, ARP rod and main bolts, had rods resized and pressed onto pistons at machine shop. new lunati 60103 hydraulic cam, new factory replacement hydraulic lifters, new pushrods, new GM self aligning rocker arms (stock ratio), new patriot performance vortec heads, 64 cc vortec style chamber, 185 cc runner, cast iron, drilled for both vortec & standard intake manifolds, drilled for modern accessory drives, 2.02 / 1.60 stainless valves, z28 valve springs, edelbrock positive seals on all valves. non-vortec performer rpm intake with 625 road demon jr. rebuilt carb (electric choke), chrome stock-style centerbolt short height valve covers, factory 1988 serpentine system. chrome water neck, 180F Mr. Gasket thermostat. Engine has only been on test drives, probably 10-15 test drives at 10-15 miles each.
EXHAUST IN THE CAR
hooker shorty headers with new O2 sensor and add AIR injection manifolds (welded on), percy's reusable header gaskets. Mandrel bent 2.5" y-pipe, walker cat (with air pipe) dynomax 2.5 mandrel catback, thrush welded (flowmaster copy) muffler. sounds good y pipe has bung for wideband sensor.
holley adjustable fuel pressure regulator with return lets you use carburetor with TPI or other high pressure pump.
the heads: https://www.patriot-performance.com/...&cat=76&page=1
the cam: http://www.lunatipower.com/CamSpecCa...rtNumber=60103
Asking $2000.
Email (or PM) to .
Old Feb 12, 2011 | 09:50 AM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Re: FS $2000 '88 Camaro 327 Auto w/ shift kit [W Houston]
Old Feb 12, 2011 | 05:50 PM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
do you got any pictures of the engine bay and interior?
Old Feb 12, 2011 | 05:56 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Old Feb 12, 2011 | 06:59 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Old Feb 12, 2011 | 07:06 PM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
Is it possible for me to take a look at it tomorrow? I live on the east side of houston
Old Feb 14, 2011 | 07:09 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Foster came and looked at the car. Said he loved it, but doesn't have the money quite ready and if I find another buyer, not to wait on him.
The car cleaned up fairly well. I was surprised at how complete the interior is. I never knew there was a cover for the ALDL port! I took new (clean) pictures and updated my previous posts.
I will also include a set of new Richmond 3.73 gears (thick style), Jegs install kit, and what I believe is a Hurst Shifter with B&M T-handle.
Odometer reads a low low 13,xxx miles . So it's more likely 113,xxx miles on the chassis.
Old Feb 14, 2011 | 07:59 PM
Foster382's Avatar
Car: 1991 Formula
Engine: 350TBI
Yeah I did, way cleaner than my first Camaro.
If You would do it in payments I would have it all paid off in a month and a half
Old Feb 17, 2011 | 09:18 AM
lonestar7's Avatar
Car: 1988 Firbird formula 350
Engine: 5.7L TPI
Axle/Gears: 3.27 Nine Bolt
Hi,
I'm up in Austin. I might be interested in the car but I would have to drive it back to Austin, is it running good enough to do that?
Also, I see it's not been inspected or registered for a while. Do you think the car can get passed inspection and emission test so it will be legal to drive?
Thanks,
Dave E.
Old Feb 17, 2011 | 11:19 AM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Originally Posted by lonestar7
Hi,
Thanks,
Dave E.
It runs and drives fine (I've only had the car just over a week, adjusted the timing a bit since Foster test drove it). I don't know about getting it emissions tested. It has the air pump, headers with the pipes, cat etc, but it is carbed. I *think* if they are sticklers and do a visual and know that it should be tbi, then they would fail you.
Old Feb 17, 2011 | 11:31 AM
lonestar7's Avatar
Engine: 5.7L TPI
Yea, I was afraid of that, won't be much good to me if I can't drive it. But wait 2 more years and it won't be an issue, no emissions test for cars 25 years or older in Travis county, maybe in Harris county too.
Old Feb 17, 2011 | 08:44 PM
I_R_O_C_Z_2_8's Avatar
Car: 1991 Trans Am GTA
Engine: 350 tpi
Pm sent
Old Feb 17, 2011 | 08:52 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Hi,
Thanks,
Dave E.
Something else I would be wary about myself, as stated, the tires are pretty worn. I checked the date codes, 2002. Might be ok for a long drive home, I just don't want to gaurantee it.
PM replied to.
Old Feb 18, 2011 | 02:08 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Sale pending...
Old Feb 21, 2011 | 04:22 PM
J0hn_J0hn08's Avatar
Car: 1986 Iroc-Z
Engine: 355
Wondering, is the car still for sale?
Old Feb 21, 2011 | 08:56 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Just got off the phone with the guy that looked at it Friday and said he wanted it for the motor and trans, but would have to wait til today to get the money. Well, that didn't go thru, so the car is still up for grabs.
First $2000 cash in hand takes it. Or be prepared to leave $500 if you want me to hold it for a week while you get the rest of the cash and/or make arrangements to bring it home.
Old Feb 22, 2011 | 07:43 PM
92_T-5's Avatar
Car: 92 Camaro T-5
Engine: tbi 305
Transmission: t-5
Axle/Gears: ?
i got a friend but you said it dont have inspection stickers ? an it wont pass?!?
Old Feb 22, 2011 | 07:48 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
If it's an emissions problem, that car is going to be grandfathered in very soon.. that would help for a texas buyer.
Old Feb 22, 2011 | 08:13 PM
Stephen's Avatar
Car: 87 GTA
Everybody is always thinking that once a car passes the 25 yr mark, they can rip off the emissions stuff & the car will pass. That is 100% wrong.
For the Emissions Test it has to be there & what comes out the tail pie has to be clean. After 25 yrs, no more Emissions Testing, but there is still the Visual portion of Inspections.
For the Visual Test, the stuff still has to be there.
So.....
Cats cannot be taken off.
AIR tubes cannot be taken off.
Smog pumps cannot be taken off.
FI cannot be replaced with a carb.
The stock snorkle air cleaner cannot be replaced with an open element one.
Etc., etc., etc.
In other words.....Your FI converted to carb will never legally pass in the state of Texas.
Old Feb 22, 2011 | 08:46 PM
58mark's Avatar
that's all true, but it does get a lot easier to find a shop that will things slide after you pass that 25 year mark
Old Feb 23, 2011 | 04:37 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Yea, easy to find a shop that wont open the hood or give a ****, as long as it is not camming its assoff like mine, LOL.
As for legally pass? Technically, you can fail near 100% of cars that get inspections because there is literally something you can always find to fail a vehicle, even new believe it or not. That is just from what i have seen when i used to work on shitboxes for a living.
Old Feb 23, 2011 | 07:14 AM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
So.....
Etc., etc., etc.
No idea if it would pass the sniffer since it's never been tested with this motor. Not a big deal if you live in a non-emissions county. *If* they do the visual and are sticklers then it technically wouldn't pass due to the bolded items above. But with the smog pump and cats that are still on the car, it should be easier to persuade the tech to pass it.
I do have a complete 305 TPI motor I could sell with the car...
Old Feb 23, 2011 | 07:20 AM
58mark's Avatar
I wonder if it's possible to put a stock type air filter from a TBI car on your car just for inspections... with that setup, I'm wondering how many people would even look to see if it'sa TBI or a carb under there
Old Feb 24, 2011 | 08:20 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
SOLD!!!
junior419
Apr 7, 2025 11:35 AM
1Aauto
Sponsored Vendors
Jan 20, 2016 01:01 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Dragonsys
Sep 25, 2015 03:51 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
