Desert Rats.................
Engine: 305TBI
Axle/Gears: B&W 9 Bolt 3.73
You Arizona F-Body guys are hard to find.
Hopefully you guys will be hosting another meet in AZ i would like to come (except i'd be bringing my Ford truck) My Camaro is sick been sitting for 2 years and isnt road worthy since it will never pass emissions, too many leaks, i recently did an engine/tranny rearend swap, it burst into flames twice actually couldnt put out the 1st fire had to wait for the battery cable to burn completely threw
and TBI caught on fire didnt touch car for week was scared to death and I need an F-body gurue to look at it,
anyway i live way out Past Loop 303 for those that dont no where that is its the other side of Luke Air Force Base. on the White Tank Mountains. 13 minutes from buckeye. http://www.fl-thirdgen.org/camarophreak.html <there are some of my pics.
and TBI caught on fire didnt touch car for week was scared to death and I need an F-body gurue to look at it, anyway i live way out Past Loop 303 for those that dont no where that is its the other side of Luke Air Force Base. on the White Tank Mountains. 13 minutes from buckeye. http://www.fl-thirdgen.org/camarophreak.html <there are some of my pics.
Engine: 305TBI
I see that, sorry this post was supposed to have a pic on it, but I messed up.
Car: 91z28 and 88 SC thats for sale,in the sig
Engine: 305 TPI soon 383 stroker or 327
Transmission: t-5
welcome to the boards,me and aziroc live out on the west side also, 107th n northern for me. we go to the pavillions car show sometimes. check out azfba.com, they have alot of meetings and events.
Engine: 305TBI
Originally posted by 89FRMLA350
How bad is the damage to the car? Got any pics of it?
Car: camaro
Engine: mighty 305
Transmission: mighty 700r
my tbi has been threw 2 fires as well... sucks..
mine is soon going to be replaced.. i am strongly debating going to carb but still undecided might go tpi..
the 2nd fire bunt up my entire wire harness.. fixed it though and i am no expert by far..
Shawn
Shawn
Engine: 305TBI
bad thing is i need to find a used TPI I cant afford the new stuff, if i have to buy new then i will keep the tbi and cut the intake for a 4bbl tbi, i dont care much about the cond. of the harness or the TPI's looks it has to pass the emissions not beauty pagent. nor the intensive labor. ive read the posts on this site on TPI's and think that is what i want.
Car: 86 IROC-Z
Engine: 406
hey whats up... sorry to hear about what happened to the car... but hey, as long as u still are trying to fix it
im out by 115th/thomas, like sabatian said, so if u need any help just email/pm/AIM me (falcon978@aol.com/falcon978) . BTW.. id like to give u heads-up to THE BEST car club here in AZ ... www.AZFBA.com check it out.. sabatian knows abotu the guys and such.. just cant find the $20 to join.. yet he "is building a 383"
(damn we need an OWNED smilie here on thirdgen.org )
as far as carb/tpi: trust me. go TPI. u wotn pass emissions unless u either but the q-jey back on the intake and mayeb get the car running.. or build a really weak engine.. were as u go TPI, well// u can see what i have done so far.. and that was with NO smog stuff at all..
Engine: 305TBI
Shawn
Shawn
Engine: 305TBI
i have all the emission crap for the TBI including that worthless airpump, the exhaust leaks really bad im not sure if the Y-pipe is good or the cat is too small it the same one off my 2.8l i know the tailpipes are cracked at the rear but near the engine it sounds way worse. its bad enough that the car loses power after 3500 rpm if i can get one of you guys to give a phone number, or ill give mine over a PM i'll start it so you can hear it. its bone stock, maybe the headers are cracked?
Car: camaro
Engine: mighty 305
chris ask mike how much he'll charge me to put a tpi on top of my engine and wire it up.. otherwise i'll have to do it myself it wouldnt be fun...i could buy all the parts and what not over time..
i know i can find a kit cheap (tpi) i am just looking for some power and tune-ability (ghetto vocab).. tbi just doesnt have all the tuners like a carb engine or tpi engine does...
chris havent you talked to sabatian yet?? Ask him what i found for him.. Its red and its alot faster then what he's got.. oh yeah its not tbi.. sorry sabatian spilled your beans.
Shawn
i need a head swap/cam swap/rear end swap/and which ever injection i go with.. who wants to help?
Shawn
From: Tucson AZ where the 3k ft of elevation kills your time
Car: 89 camaro rs
Engine: 383 .06 over
Transmission: th350
Axle/Gears: 3.73 10 bolt
well i have done both tpi and carb swap and i would have to say that carb is a lot easyer then tpi swap but i know that the tpi swap is posabale. for anybody that wants to do a tpi swap the best and esayest way to do it it to find a doner car. You could probaly pull it off with out one but it would be to hard and more inportently it would cost to much money. you could buy some peace of junk iroc or formula for less then 1000 bucks some where i am sure. i have bought one my self. but if you did a carb swap you would have to buy most likely all new stuff but less expensive stuff. you can still get a carbed car through emissions it will just be a lil harder then a tpi setup.
Car: 1984 Trans Am (KITT)
Engine: 350 w/ cam
Transmission: TH700R4
Axle/Gears: 3:73
Actually, up through the end of the year it's $10 to join.
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
Re: Desert Rats.................
Hopefully you guys will be hosting another meet in AZ i would like to come.....
Good luck with your car though. I may be a little bit of a drive from you but if you want PM me and I'll give you my cell number. I'm also looking for that $10-$20 to join AZFBA....:lala:
Switched to a SR intake so I removed the LTR stuff.
I have a ported plenum (top is polished), edlebrock runners and edelbrock lower intake that is sitting in the garage. There is a very small crack on the front corner of the lower intake, in front of the first bolt hole. I never had a problem with it sealing, ever. Other than the little crack, everything is in good shape.
PM me if interested.
Engine: 305TBI
Actually i have found some cheap ez mods to do on the TBI, to gain some power out of it other then just buying a 4bbl unit.
The TPI isnt totally out of the question except for the cost and install time, well the biggest problem i see with most tpi units on ebay is they are in need of new parts like fuel injectors and wiring harness if i have to replace that then why not just buy a brand new setup its actually cheaper in long run then nickel and diming myself to death.
