South West Region South West regional discussion board.
part request: lower control arm
Old Apr 2, 2004 | 02:31 PM
400cidz28's Avatar
Does anyone around Phoenix have any lower control arms sitting around? I'll pay $$. I think my front left arm is slightly bent and causing my car to pull.
Anyone know of a good salvage yard for 3rd gens in phoenix? north phoenix?
Old Apr 2, 2004 | 04:55 PM
82Z28NAZ
Guest
Posts: n/a
check Ecology, dude... they have a ton of 3rd gens
Old Apr 2, 2004 | 05:09 PM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
werd.. that place has tonds of 3rd gen stuff.
Old Apr 3, 2004 | 01:12 PM
82Z28NAZ
Guest
Posts: n/a
first off... what makes you think it's bent? has it hit something?
Old Apr 3, 2004 | 01:19 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
Where is Ecology?
Old Apr 3, 2004 | 03:17 PM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
Ecology Auto Wrecking
320 S 27 Av
PHOENIX, AZ 85009 - 5052
(602) 233-2277
Old Apr 3, 2004 | 03:18 PM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
Ecology Auto Parts
(602) 352-6161
Old Apr 4, 2004 | 05:01 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
I have two!!! I think they might be a little rusty, but still good to go! Let me know!
Old Apr 4, 2004 | 07:38 PM
mrt89rs's Avatar
From: Tucson AZ where the 3k ft of elevation kills your time
Car: 89 camaro rs
Engine: 383 .06 over
Transmission: th350
Axle/Gears: 3.73 10 bolt
Re: part request: lower control arm
how about taking it somewhere and get an alignment done to it i think that should salve your problem and if it doesn't then they will be able to tell you what it is that it needs in order to get it aligned.
Old Apr 5, 2004 | 02:11 AM
400cidz28's Avatar
I took it to an alignment shop, caster was way off...cross caster was -4.71! The guy I bought it from said his wife hit a curb, who knows. I'm tryin to fix a problem I have when I brake, it pulls really hard to the left, I mean it pulls so hard that it's dangerous braking at high speeds. It drives pretty straight otherwise...even with whatever is bent making my front left tire sit .75" farther back than it's supposed to.
Old Apr 5, 2004 | 03:07 AM
400cidz28's Avatar
well I'm going to replace the hose and caliper on the left side, since I just did it to the right trying to fix the problem(which it didn't). I think it may be a sticking caliper on the side it pulls to.
Then if that doesn't do it...I guess I'll have to tear into the suspension...so the LCA and k-member are on hold for now.
Old Apr 6, 2004 | 12:48 PM
mrt89rs's Avatar
Car: 89 camaro rs
Transmission: th350
Caster will sometimes cause a pull but it is usually cross camber that does it. but if the car pulls when you step on the brake's then you have a hydraulic problem or your pads are defective this is a really conmen problem with AutoZone pads and raybestos pads. a quick way to find out if it is your pads all you have to do is swap your front pads from one side to the other. if it starts to pull to the other side then you need new pads if not then you have a hydraulic problem. IF it pulls to the left then you have a problem on your left side. If something is bent replace your Spindale first that's the weakest part in the front suspension on our cars. But before you do anything just look at everything under your car and compare it with the other side and see if you can find anything out of the ordinary, something that may look bent. check to see if any chunks of rust, oil, dirt, and other crap has some how mysteriously fallen off you car if so that's where the bend is at, then replace what ever that is as well.
What about camber? And cross camber? Do you remember? Has the car been in an accident? If so how bad was it you might have bigger problems than what you think.
hope this helps, mike.
Old Apr 6, 2004 | 10:07 PM
400cidz28's Avatar
Well I fixed the pulling problem, it was a bad caliper on the same side it pulled to.
1992rs/ss
Jan 31, 2025 05:10 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
