South West Region South West regional discussion board.
Track Times Dec 3
Old Dec 3, 2004 | 11:00 PM
matt3383's Avatar
Car: 2000 Camaro SS
Transmission: t-56
Axle/Gears: 4.10
Track Times Dec 3
Just want to see what everyone ran this Friday. This was the 1st time i had run my car down the strip and got a 15.191 91.98 MPH.
I was wondering if that is a normal time for my car or not. Im sure i could use a tune up, and stuff, but im not sure with the MPH if it was more my driving or the car itself that caused the low times? Speak freely i want to know what to work on if its me too
Old Dec 4, 2004 | 01:35 AM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
Guy I used to work with had a stock 350tpi/700r4 outta a 92 Z28 (engine still stock) in a 90 IROC vert and his ran a 14.5. Don't know the MPH, but it did it rather consistantly... You still feel iffy about your launching? What kinda 60' times were ya runnin?
Bruce (90RS305)
Old Dec 4, 2004 | 10:47 AM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
My last run was against my roommate in his 86 Bird with a 350. I cut a .09 light and he cut a .36. He caught me and beat me by one car length, the bastard . But that was my best run 15.011...so close yet so far! My best MPH was 95.75 but I couldn't do burnouts or launch all night which I'm assuming is a result of my clutch being near death, oh well. I'm sending my computer out today to get the Prom stuff put in, and should be goin back next week to get into the stupid 14's
Old Dec 4, 2004 | 02:59 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
So I was wondering how the races went last night and who actually showed up? Can someone post some times?
Old Dec 4, 2004 | 03:07 PM
matt3383's Avatar
Car: 2000 Camaro SS
Transmission: t-56
Axle/Gears: 4.10
time slip
60' - 2.356
330- 6.445
1/8 - 9.811
MPH - 71.00
1000 - 12.728
1/4 - 15.191
MPH - 91.96
Old Dec 4, 2004 | 04:45 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
I ran twice and had a 15.6 both times. One with a 2.2 60' and one with a 2.4 60'. The second time was the worst I have ever spun at the line. Track was very cold. No traction. But I just had regular time too.
Old Dec 5, 2004 | 05:12 AM
90RS305's Avatar
As far as turn-out is concerned....I'm still in shock:
90RS305
Snflupigus
SwartzCamaroRS
azvolfan
TonyC w/Roomie
90_Formula_WS6
matt3383
GearDrive63
I think I'm missing one or two, and on top of that there were a few other random thirdgens as well! Aside from the Tucson gathering, this was BY FAR the best TGO turnout I've seen!
Bruce (90RS305)
Old Dec 5, 2004 | 10:44 AM
90RS305
Snflupigus
SwartzCamaroRS
azvolfan
TonyC w/Roomie
90_Formula_WS6
matt3383
GearDrive63
Bruce (90RS305)
Thats great....too bad niether one of my 3 camaros is in racing form otherwise I would have gone for sure.
Old Dec 5, 2004 | 11:58 AM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
Re: Track Times Dec 3
my 90 iroc with L98/700r4 ran a 13.97 @ 97mph, with only a muffler and a 2100 stall. i think your times are a lil high. you should be able to pull mid 14's at least....your trap is pretty low too, give your car a tuneup.
Old Dec 5, 2004 | 09:03 PM
mrt89rs's Avatar
From: Tucson AZ where the 3k ft of elevation kills your time
Car: 89 camaro rs
Engine: 383 .06 over
Transmission: th350
Axle/Gears: 3.73 10 bolt
time slip
60' - 2.356
330- 6.445
1/8 - 9.811
MPH - 71.00
1000 - 12.728
1/4 - 15.191
MPH - 91.96
ok it's preaty esay. you see you have traction problems that first lil group of numbers is tilling you how long it takes for you to go from the line to 60 feet away, and yes 2.356 is a long time. if you put a set of slicks on your car or changed your driving habbits so that you could pull off a 2.0xx 60' then you would run some where in the 14.8, 14.9 area. wich sounds alot more like what you should be running if you are trapping 91mph. MPH is what really matters when you race on the street. NOT 1/4 MILES TIMES.
Old Dec 6, 2004 | 12:45 PM
matt3383's Avatar
Car: 2000 Camaro SS
Transmission: t-56
Axle/Gears: 4.10
Yeah i was having huge traction problems that night. I couldnt seem to get a decent launch, even if i babied it off the line then punched it they would break loose. I have 245 50 16s all the way around, my roomate was telling me to stick some 275s on the rear to help. But i think a tune up would help out a lot. I had a small miss awhile back and replaced my cap and rotor, but never did the plugs and wires. I will be getting those for X mas. Project Iroc, you ran a sub 14 with the same set up i have lol, WTF !! I have a stock motor ( i put on a cone K & N on the end of the intake tube) and a different muffler. And i have a 2200 stall converter. Do you really think that a tune up would drop my time that much? The car runs fine, no misses or anything. I know i have ring blow by, maybe thats what is hurting my motors performance.
Old Dec 6, 2004 | 02:06 PM
90_WS6_Formula's Avatar
Car: 91 Z28
still running 16.3's... I should catch a good tailwind and open the hatch
Old Dec 6, 2004 | 02:40 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Haha, next time shave your entire body and take a big crap before you race, 16.0's easily!
Tony
Old Dec 6, 2004 | 04:33 PM
Car: 91 Z28
a haircut could get you into the 14's
nah... there's a lot I could do to the car to get it into the 15's but I'm going to focus on the IROC for a bit.
Old Dec 6, 2004 | 06:39 PM
SchwarzCamaroRS's Avatar
bastards wouldnt let me run, drop tops MUST HAVE helmets... bullcrap... anyways... im sure i would have ran mid-hi 15's on good runs... eh, whatever though, after seeing the turnout there at the bird, i dont think ill be going back to race for a while, i need to have a lil more work done before i run... new stall, heads, cam, chip... then i should be 14's... still fun though
Old Dec 6, 2004 | 07:20 PM
Car: 1990 Iroc-Z
91mph is still a low trap. specially for a 91-92 L98. i say something isn't right.....:dunno:
Old Dec 6, 2004 | 11:47 PM
mrt89rs's Avatar
Car: 89 camaro rs
Transmission: th350
Well I was going off what he ran not what he had. I don't have any idea what he has under the hood, just telling hem what he would run if he where to get some traction. I don't know very many l98's in stock shape that will trap some thing better then a 91mph. But I bet that there are a cauple out there that will.
Old Dec 7, 2004 | 03:49 AM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
If thats a 91mph trap speed in tucson, I'd call that normal for a stock 350tpi, but in phoenix, thats pretty low. I know for a fact that cars that drive up to phoenix to run usually go 2-4 mph faster.
Old Dec 7, 2004 | 07:16 AM
Car: 91 Z28
any of you tucson guys have an LG4 intake laying around?
Old Dec 7, 2004 | 06:13 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Let's just say the last person to make fun of the fro did not live to tell about it
Old Dec 7, 2004 | 06:49 PM
azvolfan's Avatar
I thought that was me!!!!!
Old Dec 7, 2004 | 11:12 PM
Car: 91 Z28
relax dude... I used to have a huge fro sticking out of the t tops in the 85.
It's going to be a while before the Formula goes back to the track. I might grow mine back
I still need and LG4 intake (H code 305) intake if ANYONE has one.
Old Dec 8, 2004 | 10:13 AM
mrt89rs's Avatar
Car: 89 camaro rs
Transmission: th350
What do you need that for? Those things are junk. Is it going on to somthing that you want to make somewhat fast?
Old Dec 8, 2004 | 02:12 PM
Car: 91 Z28
yes... do you have one?
Old Dec 8, 2004 | 11:37 PM
mrt89rs's Avatar
Car: 89 camaro rs
Transmission: th350
NO i don't have one but if you want to make "this certian car" fast then you just might want to put somthing on there that is a lil better then a lg4 intake. What is it going on?
Old Dec 8, 2004 | 11:53 PM
Car: 91 Z28
do you have a better intake in mind?
Old Dec 9, 2004 | 12:01 AM
azvolfan's Avatar
What was wrong with the Weiand 7525 intake you had?
Old Dec 9, 2004 | 12:03 AM
Car: 91 Z28
I still have it... for the time being... it's up for auction on Ebay. I'm going to be running a carb on my other car. I need a dual plane intake.
Old Dec 9, 2004 | 12:10 AM
Car: 91 Z28
I'm giving up on my TBI project. I'll resume it when funding and time allows. Right now the Formula has been retired to "daily driver" status and the IROC is going to be the track car.
Old Dec 10, 2004 | 12:45 AM
mrt89rs's Avatar
Car: 89 camaro rs
Transmission: th350
305
so what all do you have in that thing, some specs? cam?
Street Lethal
Apr 30, 2019 12:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
