Prominated!!
Car: A Camaro
Engine: Weak
Transmission: Weaker
Prominated!!
Well I woke up from a nap after working on someone elses car all day and decided **** it, even though I can't do any part throttle or WOT work on the prom, I can still mess with the idle and some constants. So I took my laptop out to the garage, plugged her in and
. It was great, I'd set the idle for 1100, hit upload and the idle would just climb up to 1100, set it for 425, hit upload and the car would do its best not to fall on its face
. Finally quit screwing with it and left it at 575, then turned off EGR, turned off the speed limiter and smiled some more. I can't wait to get my laptop battery so I can datalog the thing and get into some real work. I also tried to turn of the stupid shift light but couldn't seem to find those values for some reason. Anyways,
Car: currently thirdgenless!!!
Sounds good Tony.
I'll get back to burning as soon as I can figure out why the chips I burn will not work. I burned a copy of my dyno tuned chip and it works fine. But now I can't get a burned chip to work. Oh well, it's probably something simple.
BobbyK
Dec 16, 2004 08:39 AM
