South West Region South West regional discussion board.
13s
Old Feb 6, 2006 | 02:30 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
13s
Got em on friday, I have to find the slip and post up the whole thing but it was a 13.97 at around 102 mph. I was kinda frustrated because the best I could put down on motor was a 15.13 or so, couldn't even get into the 14's . Clutch is slipping pretty bad, but I think I just suck at driving in general . I've knocked out a few 104 mph passes and I pulled out more timing this time, so I think if I bump it up just a little I might gain that 2 mph back and get a little deeper into "slightly fast car" territory.
Old Feb 6, 2006 | 05:10 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
Congrats Tony. Your where I could never get to. I'd like to be running a mid to high 14 on just the motor. If I had chosen the proper cam I could probably get there. But it's not to be. I will shortly be getting out of the third gen business.
Old Feb 6, 2006 | 05:15 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Don't get rid of the Camaro!! If you want I'd be willing to help ya on putting a bigger cam in.
Old Feb 6, 2006 | 05:58 PM
azvolfan's Avatar
All ready have a buyer. I just don't have the time to put in it any more. And having it as my toy is detracting me from getting a corvette. I have wanted one of those for years.
Old Feb 7, 2006 | 10:27 PM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
Grats Tony!! When is the next time you are going down to the track? I'd like to go, haven't been there in a while. Won't be racing, just wanna watch. Give me a call before you leave next time!
Old Feb 8, 2006 | 02:34 PM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
congrats and it was nice to actually talk to you friday.
Old Feb 8, 2006 | 10:57 PM
3GTAs1TA1Z28's Avatar
Car: 85 87 87 91 92
Engine: 305 TPI 350 TPI 350 Carb
Transmission: B/W T-5 and 700R4
Dude, That Rocks!!!
I am heading out to Firebird Friday to see what this new motor I just finished can do myself......13's would be nice but the last motor I had pulled me into a 14.98 so anything better than that would be sick.....Little worried about traction though....On the street I burn the tires all the way thru 1st and that is from a 20 MPH roll.....I can only imagine a clutch dump.....
Man I hope the track will hold traction better than the street....
Old Feb 9, 2006 | 12:15 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Yeah good to see you out there man, that Stang amazes me every time. Traction at the track is much better than on the street, but it varies from time to time. The best (stickiest) time is during national time trials or right after nats.
Old Feb 11, 2006 | 02:31 PM
2kickassbirds's Avatar
Car: 1991 firebird formula
Engine: 5.8
Sad time for being on the spray come to Tucson I got some stuff for you and we will get that car in the 12s.
Old Feb 12, 2006 | 04:19 PM
ASUspeeddemon's Avatar
Car: '86 Firebird
Transmission: th350
Honestly I haven't seen anybody with TBI go faster in Phoenix. JR when he had his 305 had Torquer heads and ZZ4 cam and he only went low 15's N/A, I can't remember if he ever sprayed or not. I'm not going to put any more money into the engine as it will be replaced eventually, but I will say that the transmission is hard to shift and the clutch is slipping rediculously. The best 60' I could cut was like a 2.13 which isn't good and I'm not sure why it won't launch better, I'm thinking it needs more timing down low, fuel side is dialed in fine.
*Edit* This is Tony posting on Justin's account, sorry
Old Feb 18, 2006 | 06:33 PM
Engine: 5.8
I run 14s all night long in tucson some at 98mph but i no longer have a 305 tbi iys all about the 327 carb.
Old Feb 18, 2006 | 08:35 PM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
yea i run 14.5@99mph but its off...im not sure what to do with it lol. owell its fun
Old Feb 19, 2006 | 12:05 AM
TonyC's Avatar
Car: A Camaro
Engine: Weak
ok
Old Feb 21, 2006 | 08:11 PM
Engine: 5.8
I see you have a 700cfm dp not to far off but the biggest cfm you shold put on that motor is a 650. I would go with a 600, you would get off the line beter and not give up any top end power as long as you keep it under 6000.
Old Feb 21, 2006 | 08:13 PM
7plagues's Avatar
yea ive got a size down jets waitin to be installed. hopeing it will help, we'll see
Old Feb 27, 2006 | 04:54 PM
SchwarzCamaroRS's Avatar
yeah, plagues, your setup should be running faster than that... i run high 14's with swirl ports and a stock cam... good luck with that... hopefully my next trip out to phoenix will be in a 1992 RS 355cid TPI & BW/WC T-5 that runs mid 13's on ported heads and stock cam...
Old Feb 27, 2006 | 05:12 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Shwarzy did you get to run your car??
86IROC350NY
Theoretical and Street Racing
28
Oct 28, 2002 07:37 PM
90Iroc-Zee
Jun 25, 2002 04:30 AM
90Iroc-Zee
Jun 24, 2002 07:55 PM
brian89transam
Apr 25, 2002 08:18 AM
iroc_cragg
Apr 9, 2002 09:22 PM
