South West Region South West regional discussion board.
Headers
Old May 2, 2006 | 09:49 AM
mdurbala's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
Headers
just wondering if putting headers on my 92rs would be too much of a pain in the ***.. ive got opinions from a few buddys and no one really knows not having done it.. has anyone here done it and any recomendations on what kind or better yet a inexpensive shop so i dont have to get dirty :P
Old May 2, 2006 | 12:08 PM
90_WS6_Formula's Avatar
Car: 91 Z28
don't be lazy... do it your damned self
if you get good headers they go on easy
if you get cheap MIM headers they're a PITA to put on
Old May 2, 2006 | 12:33 PM
mdurbala's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
so any recommendations?
Old May 2, 2006 | 02:21 PM
1Bad3rdGen's Avatar
Car: 92 Firebird Convert & 91 Camaro RS
Engine: 305 L03 TBI
Transmission: 700r4 & T5
Axle/Gears: Stock
the passenger side its a pita all the emmission crap is there and you would have to move some of that around to get to the stock manifold.
Old May 2, 2006 | 04:26 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
I just installed some Pacesetter 1336 headers. Easy as pie. The tough part will be the drivers side. I had to remove the ac compressor out of the way(and I think the bracket as well, no biggie). And the emissions. But it was easy. I got my headers coated for $420 and I am happy with them, eventhough my car isn't running and I only drove with them for 40 miles with crap pistons rings and no compression. But they went in easy, no cutting of stock peices or anything. The only thing is the AIR check valves don't screw onto the headers provisions, but they stay on.
Unfortunately I can't give you performance gains or sound bites, because of the problems my car is having, but anything is better thans stock and these look pretty good imho.
Old May 2, 2006 | 04:30 PM
matt3383's Avatar
Car: 2000 Camaro SS
Transmission: t-56
Axle/Gears: 4.10
The hardest part i had was getting the damn header bolts out since i had the locking washers on the bolts. I bought Mac headers.
Old May 2, 2006 | 06:41 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
It's a little tricky, but anyone can do it. It helps to have a cherry picker around to unbolt an engine mount and lift up/tilt the engine to one side.
Old May 3, 2006 | 10:01 AM
89BlueRSCamaro's Avatar
Car: 1989 IROC-Z
Engine: 350-5.7L
Transmission: 700R
bolting on headers is not that bad on a third gen....drivers side is easy...takes about 10 to 15 minutes tops.......on the other hand the drivers side can be a killer.....it took me and my brother about 2 hours....reason being because the last bolt inside the engine, way back in there...i think the one near #7 piston is a pita...that one alone took us about 45 hour (both of us have big hands) and then another 1/2 to screw the bolt in when installing the headers...careful with the oil dip stick cuz you might break it like we did....or i did....we did not remove anything....i also got rid of the AIR system while i was at it.....thats it....not biggie...its a little hard but if you are not afraid of trying to do things yourself and learn then you will have fun...feels good afterwards....at least me since i am learning....good luck and if you already did it..nice
Old May 3, 2006 | 01:44 PM
mdurbala's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
headers are normally cake i was just getting some other opinions on a 3rd gen camaro because tuning that thing up was such a pita
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
