Door Panels
Car: 1992 RS 25th Anniversary
Engine: Hamster Powered
Transmission: However fast he runs
Axle/Gears: 3:42 Peg legger for now
Door Panels
Well as I was working on my car I pulled the door panels off only to find that someone had taken a screwdriver or something and punched holes through them towards the front on the bottom, looks like they used to have speakers there for some stupid *** reason. So as you can imagine it pretty much made the door panels junk. So....... I made new ones using the old ones as sort of a template and I thought I would add a little extra to it, so without further adieu
Lemme know whatcha think, its actually only temporary right now. I just want to get it put back together so when I get my motor and tranny in it I can drive it.
Re: Door Panels
it is really quite easy, just find some type of wood of your preference, I used some stuff I found at lowes can't remember the name of it but it was 10 bux for a 4 x 8 ft sheet. traced the original door panels as best as I could then drew out the design for the flames on cardboard. cut that out as a template. traced it out on the material I used for the door panel itself. Then you decide what type of adhesive you want to use for everything, etc etc. There are more steps thats just a quick run through.
Car: 1987 Camaro
Engine: 5.7
Re: Door Panels
Man, that looks awesome! There used to be some similar to that a guy made on ebay, but I haven seen them in ages, but those look so good.
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Re: Door Panels
Daaayum.
Was it actually wood, or something closer to cardboard? This is almost an idea for me so I don't have to shell out the $160 for my door panels quite yet.
Re: Door Panels
I will see if I can find out the name of the stuff I used and let you guys know
Re: Door Panels
http://www.decpanels.com/Signature_S2S.html That is the exact stuff I bought. But I can't find it on the lowes website. It is actually a wall panel but it is pretty flexible. I used a jigsaw to cut mine out but you could probably use a razor knife if you wanted to take the time. Just go to lowes back by the trim and all that and it should be back there. I used the 1/8 " cause anything any thicker won't work all that great. I used the factory push clips that go inside the doors too!!! If anyone wants to do this and needs any help with it I still have one door panel left to do so I can take lots of pictures and make kind of like a tutorial.
Car: 89Z28 Vert
Engine: 350/tbi
Axle/Gears: 3.27 Posi
Re: Door Panels
that would be great man if you coould do that witht the other door i would love to do this to mine thanks oh how much did it all cost you
Car: 87 GTA
Re: Door Panels
I've never been able to get the cover material to contour to under lying shapes, like your flames.
How'd you get it to contour so well, without folds or wrinkles?
Car: 92 RS, 87 IROC, 89 GTA
Engine: LO3, LB9, L98
Transmission: 700R4 X3
Axle/Gears: 2.70, 3.30, 3.27
Re: Door Panels
so you glue the cardboard to the wood and put the material over it, and thats how u get the design?
Re: Door Panels
NOOOO. lol I found out a long time ago using cardboard as the pattern underneath the fabric doesn't work to well. It lets go after a while. I just use the cardboard as a template so that way both sides are exact.
Re: Door Panels
so you use your base peice of wood, and then another peice of wood for the design, glue the two peices of wood together, and then put on the fabric???
Re: Door Panels
Yeppers thats the basic process. When I start on the drivers side door panel I will take some pictures and do a tutorial for it so if anyone else wants to do it they will have that to go by. I already have the panel and design traced out but its not hard to get to that point. So my tutorial will start from there.
Car: 87 GTA
Re: Door Panels
Again.........
How'd you get it to contour so well, without folds or wrinkles? Care to share HOW?
Re: Door Panels
lol, look up stephen, he answered u. he said its tedious. and that u just take it slow and pay attention to detail and whatnot
Car: 87 GTA
Re: Door Panels
My bad!
I got no Reply Notice, and when the others came in after his, I didn't scroll up and read more.
I will say this though....It's not nearly as easy as he made it sound. Short of using Spandex to stretch over the multiple contours, it always comes out looking like....well....you know!
Re: Door Panels
im sure it one of them, aquired skills. but, im willing to try!
Re: Door Panels
I'm sure it also depends on what type of material you are using. But either way you can make anything look good with a little time.
Car: 1987 Camaro
Engine: 5.7
Re: Door Panels
My bad!
I agree, its not near that easy. Me and a buddy of mine attempted to recover the top material on mine and could barely get it to come out ok, I cant imagine someting lying under it and having to make it raise without getting wrinkls all over. Tried to get it to contour to the factory slit thingswith no luck.
On another note those things look great, seriously.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
